GPU Acceleration not available in PP CC 2019
Oct 18, 2018 Oct 18, 2018
Mercury Playback engine GPU acceleration (CUDA) doesn't work / isn't available in PP CC 2019 version.
Luckily, I've learned my lesson and kept previous version this time (2018) in which the Mercury Playback engine GPU acceleration (CUDA) was and still is available every time.
Intel Core I7-5930K @ 3.5 ghz
64gb RAM
GeForce GTX 980 Ti
56.1K
New Here , Jan 21, 2019 Jan 21, 2019
Latest Nvidia drivers worked for me.
MSI GS65 Stealth Thin 8RF
Windows 10 Home Version 10.0.17134 Build 17134
NVidia GeForce 1070 with Max-Q Design
Cuda acceleration now listed.
Adobe Employee ,
Sentern,
Have you updated GPU drivers yet? That may hold the key to your solution.
Kevin
What does that mean?
You need to move to the newer series of drivers for that card. Go to the Nvidia site and download/install the newest version of the driver.
Neil
Yeah, and updating to the latest Nvidia driver in the past has caused my system to crash. How is it that we're in late 2018 and these @Y*@Y!@!!!  companies still haven't figured out how to make things work together?  Will Artificial Intelligence someday relieve us users of the burden of hardware and software incompetence?
Updating hardware drivers to the latest version has always been required to keep a pro level NLE, fx, or grading app functioning correctly.
Then of course the more antiquated hardware you write extra code to support, the more limited the effort to move forward with performance and the easier it is for instabilities to happen.
I've had crashes or screen garbled from drivers both from an older driver or the newest being screwy.
Takes what, 5 minutes to change drivers. I manually check for video drivers at least every other week. Part of the trade. Needed for both the Adobe apps and Resolve.
Neil
Adobe Employee ,
Dec 18, 2018 Dec 18, 2018
You still there Jim? Get it working with new drivers?
Kevin
Feb 06, 2019 Feb 06, 2019
Regards, How did you get it? I have a core i9 8950hk and GPU GTX 1070, the updated drivers and I can not get it activated.
Adobe Employee ,
If you're working on a laptop with a second Intel GPU, make sure your Intel drivers are updated correctly as well.
What version of Nvidia drivers are you working with? Are your GPU acceleration options grayed out?
Mar 18, 2019 Mar 18, 2019
I run Adobe CC on a Dell Precision 7710 with an nVidia M3000M.
Has anyone had experience with installing the new driver which Dell last updated on 03 Mar 2019?
My Mercury Engine Hardware Acceleration issue seems to have been resolved by updating the driver for my second Intel Graphics card.
I'm wondering whether I should leave well enough alone or also install the new NVidia driver from Dell.
Adobe Employee ,
I'm assuming you updated to Intel GPU driver x.100.6444 or later, correct?
Some have needed to change one setting after updating to the new Nvidia DCH driver.
I made this change on my system and the new driver has been working great.
Nvidia DCH drivers / Open GL crash
https://www.pugetsystems.com/labs/support-software/Resolving-NVIDIA-Quadro-OpenGL-Kernel-Exception-1...
Mar 20, 2019 Mar 20, 2019
Thanks Wes.  Yes, the new driver is: 25.20.100.6472
Question:  If my Mercury Engine Hardware Acceleration is working now, what benefit would there be in updating my nVidia driver?
Adobe Employee ,
If all is working well, I probably wouldn't update
Driver updates are often motivated by constant change and evolution of features, etc....  Sometimes newer drivers can break things.
If you are up and running without issues....you're probably good to go!
Hi! My premiere When using CUDA happens blue screen (Drive State power failure)... I'Ve made all the updates. I Formatted, reinstalled... But the premiere only works when I disable the NVidia Drive. GTX 1050 TI (notebook). I need some help. There are many days I fight against this problem.
Adobe Employee ,
What version are your Intel GPU drivers?
Adobe Employee ,
Glad to see the Intel driver updated. That snags some people but you are in good shape there.
Here's one more thing to try.  Can you go into your preferences>media and turn off hardware accelerated decoding?
If that doesn't help - lmk.
Did it in the premiere; Turn off hardware accelerated decoding. I Enabled the Nvidia drive, restarted and opened the premiere. 5 minutes using the software and... Blue screen.
Adobe Employee ,
Are there other apps you can test with that GPU?  This is definitely a highly abnormal strange issue and I have not heard of a similar issue where Premiere Pro would cause a blue screen like this.
What version of Premiere are you using? Have you tried 2018 and 2019? That should be a useful thing to try as it will provide more useful information
I Also think it's very strange. Also occurs with Media Encoder. I'll install another editor to test.
Enthusiast ,
Mar 21, 2019 Mar 21, 2019
It helps if you can give the message when you got the blue screen. It usually points to the driver or service that is causing the issue?
Blue screens are normally cause by hardware interrupt issues, sometimes caused by incompatible software. In particular I would avoid any third party codec packs (apart from ones like SMPTE approved Avid DNxHD). Tracking down problem software is always tricky.
Jun 15, 2019 Jun 15, 2019
I'm using a 2016 macbook pro
Mohave OS 10.14.5
Graphics cards Radeon Pro 460 4 GB
      Intel HD Graphics 530 1536 MB
I have 3 monitors attached to the laptop.
Premiere 2018 allows me to use my laptop and another monitor as full screen program monitors.
When I upgraded to Premiere 2019 I became unable to check the Video Device monitor choices. It ignores my selections. So my laptop and client monitor will only display their desktops. The external monitor selections are still accepted on Premiere 2018.
I'm using Mercury playback GPU accel Open CL. Metal doesn't solve the problem either.
Mac won't allow me to use the CUDA option. I have a Radeon Pro 460 4gb and Intel HD Graphics 530 1536 mb.
There are no options to update these drivers on the AMD and Intel sites for an OS operating system. My understanding is that MAC automatically updates the drivers when the OS is updated and I'm running the most recent OS.
I've trashed my preferences.
I can't revert back to Premiere 2018 because the project I inherited was created on the 2019 version and won't allow me to go backward. I'm going blind squinting at the program monitor. Any help is appreciated. Thanks.
This is an acknowledged bug in this version and we're waiting for the next patch to be released. I've had this also.
Neil
Engaged ,
Apr 21, 2019 Apr 21, 2019
I've got a Sager P170HM laptop I'm working on which has a GTX 580M GPU and version 391.35 of the drivers installed on Windows 10 64-bit, but GPU acceleration isn't available for Premiere Pro CC 2019. It works fine in Premiere Pro CC 2018 (version 12.1.2). Is this GPU just no longer compatible with the newest version of Premiere? It had popped up a message about CUDA 9.2, but I don't remember exactly what it said and the message no longer comes up.
