Jag har problem med långsam dator och tänkte avinstallera något program. Såg att Acrobat DC tar 16,3 Gb (Gigabyte!!) i datorn. Det kan väl inte vara möjligt? Tom Photoshop tar ungefär 1,09 Gb och det är ett ganska stort program.
Tacksam för goda råd om vad jag ska göra.
Hi mariab,
Sorry for the delay in response.
Acrobat DC usually takes 4.5GB of available hard-disk space. Please refer: Adobe Acrobat system requirements, supported platforms
Also, please check the response in the following forum thread at post#11:
How do you reduce the installed size of Acrobat Pro XI on Windows after updates?
You may also visit the following forum threads discussing the similar issue:
...Copy link to clipboard
On my computer Acrobat takes about 1.4GB... Maybe you have a bunch of temporary files saved in it or something like that?
Also, the size of the application folder has nothing to do with your computer running slowly, unless your HD is completely full.
Where do you see the 16.3 GB ?
In the control panel (or whatever it is called in English ) . If I look at the list of programs i could see that acrobat DC took 16.3 Gb
So I uninstalled it. Havent reinstalled it again yet
The size informations in this tool are not correct.
But how do I know that?
Find the application's folder (probably something like C:\Program Files (x86)\Adobe\Acrobat DC), right-click it and go to Properties.
It will let you know the size of the entire folder. Now, that's not the full application (there are some other folders with user data), but it's most of it.
Hi mariab,
How much disk space does your Acrobat installation take?
Adobe Acrobat Pro DC uses 45 GB of system memory!
Let us know if you have any query.
Shivam
