Same here, double-clicking on an empty area in the project makes PPCC2019 freeze. Drag & Drop from Explorer to PP-project panel is fine though...
I have the same problem too. Any move that opens up another window to import file, or even to change file saved location caused my pp 2019 to freeze and crash. The software just closed on itself after a short freeze. I cannot find any way to solve it. anyone help?
can you help me? I have the same problem. how did you solve it at the end?
If you are specifically talking about the Windows version of Premiere, I have a solution that's worked for me on two separate computers.
Option One: Roll back your video drivers!
My work Laptop and personal laptop both use the horrendous Intel HD 530 video card in conjunction with Nvidia Quadro and GTX cards respectively. With both computers I had to search out the oldest driver I could find for the Intel video card. Once I had drivers from 2015 installed, the problem went away.
Option Two: Downgrade to Premiere 2018
This cleared up all the other problems I was having with Premiere 2019 (13). I'm sure Adobe will delete this post if I were to link directly to the instructions on how to do this, but if a cat were to walk across your keyboard and accidentally type "Premiere Project Downgrader" into Google you would be pleasantly surprised.
NB: This guide details how to move Premiere Pro project files between different product versions, if/when you have no other options:
Are Adobe CC Files and Projects Backwards Compatible?
Hope that helps.
"Hacking" project files has been discussed many times here. No clue why any support staff would delete a post on it.
If you go to the SpeedGrade forum you'll find a thread near the top where I posted the specifics for both Mac and PC. And a guy that made an inexpensive forzoay utility app that I used a ton for auto-hacking the file both back and forward.
Of course 2018 is still available for download and you can have previous major versions installed.
Neil
