I have the Premiere Pro CC 2015 and when I insert the video avi file (exported animation from Solidworks software which video player show without problems), Premiere decrease the opacity of whole video and lines are not 100% visible, see the image below. Does anyone know what the problem is?
What are the dimensions of the .avi, such as 1920x1080 pixels?
Do the Sequence Settings in Premiere match the resolution of the source video? As your video has very thin lines/fine detail, if the resolution gets reduced that is going to affect the quality.
Jeff
The dimensions of avi file are twice less then Premiere Sequence Settings and maybe that's the reason.
Thanks Jeff for answer.
If you'd care to share the specs of the source file, and also how you intend to delivery final video, perhaps I or others can help suggest a workflow that would improve or maintain the image quality better.
Right-click the source clip in Project bin and select Properties and share an image or text with us
Jeff
The final video will be 1920x1080 and specs of the source file is attached. I export the new animation in bigger resolution and now is ok.
Sounds like it may be a bug, славишап. Can you file it here? Image alpha channel renders too transparent – Adobe video & audio apps
Kevin
