I've been trying to make an Adobe AIR app open a PDF using File.openWithDefaultApplication() but it appears to be not compatible with iOS. (works on Desktop no worries). Is there a way to get a PDF to be opened with the users default reader (e.g. iBooks, Adobe Reader etc).
I've had a check through the documentation and I think I must be looking in the wrong place
Ok so I was able to get the app to interface with the iOS Share mode. Creating a PDF seems to work but copy to iBooks does not
I used the following ANE which is not listed on the ANE directory on the Adobe site but appears to work no problems
GitHub - katopz/ane-device-file-util: ANE 64-bit for open file with registered application on iOS
Make sure you are running the newest version of iOS and AIR SDK
Big thanks to JoãoCésar for his help
So what you first need to do is create an actionscript 3.0 document, this will verify that computer can handle what you'd really enjoy doing. Has that been done? Yes? Good, now go over to the issue and see if it has been fixed, if it hasn't then don't worry it will be fixed sooner than you can spell "ApplicationDirectory". Now go over to the applicationdirectory, right click, go to "properties" click "edit" and check the box that says "allow opening of pdf" If the checkbox isn't there it is because you may be running on the wrong version, you need the updated version to be able to see the checkbox. So to update your device go into "settings" click on "verify device" and it will tell you if you need to update which of course, the answer is yes. So click on "update" and go back to the applicationDirectory. There you go!
This is not for ActionScript or iOS
I've found some success with Adobes DataShare ANE. I will continue to update this post with what I come up with
https://www.adobe.com/devnet/air/articles/datashare-native-extension.html
Hi.
The last time I needed to load PDFs on mobile devices using AIR I soon found out that these app stores are becoming each time more restrictive.
What worked for me was to load the PDFs inside of a web view using a service like Google Drive.
I'm not sure if this is what you want or if this is gonna work but I think it's worth trying or maybe at least considering this method as a future alternative.
Also, I don't have a iOS device right now to test the code. I only tested on my PC desktop and on my Android phone.
AS3 code:
import flash.geom.Rectangle;
import flash.events.Event;
import flash.media.StageWebView;
import flash.system.Capabilities;
const GOOGLE_DRIVE_VIEWER:String = "https://drive.google.com/viewerng/viewer?embedded=true&url=";
var webView:StageWebView;
function loadPDF(pdfURL:String, area:Rectangle = null):void
if (!area)
area = new Rectangle(0, 0, stage.stageWidth, stage.stageHeight);
webView = new StageWebView(true);
webView.stage = stage;
webView.addEventListener(Event.COMPLETE, function(e:Event):void
webView.viewPort = area;
e.currentTarget.removeEventListener(e.type, arguments.callee);
webView.loadURL(isMobile() ? GOOGLE_DRIVE_VIEWER + pdfURL : pdfURL);
function isAndroid():Boolean
return (Capabilities.version.substr(0,3) == "AND");
function isIOS():Boolean
return (Capabilities.version.substr(0,3) == "IOS");
function isMobile():Boolean
return (isAndroid() || isIOS());
loadPDF("http://joaocesar.000webhostapp.com/adobe/test/test.pdf");
FLA download:
animate_cc_as3_load_pdf_using_google_drive.zip - Google Drive​
JC
Thanks João
I will see if I can adapt it to work on iPad. if it works then mission complete.
I was also looking at an ANE but it appears to have issues with compiling
