Just installed premiere pro cc 2018 and trying to do a short commercial.... put the videos and audio in the sequence line, and nothing...no playback whatsoever. what is going on? i do not have any presets, no plugins, nothing. could it be a codec? video was shot with canon 60d. please i need help.
Hi rhmcclurg,
Sorry for the trouble. Just for a test, change the renderer & check the issue. Here are the steps: FAQ: How to change the Video Renderer in Premiere Pro?
What are the system specs(OS, RAM, GPU, CPU)?
Vidya
Nothing happened with rendering (i tried that before i messaged, nothing happened prior to rendering and after). I used to have this installed 2 years ago different model and worked fine (dont know what i did)
Specs:
Windows 10
Processor: AMD A6-5200 with Radeon HD Graphics 2.0GHz
Memory: 8GB
SYS: 64Bit
When i hit play, does nothing just shows stop button, time does not advance.
I also try to change audio setting from mme to asio and the program freezes instantly. I have a Presonus AudioBox iTwo audio interface that i run the line in and out from as well.
Hi rhmcclurg,
Thanks for the info. Please share a screenshot of Preferences > Audio Hardware.
Just for a test, change the Default Input in Preferences > Audio Hardware > Default Input to 'NO INPUT' and check the issue.
Vidya
I had the same problem on my brand new Alienware R5 17 using Windows 10. I just checked this button after reading you emails strings and it fix my issue.
Dwaine
This help me so much, thank you and now my audio is working now. Thanks!
Hello,
Got the same problem with a Gigabyte.
GTX 1070
32 Go ram
Everything on SSD.
Well, Dwain, you are right it's a audio issue.
I didn't have the same menu as you but when getting inside the material configuration, there were a driver conflict :Realtek stereo and Realtek surround,...
So just keep the stereo one. Deactivate the other(s) ones.
And that worked perfectly, even in full resolution with 4K.
AG
