Hi
Attempts to send using Adobe Acrobat don't work. I have Outlook as default mail programm and it works in all application but for Adobe Acrobat Pro.
I get this error
What should I do to have Acrobat just send a PDF as attachment?
Hi theking2,
As per the issue description mentioned above, you are facing issue when trying to send pdf using outlook, is that correct?
Please try following troubleshooting steps:
1- Reboot the machine once if you haven't already and check if that helps.
2- Check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again.
3- If issue still persists, try repairing Acrobat using "Repair installation" option under Help menu, reboot the machine after repair and check.
You may also refer to the following forum threads discussing the similar issue:
https://forums.adobe.com/thread/2368246
Let us know if you need any help.
Shivam
Thanks Shivam!
That was refreshingly unhelpful
Hi theking2,
Could you confirm the dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Also, please confirm if you have tried the troubleshooting steps suggested above?
-Shivam
Betriebssystemhersteller: Microsoft Corporation
Betriebssystemname: Microsoft Windows Vista
Betriebssystemversion: 6.2.9200
BIOS-Version: ALASKA - 1072009
Gebietsschema: Schweizerdeutsch (Schweiz)
Gesamter realer Speicher: 4194303 KB
Gesamter virtueller Speicher: 4194176 KB
Grafikkarte: NVIDIA GeForce GTX 980 Ti
Version: 23.21.13.9135
Test: Nicht unterstützt
Größe der Auslagerungsdatei: 4194303 KB
Installierte Acrobat-Version: C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe
Version: 10.1.16.13
Erstellungsdatum: 2015/09/24
Erstellungszeit: 17:40:44
Monitor:
Name: NVIDIA GeForce GTX 980 Ti
Auflösung: 1920 x 1080 x 60
Bit pro Pixel: 32
Prozessor: Intel64 Family 6 Model 158 Stepping 9 GenuineIntel ~4200 Mhz
Standard-Browser:
Standard-E-Mail-Anwendung: Microsoft Outlook
mapi32.dll
Version: 1.0.2536.0 (WinBuild.160101.0800)
Erstellungsdatum: 2018/09/01
Erstellungszeit: 10:42:07
Systemname: IAPETUS
Temporärer Ordner: Y:\johannes\Temp\
Verfügbarer realer Speicher: 4194303 KB
Verfügbarer virtueller Speicher: 3974744 KB
Windows-Verzeichnis: C:\WINDOWS
Zeitzone: Mitteleuropäische Zeit
Hi theking2,
Thanks for the info. It seems you are using Acrobat X which has been declared end of life. More info here: Adobe Acrobat X and Adobe Reader X End of Support | Adobe Document Cloud.​ You may try reinstalling Acrobat on the machine and check if that helps.
-Shivam
I have the same problem. I am using Acrobat XI. I cannot send an email from within the program. Outlook is set as the default email program. I receive the following message:
"An error occurred while trying to create a mail document. Acrobat is unable to complete your request"
It is extremely frustrating as ALL prior Acrobat versions I have had worked fine. The only work around is to open Outlook, create the email and then attach the PDF from Finder. This is not helpful.
Please help.
Paul
Hi Paul,
Could you please check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. You may also download updates from here: Adobe software and product updates
If that doesn't work, please try the troubleshooting steps given in the following help document: Attach to email option is not working | Acrobat DC, Acrobat Reader DC
-Shivam
