Is it possible to find all images below 300dpi in a book document?
Oct 25, 2018 Oct 25, 2018
Hi there, I'm hoping this is a quick question. I've had a look on google but to no avail.
This script run in open document only to search and plug images below 300dpi.
Is it possible to run this script in Book File?
  1. //DESCRIPTION:Report Bad Resolutions for a New Year
  2. // No Guarantees, Ltd. Use at your own risk.
  3. // Jongware, 05-Feb-2010
  4. // Minimum dpi allowed:
  5. var minimumValue = 300;
  6. // Alert when x/y scaling is off by this much percents:
  7. var percentageScaling = 1;
  8. var lowResList = new Array;
  9. for (aGraphic=0; aGraphic<app.activeDocument.allGraphics.length; aGraphic++)
  10. oneGraphic = app.activeDocument.allGraphics[aGraphic];
  11. try {
  12.   xres = oneGraphic.effectivePpi[0];
  13.   yres = oneGraphic.effectivePpi[1];
  14.   if (xres < minimumValue || yres < minimumValue)
  15.    lowResList.push (oneGraphic);
  16.   else
  17.   {
  18.    if (xres < yres)
  19.     scaling = 100*yres/xres;
  20.    else
  21.     scaling = 100*xres/yres;
  22.    if (scaling > 100+percentageScaling)
  23.     lowResList.push (oneGraphic);
  24.   }
  25. } catch (_) {}
  26. if (lowResList.length > 0
  27. doc = app.documents.add();
  28. frame = doc.textFrames.add({geometricBounds:[0,0,doc.documentPreferences.pageHeight, doc.documentPreferences.pageWidth]});
  29. txt = '';
  30. for (i=0; i<lowResList.length; i++)
  31.   pg = ultimateParent (lowResList);
  32.   txt = txt+"File: "+lowResList.itemLink.name;
  33.   if (pg.parent instanceof(MasterSpread))
  34.    txt = txt+' on Master spread '+pg.name;
  35.   else
  36.    if (pg instanceof(Spread))
  37.    {
  38.     txt = txt+' on clipboard of pg '+pg.pages[0].name;
  39.     for (j=1; j<pg.pages.length; j++)
  40.      txt += '-'+pg.pages.name;
  41.    } else
  42.     txt = txt+' on pg '+pg.name;
  43.   txt = txt+' has xres: '+lowResList.effectivePpi[0]+', yres: '+lowResList.effectivePpi[1]+'\n';
  44. frame.contents = txt;
  45. } else
  46. alert ("No images have a resolution less than "+minimumValue+" dpi");
  47.
  48. function ultimateParent(obj)
  49. while (1
  50.   obj = obj.parent;
  51.   if (obj.constructor.name == "Page"
  52.    break;
  53.   if (obj.constructor.name == "Character"
  54.    obj = obj.parentTextFrames[0];
  55.   if (obj.constructor.name == "Spread" || obj.constructor.name == "MasterSpread"
  56.    break;
  57. return obj;
Scripting
2.4K
Enthusiast ,
Oct 26, 2018 Oct 26, 2018
Below is a sample demonstration script written for AppleScript that does what you are looking for. It produces a list of the names of graphics where effective PPI is less than 299 or greater than 301 for both the x and y parameters. This can give you some ideas for your ExtendScript.
tell application "Adobe InDesign CC 2018"
  set bookCount to count of books
  if bookCount = 0 then
  set fileRef to choose file
  set bookRef to open bookFile
  else
  set bookRef to book 1
  end if
  set badList to {}
  set bookFiles to book contents of bookRef
  with timeout of 500 seconds
  repeat with i from 1 to length of bookFiles
  set thisDoc to item i of bookFiles
  set docStatus to status of thisDoc
  if docStatus is not "document is open" then
  set docPath to full name of thisDoc
  set docRef to open file docPath
  else
  set docName to name of thisDoc
  set docRef to document docName
  end if
  tell docRef
  set graphicList to all graphics
  end tell
  repeat with j from 1 to length of graphicList
  set thisGraphic to item j of graphicList
  set thisPPi to effective ppi of thisGraphic
  set thisTest to 0
  if item 1 of thisPPi < 299 or item 2 of thisPPi > 301 then
  set thisTest to thisTest + 1
  end if
  if item 2 of thisPPi < 209 or item 2 of thisPPi > 301 then
  end if
  if thisTest > 0 then
  set end of badList to name of item link of thisGraphic
  end if
  end repeat
  end repeat
  end timeout
end tell
Thanks Hopkins... but I'm not good in translating/reading AppleScript
Oct 29, 2018 Oct 29, 2018
You should be able to get the bookContents and then loop through each entry, making sure it is open in InDesign then run your code on it.
// assuming only one book open.
var myBook = app.books[0];
var allInddFiles = myBook.bookContents;
for ( var i = 0; i < allInddFiles.length; i++)
     var curDoc = app.open ( allInddFiles.fullName )
     // your code here, with changes to cope with using the curDoc variable from above
     // close your doc when you are finished
     curDoc.close ( SaveOptions.NO);
Hope this helps
Malcolm
Oct 30, 2018 Oct 30, 2018
Hi Malcolm,
I've tried your suggestion but the outcome will open every document create list then closed then open another one create list then close again until the last indesign in a book. Is there a way that it will run first throughout the book then create only one list of images.
Many thanks.
-ryu
Hi Ryu,
My code doesn't handle the creation of the list document at all, but if you want all images to be listed in one document, create that document before you start the loop and always write to it in the code.
//Something like
var doc = app.documents.add();
     try {
      else
       if (xres < yres)
       else
     } catch (_) {}
    if (lowResList.length > 0)
     txt = '';
      else
       } else
    } else
     while (1)
      obj = obj.parent;
      if (obj.constructor.name == "Page")
       break;
      if (obj.constructor.name == "Character")
      if (obj.constructor.name == "Spread" || obj.constructor.name == "MasterSpread")
       break;
     return obj;
Hope this helps
Malcolm
Enthusiast ,
Sorry, but I already had an AppleScript. Here is the script translated for JavaScript. It's coarse, I know but pretty much line for line. That way you can see how easy it is to translate from AppleScript to JavaScript and vice-versa. Script is not thoroughly tested either.
var appRef = app;
var bookCount = appRef.books.count();
if (bookCount == 0) {
  var fileRef = File.openDialog("Select inDesign book file");
  var bookRef = appRef.open(File(fileRef));
} else {
  var bookRef = appRef.books.item(0);
var badList = [];
var bookFiles = bookRef.bookContents;
for (var i = 1; i < bookFiles.length; i++) {
var docRef = bookFiles;
var docStatus = docRef.status;
if (docStatus == BookContentStatus.DOCUMENT_IS_OPEN) {
    var docName = bookFiles.name;
    docRef = appRef.documents.itemByName(docName);
  } else {
      var docPath = docRef.fullName;
      docRef = appRef.open(File(docPath));
   var graphicList = docRef.allGraphics;
   for (var j = 0; j < graphicList.length; j++) {
       var thisTest = 0;
       var thisGraphic = graphicList;
       var thisPpi = thisGraphic.effectivePpi;
       if (thisPpi[0]< 299 || thisPpi[0]> 301) {
           thisTest += 1;
      if (thisPpi[1] < 299 || thisPpi[1]> 301) {
           thisTest += 1;
   if (thisTest >0) {
       badList.push(thisGraphic.itemLink.name);
}//ends repeat j
} //ends repeat i
badList;
Oct 31, 2018 Oct 31, 2018
Hi Hopkins,
How can I fix this error in your translated code.
for certain types of graphics property effectivePpi is not available.
Like placed AI files or PDFs…
Uwe
Which is why that part is wrapped in my script in a try...catch block.
Enthusiast ,
Nov 24, 2018 Nov 24, 2018
Don't need try/catch. Just check the object constructor... let us assume object is named graphic...
if (graphic instanceof Image) {
   ppi = graphic.effectivePpi;
} else {
    // 'graphic' is not raster (not an 'Image').
William Campbell
Engaged ,
If you want to skip the code, just download a full working demo of FlightCheck. Drag-and-drop your InDesign file onto it. Look at the main window and see the "images" section. There you can sort by DPI and many other factors.
Friendly Regards,
David Dilling
Markzware
Enthusiast ,
Try this free script. Select book doc, choose to make a CSV and open in Excel, sort by row PPI and you can see all that fall below whatever value you're after.
https://www.marspremedia.com/software/indesign/links-report
William Campbell
Contributor ,
Nov 25, 2018 Nov 25, 2018
Why do you need scripting for this? Why do you not simple use Indesign's preflight to check your book?
Right.
Preflight will even catch more:
Image data in placed PDFs or AIs, also in placed EPS files.
Uwe
