Since updating to the latest on Windows 10, when I go to put text in the sequence I no longer have a cursor nor can see the outline of the text like I used to. Also, I can't make masks with the pen tool nor see the outline of the mask if I choose the rectangle. Has anybody else encountered this?
Are you using windows scaling? Apparently not a problem in 2018, but there is in 2019.
See this thread:
Re: Bounding Box Disappears Essential Graphics with Version 2019
See this thread:
Yup, that must be it. I'm at 125%... Geez. They broke it again.
The 13.0.1 update is out, and one fix is regarding windows scaling. I don't know if it affects this or not.
I have not installed yet, but when I have, I'll test for the disappearing text bounding box. I'll have to try your mask issue also.
Installed PR CC 13.0.1. Set scale to 125%. I have bounding boxes for text. I could consistently see this problem, so appears fixed. I selected a clip and in effects controls under opacity used pen tool to create mask and selecting rectangle, could create and edit a mask. See what you find.
