8 Replies Latest reply on Oct 29, 2018 8:55 AM by Laubender
      • 1. Re: Add text if ParagraphStyle is found
        Manan Joshi Level 4
        Try the following code
        function addTextToPara(pStyleName, prefixText)
               app.findGrepPreferences.appliedParagraphStyle = pStyleName
               var paraList = app.activeDocument.findGrep()
               for(var i = 0 ; i < paraList.length; i++)
                    paraList[i].contents = prefixText + paraList[i].contents
               app.findGrepPreferences = NothingEnum.nothing;
        //Change the argument with the name of the paragraph style you want to search and the text you want to add before that para
        addTextToPara("Paragraph Style 2", "<1>")
        -Manan
        • 2. Re: Add text if ParagraphStyle is found
          beh_gras_beh Level 1
          Hi Manan,
          That worked perfectly!
          Many thanks.
          • 3. Re: Add text if ParagraphStyle is found
            Hi Manan and others,
            Is there also an way the text would be at the end of an paragraph?
            Like <1>here is some text<1>
            Again thanks for you'r help!
            Greetings.
            • 4. Re: Add text if ParagraphStyle is found
              Manan Joshi Level 4
              In place of the below line in the code mentioned before in the thread use the line that follows it
              //Replace this
              //With this
              paraList[i].contents = prefixText + paraList[i].contents + prefixText
              -Manan
              • 5. Re: Add text if ParagraphStyle is found
                Wouw that's an extremely fast answer! Thanks!
                It is placing the text alright but at the beginning of an new paragraph.
                This
                Becomes this
                I'm wondering if there is an way you can tell indesign that there is an end of an paragraph (without using /n or /r)?
                And if found add <2> so you get <2>TEST<2>.
                Greetings.
                • 6. Re: Add text if ParagraphStyle is found
                  Manan Joshi Level 4
                  I am not sure why you don't wanna use \r or \n for check condition. The following works for me
                         var paraList = app.activeDocument.findGrep(true)
                                 if(paraList[i].contents[paraList[i].contents.length - 1] == '\r')
                                      paraList[i].insertionPoints[-2].contents =  prefixText
                                 else
                                      paraList[i].insertionPoints[-1].contents = prefixText
                  -Manan
                  1 person found this helpful
                  • 7. Re: Add text if ParagraphStyle is found
                    Oh, but this works perfectly, can I double give you the credits?
                    The reason I'm scared to use \r is that sometimes in the story there is an \r and sometimes an \n.
                    I thought when you use that variable the script puts in the middle of story 's an <1> and I only wanted it at the end of each lines of text with an specific paragraph style but that's not the case, I see now.
                    You look for an specific paragraph style and the end of each paragraph style it always ends with an \r. I was thinking wrong.
                    Again for the second time thanks for you'r help!
                    Greetings.
                    • 8. Re: Add text if ParagraphStyle is found
                      Laubender Adobe Community Professional & MVP
                      Hi beh_gras_beh ,
                      is this thread related to the one below? Guess, yes:
                      GREP style in paragraph with ~b \r or \n?
                      Uwe
