Just upgraded to Photoshop CC 2018, used to be able to select a layer and Free Transform with handles with live redraw for placement. Now when I select a corner (to resize or rotate), it resizes the visible selection block/indicator and gives me new handles and I can't see what I'm doing, it's just a guess. This problem is happening on text and object layers. (Not using smart objects for this project).
I've tried looking through preferences and options to no avail. It's almost like area select is turned on but I deselected that long ago.
Thanks for any help.
Why not?
Could you please post a screenshot taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, …) visible?
https://forums.adobe.com/thread/963429
When you have applied a transformation destructively and »Show Transform Controls« is checked that would seem to be what is to be expected.
I've discovered it has to be an option or preference that I haven't deselected.
I recently updated at work and am not having the same problem.
It has to be auto-select has reactivated. I'm going to check it tonight. Thanks.
Im having the same problem. When I use free transform it does not show the corner boxes you usually place your curser on to move the edges.
Please read this (in particular the section titled "Supply pertinent information for quicker answers"):
What is the Photoshop version you are using?
How do you invoke the transformation?
Please post screenshots including the pertinent UI elements.
Im having the same problem. I see red circles instead of transform controllers or text selection. I tried it on layers and on simple shapes. When I try to edit text I don't see which part of the text is selected. Please see pictures below.
Any ideas how to fix this?
I was also having this problem but I think if you go to preferences > tools then un-tick the Show Reference Point when using Transform that it solves the problem.
