I selected some (not all) of the photos on my iPhone to import into a Lightroom folder. Worked fine. When I attempt to import again (to add photos to a different folder), it shows there are no photos to import. This happens every time. I've tried it with 2 different iPhones. If I then close/reopen Lightroom, the photos are there to import.
Can you give us software version numbers?
Lightroom Classic CC (Help > System Info)
iOS
I'm fairly sure this is a bug in Lightroom import and report
I have this problem too.
Sometimes the photos import. More often, I get a "no photos found" message
Lightroom is probably treating this as if you did not properly eject the removable media,check for the box to eject when complete, then if you disconnect the phone followed by reconnecting the phone LR might treat it better, also, do not have the option to not import suspected duplicates on.
I'm having the same problem and cannot fix it... I've tried rebooting the computer a few times, taking the iphone out and plugging it back in, quitting lightroom and restarting it... nothing works
Simple COPY the images off the iPhone to a folder on your computer using the File Manager for the OS used on your computer. Then import them into LR.
Are HEIF images involved?
Go and look at this discussion: How do I import iPhone HEIF images into Lightroom Classic CC on Mac?
