Hi all,
I've got this weird problem. My Premiere CC 2018 is eating up all of my RAM. I'm working with a simple timeline; just 3 layers of video GH4's 4K 100Mbit Footage. (not playing simultaneously) and two audio tracks.
Whenever I jump through my timeline - for i.e. when I'm looking for a specific shot - my RAM usage skyrockets to the maximum value (32GB) which causes Premiere to drastically lag. It takes about 5 seconds to load before I can resume playback. Sometimes it even completely freezes up which makes me have to force quit the program. It's really annoying me because I've invested in a very high-end system to avoid this hassle and stress...
I've already cleared my cache.
My system:
CPU: Intel® Core™ i9-7980XE (2,6 GHz) OC'd @ 4GHz
Memory: 32 GB Corsair VENGEANCE DDR4 3600MHz (4 x 8 GB)
SSD: 500 GB Samsung 860 EVO. -> Also the location of Premiere Pro
HDD: 2 TB SEAGATE BARRACUDA SATA-III 3,5 inch HDD, 6 GB/s, 7200 RPM -> Where my media is located
Please help me!
- Teun
Hi in preferences you can check how much ram you want to allow be used by Premiere Pro CC check it...Thanks
Hi Lambioon,
thanks for the tip. I was aware of that, however. The probolem though is that Premiere uses all of the 25GB RAM I have dedicated to the program which bottlenecks the whole system. This can’t be normaal, can it?
Hi yes you can move the limit back to any number which you like...Thanks.
Teun%20Peters,
Sorry for this. You might try creating a new project and then import this problematic project into it. Do things work better now? Please let us know.
Kevin
Hi Yes try to put into new project and let us know....thanks
I never found 32 GB adequate for Pr on my MacPro3,1. I was constantly purging RAM using the console or a RAM purging utility when I encountered the laggy behavior you describe, which was usually anytime after editing for 15 or 20 minutes. I thought it was normal, however disheartening. I've since upgraded to a MacPro5,1 with 128 GB RAM and now I don't run out.
