SOLVED
Creating an OAuth client for a third-party integration?
Avatar
Level 1
I'm trying to set up OAuth integration for a third-party application, but am running into a similar problem as Creating an oAuth Client - what level of access is required? -- Adobe Analytics can be selected, but the "OAuth integration" option is greyed out:
In our case, we don't have our own Adobe Analytics installation, since we would be integrating with our customers' Analytics installations. For that matter, we don't currently have an enterprise organization either, since we don't actually have any Adobe software of our own, so there is no "System Administrator" role that I'm aware of.
How can we set up an OAuth integration for a third-party application? Thanks!
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
So I chatted with a couple people internally about this, and here's what I've found:
Partners that need a more permanent authentication token for clients' Adobe Analytics accounts will need to generate a JSON Web Token. More information can be found here:
However, there's one obstacle: it's not quite ready for Adobe Analytics yet. We anticipate it will be available next month, and will be the solution moving forward.
Avatar
Employee Advisor
Your best option here would be to ask for credentials from a client who has an Analytics contract.
Avatar
Level 1
The only way to create a "third-party" integration is to ask your customer to create application credentials for you? Are there any plans to improve this?
Aside from a poor developer experience, it creates a problematic coupling -- what happens if that customer relationship ends? I imagine it could elicit concerns from the client as well, since the application is outside of their organization.
(It seems like it would be useful to support the delegation of authority across organizational boundaries.)
Avatar
Level 1
Alternatively, are you suggesting that we should create a separate application with independent credentials for each client that has an Analytics contract? (This seems like it would defeat the purpose of OAuth.)
Avatar
Correct answer by
Employee Advisor
Avatar
Level 1
Any news about that?
I'm trying to use the Service Account Integration with Adobe Analytics and it doesn't work yet
Is there any date planned?
