10 Replies Latest reply on Oct 31, 2018 7:36 AM by DavidMWE
    Is it possible to find all images below 300dpi in a book document?
    manilap94829696 Level 1
      Hi there, I'm hoping this is a quick question. I've had a look on google but to no avail.
      This script run in open document only to search and plug images below 300dpi.
      Is it possible to run this script in Book File?
      //DESCRIPTION:Report Bad Resolutions for a New Year
      // No Guarantees, Ltd. Use at your own risk.
      // Jongware, 05-Feb-2010
      // Minimum dpi allowed:
      var minimumValue = 300;
      // Alert when x/y scaling is off by this much percents:
      var percentageScaling = 1;
      var lowResList = new Array;
      for (aGraphic=0; aGraphic<app.activeDocument.allGraphics.length; aGraphic++)
       oneGraphic = app.activeDocument.allGraphics[aGraphic];
       try {
        xres = oneGraphic.effectivePpi[0];
        yres = oneGraphic.effectivePpi[1];
        if (xres < minimumValue || yres < minimumValue)
         lowResList.push (oneGraphic);
        else
         if (xres < yres)
          scaling = 100*yres/xres;
         else
          scaling = 100*xres/yres;
         if (scaling > 100+percentageScaling)
       } catch (_) {}
      if (lowResList.length > 0)
       doc = app.documents.add();
       frame = doc.textFrames.add({geometricBounds:[0,0,doc.documentPreferences.pageHeight, doc.documentPreferences.pageWidth]});
       txt = '';
       for (i=0; i<lowResList.length; i++)
        pg = ultimateParent (lowResList[i]);
        txt = txt+"File: "+lowResList[i].itemLink.name;
        if (pg.parent instanceof(MasterSpread))
         txt = txt+' on Master spread '+pg.name;
        else
         if (pg instanceof(Spread))
          txt = txt+' on clipboard of pg '+pg.pages[0].name;
          for (j=1; j<pg.pages.length; j++)
           txt += '-'+pg.pages[j].name;
         } else
          txt = txt+' on pg '+pg.name;
        txt = txt+' has xres: '+lowResList[i].effectivePpi[0]+', yres: '+lowResList[i].effectivePpi[1]+'\n';
       frame.contents = txt;
      } else
       alert ("No images have a resolution less than "+minimumValue+" dpi");
      function ultimateParent(obj)
       while (1)
        obj = obj.parent;
        if (obj.constructor.name == "Page")
         break;
        if (obj.constructor.name == "Character")
         obj = obj.parentTextFrames[0];
        if (obj.constructor.name == "Spread" || obj.constructor.name == "MasterSpread")
         break;
       return obj;
        • 1. Re: Is it possible to find all images below 300dpi in a book document?
          S Hopkins Adobe Community Professional
          Below is a sample demonstration script written for AppleScript that does what you are looking for. It produces a list of the names of graphics where effective PPI is less than 299 or greater than 301 for both the x and y parameters. This can give you some ideas for your ExtendScript.
          tell application "Adobe InDesign CC 2018"
            set bookCount to count of books
            if bookCount = 0 then
            set fileRef to choose file
            set bookRef to open bookFile
            else
            set bookRef to book 1
            end if
            set badList to {}
            set bookFiles to book contents of bookRef
            with timeout of 500 seconds
            repeat with i from 1 to length of bookFiles
            set thisDoc to item i of bookFiles
            set docStatus to status of thisDoc
            if docStatus is not "document is open" then
            set docPath to full name of thisDoc
            set docRef to open file docPath
            else
            set docName to name of thisDoc
            set docRef to document docName
            end if
            tell docRef
            set graphicList to all graphics
            end tell
            repeat with j from 1 to length of graphicList
            set thisGraphic to item j of graphicList
            set thisPPi to effective ppi of thisGraphic
            set thisTest to 0
            if item 1 of thisPPi < 299 or item 2 of thisPPi > 301 then
            set thisTest to thisTest + 1
            end if
            if item 2 of thisPPi < 209 or item 2 of thisPPi > 301 then
            end if
            if thisTest > 0 then
            set end of badList to name of item link of thisGraphic
            end if
            end repeat
            end repeat
            end timeout
          end tell
          • 2. Re: Is it possible to find all images below 300dpi in a book document?
            Thanks Hopkins... but I'm not good in translating/reading AppleScript
            • 3. Re: Is it possible to find all images below 300dpi in a book document?
              BarlaeDC Adobe Community Professional
              You should be able to get the bookContents and then loop through each entry, making sure it is open in InDesign then run your code on it.
              // assuming only one book open.
              var myBook = app.books[0];
              var allInddFiles = myBook.bookContents;
              for ( var i = 0; i < allInddFiles.length; i++)
                   var curDoc = app.open ( allInddFiles[i].fullName )
                   // your code here, with changes to cope with using the curDoc variable from above
                   // close your doc when you are finished
                   curDoc.close ( SaveOptions.NO);
              Hope this helps
              Malcolm
              • 4. Re: Is it possible to find all images below 300dpi in a book document?
                Hi Malcolm,
                I've tried your suggestion but the outcome will open every document create list then closed then open another one create list then close again until the last indesign in a book. Is there a way that it will run first throughout the book then create only one list of images.
                Many thanks.
                -ryu
                • 5. Re: Is it possible to find all images below 300dpi in a book document?
                  Hi Ryu,
                  My code doesn't handle the creation of the list document at all, but if you want all images to be listed in one document, create that document before you start the loop and always write to it in the code.
                  //Something like
                  var doc = app.documents.add();
                       try {
                        else
                         if (xres < yres)
                         else
                       } catch (_) {}
                       txt = '';
                        else
                         } else
                      } else
                       while (1)
                        obj = obj.parent;
                         break;
                         break;
                       return obj;
                  Hope this helps
                  Malcolm
                  • 6. Re: Is it possible to find all images below 300dpi in a book document?
                    Sorry, but I already had an AppleScript. Here is the script translated for JavaScript. It's coarse, I know but pretty much line for line. That way you can see how easy it is to translate from AppleScript to JavaScript and vice-versa. Script is not thoroughly tested either.
                    var appRef = app;
                    var bookCount = appRef.books.count();
                    if (bookCount == 0) {
                      var fileRef = File.openDialog("Select inDesign book file");
                      var bookRef = appRef.open(File(fileRef));
                    } else {
                      var bookRef = appRef.books.item(0);
                    var badList = [];
                    var bookFiles = bookRef.bookContents;
                    for (var i = 1; i < bookFiles.length; i++) {
                    var docRef = bookFiles[i];
                    var docStatus = docRef.status;
                    if (docStatus == BookContentStatus.DOCUMENT_IS_OPEN) {
                        var docName = bookFiles[i].name;
                        docRef = appRef.documents.itemByName(docName);
                      } else {
                          var docPath = docRef.fullName;
                          docRef = appRef.open(File(docPath));
                       var graphicList = docRef.allGraphics;
                       for (var j = 0; j < graphicList.length; j++) {
                           var thisTest = 0;
                           var thisGraphic = graphicList[j];
                           var thisPpi = thisGraphic.effectivePpi;
                           if (thisPpi[0]< 299 || thisPpi[0]> 301) {
                               thisTest += 1;
                          if (thisPpi[1] < 299 || thisPpi[1]> 301) {
                               thisTest += 1;
                       if (thisTest >0) {
                           badList.push(thisGraphic.itemLink.name);
                    }//ends repeat j
                    } //ends repeat i
                    badList;
                    • 7. Re: Is it possible to find all images below 300dpi in a book document?
                      Hi Hopkins,
                      How can I fix this error in your translated code.
                      • 8. Re: Is it possible to find all images below 300dpi in a book document?
                        Laubender Adobe Community Professional & MVP
                        for certain types of graphics property effectivePpi is not available.
                        Like placed AI files or PDFs…
                        Uwe
                        • 9. Re: Is it possible to find all images below 300dpi in a book document?
                          [Jongware] Most Valuable Participant
                          Which is why that part is wrapped in my script in a try...catch block.
                          • 10. Re: Is it possible to find all images below 300dpi in a book document?
                            DavidMWE Level 2
                            If you want to skip the code, just download a full working demo of FlightCheck. Drag-and-drop your InDesign file onto it. Look at the main window and see the "images" section. There you can sort by DPI and many other factors.
                            Friendly Regards,
                            David Dilling
                            Markzware
