Hello
I Just recently downloaded the trial version of Premiere Pro CC to try it out with a project we have going on and i have a couple of video recordings that i have produced on one of our android tablets which is recorded in AVC .mp4 format and it playback just fine on my workstation PC but when i import it in Premiere and playback there i get a green mess in the previewer
if i export it and play it back on the same PC i get this green mess aswell, so my question is can i do anything to make this right? i Have tried to reencode the source file with other apps to H264 and other formats which playback fine but still has this problem whenever i import them to Premiere.
I was hoping to be able to use Premiere ofr my project but i'm not sure what to do here?
I include here the info i got with mediainfo about the specs of the source file:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.2
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, RefFrames : 1 frame
Muxing mode : Container profile=High@1.3
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 9 s 123 ms
Source duration : 9 s 267 ms
Bit rate : 697 kb/s
Width : 720 pixels
Height : 1 152 pixels
Display aspect ratio : 0.625
Frame rate mode : Variable
Frame rate : 9.496 FPS
Minimum frame rate : 4.948 FPS
Maximum frame rate : 62.718 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.089
Stream size : 780 KiB (83%)
Source stream size : 795 KiB (84%)
Title : VideoHandle
Language : English
Color range : Limited
Color primaries : BT.601 PAL
Transfer characteristics : BT.601
Matrix coefficients : BT.601
mdhd_Duration : 9123
Codec configuration box : avcC
Best Regards
Mattias
many thanks, the driver did the trick
