when importing .MTS footage into premier footage time extended. means raw footage shows 11 minutes duration, after import into sequence it shows 20 minutes.
fps rate is same
Have a look at this thread which talked about a similar problem and so may provide the solution to you:
Hi shivak90452326,
Sorry for the issue. What is the exact dot version of Premiere Pro? FAQ: How to find the exact version of Premiere Pro you're using?
What is the source of the footage? Is this happening with all MTS files?
Vidya
software version 12.1.2 (Build 69). You can see my problem here, here some of videos showing 1 hour duration actually they are 20 minutes clips
Hi shivak90452326,
Thanks for the reply. As suggested in the thread shared by Dean Utian, it might be an issue with the importing workflow.
Have you imported the files using Media Browser?
Vidya
