Keyframing time remapping, Help
Oct 23, 2018 Oct 23, 2018
I have been trying to figure this out for ages so I will be very very happy if someone manages to figure it out. I am trying to create the effect where it looks like the camera is flying through video screens. (this is a demonstration with pictures and not videos)
and then
and then
So for this, I have keyframed the scale from 0 to 180 and I have keyframed the position from the centre of the frame to go to the side of the frame. (I also overlapped two video tracks going the opposite direction so you get the idea of the effect I want). The problem comes with the timing. Because the position is moving at an even speed (because it's between two keyframes)  then when the picture frame is at a small scale, lets say 100 position to the right, it seems like its moving very quickly but then when the picture frames scale gets large then 100 to the right looks like it is moving very slow. I did fix this by using the time remapping function and slowing down the first part of the clip and speeding up the second part of the clip. This worked as I wanted when I tried it with pictures but the problem is that I want to do it with video and using time remapping will affect the video playback and not just affect the position and scale. I tried doing it on an adjustment layer but when I hit play it just showed black on the playback window. So trying to explain the effect I want... I want is similar to the stargate thing in 2001 space odyssey apart from instead of the lights on each side I want there to be videos.
807
My first thought is to take a different approach.  Create additional keyframes when the image is small to make it's travel take longer.
Enthusiast ,
I think keyframing this correctly in Premiere would be very time consuming. After Effects has 3D built in and would be a much better place to accomplish this.
Adobe Employee ,
Hi Chris! This sounds tricky, but I understand the effect you're going for, that'll look cool. Could you upload a video of what you've done so far and show us what the video is currently doing? I think we can find a solution if we know where you are. Looking forward to figuring this out with you!
Caroline
Adobe Employee ,
Nov 05, 2018 Nov 05, 2018
Still trying to get this done, Chris? Let us know.
Kevin
