Is this possible by adding alternative empty columns in indesign tables by indesign scripts?
Participant ,
Oct 26, 2018 Oct 26, 2018
My indesign file contains more tables and my task is want to add alternative empty columns in indesign tables. Please guide me is this possible by indesign scripts?
Before:
After:
Thanks in advance.
by
hasvi
Scripting
555
Community Expert , Oct 29, 2018 Oct 29, 2018
Hi Hasvi,
See the screenshot of what i start with and what i get once i do the changes i mentioned in the latest post.
After code execution, columns inserted after all except the first one. Now tell what is needed.
-Manan
Oct 27, 2018 Oct 27, 2018
Yes that is very much possible, select your table and run the following script
var t = app.selection[0]
var columnLen = t.columns.length
for(var i = columnLen - 1; i >= 0 ; i--)
     t.columns.add(LocationOptions.AFTER, t.columns)
-Manan
Participant ,
Oct 28, 2018 Oct 28, 2018
hi,
It's working fine, but want to insert except 1st column in table. If possible guide me.
thanks
hasvi
Do you want to say that every column should be followed by an empty column that we insert except the first one? If it is so then change the for loop condition to i > 0.
Participant ,
It works fine for except the last one, but my result should be except the first column.
by
hasvi
Hi Hasvi,
-Manan
Participant ,
Yes, I got it. Thanks.
by
Hasvi
