I am having the same issue. This is terrible.
And now it crashes when trying to export to media encoder.
rickl29819540 Please update your video card driver directly from Nvidia website, do not run a normal windows update for that.
Also check if you have any Logitech cameras, this is an issue now..
Slow export and crashing occur when you are on Software Only, Premiere does not recognize your GPU
Strangely my Logitech webcam was the reason for my decrepitly slow rendering. I simply unplugged it and voila! Media Encoder and Premiere Pro are rendering just dandy now.
I did plug the webcam back in to see if messes thing up again. Nothing wrong so far. Everything is working fine.
Computer Specs:
2016 MacBook Pro 15-inch
Processor: 2.7 GHz Intel i7
Graphics: Radeon Pro 455 2048 MB
Intel HD Graphics 530 1536 MB
Memory: 16 GB RAM
500GB SSD
Webcam: Logitech C615
Hi Drew,
Thanks for the feedback.
The Logitech webcam drivers has been reproduced internally and a fix for this issue will be available in the very near future.
Wes
This seems to work.
Close premiere.
Open Media Encoder.
In media encoder, click file, add premiere pro sequence, follow prompts to import sequence
rickl29819540 do you have the same versions of Premiere Pro and Media Encoder ? It should export normally from Premiere without this workaround
I upgraded both media encoder and premiere this morning. ENCODING DIRECTLY FROM PREMIERE DOES NOT WORK NOW.
Have you tried launching Media Encoder by itself and then exporting to Media Encoder directly from Premiere afterwords? I had to do this for my first export right after the update but have been able to encode directly from Premiere ever since.
I totally agree, exporting to Encoder freezes the timeline completely. I can export straight from the export panel and it works.
where are you from
