Hello,
tried to update an existing RH Projekt to the new one. Without success. The existing css is empty in the converted version.
It is not possible for me to switch the language of the program surface from German to English.
Sorry but this seems to be an early beta version.
Thank you for your help
Thomas
Hi Thomas,
Can you please share the project with us so that we can see what is going wrong?
Project upgrade works smoothly in RH 2019. RH 2019 update 2 has also been released. Product is not in early beta phase and can definitely be used for all major use-cases like upgrade, publishing and so on.
Thanks in advance for you help.
Surbhi Maheshwari
Hello Surbhi,
thank you for your reply. I'm not of your opinion. We could not work with the new version 2019 Update 2. You will find both projects the old and the new one in the attchements.
https://www.netinform.de/awsv.zip
https://www.netinform.de/AwSV_rh2019.zip
Thank you for help
Thomas
Hi Thomas,
I investigated your RH 2017 project and it's upgrade to 2019. CSS has not been upgraded correctly and the reason for that is CSS contains some extra { braces.
Can you please try replacing the CSS with this attached CSS(Fixed CSS file )and then try upgrading your project again?
If you find any more issues, do let us know.
Thanks and Regards,
Surbhi Maheshwari
Hi Surbi,
now it works a little bit better. But there are many new bugs.
In the generated chm Output are all German Umlate in the TOC lost.
It is not possible to work with this version,.I have to go back to the classic version.
Thanks and Regards
Thomas
Hi Thomas,
Thanks for the update.
We will be fixing the umlaut character issue in chm output in coming update.
Are there any more issues you are facing while using RH 2019?
Surbhi Maheshwari
Hi Surbhi,
tank you. I don't know any more issues because I'm working with the old version now.
Regards
Thomas
