3 Replies Latest reply on Nov 8, 2018 5:12 AM by sr48262525
    Applescript InDesign Grep Script - Needs updating
    sr48262525
      Hi All.
      I had an applescript that was working in Indesign 2015, however, I've returned to use it with Indesign 2018 and it keeps intermittently failing.
      The script would set find / change values, search the doc and return the text found, I would then use this text to form the file name for saving.
      [applescript]
      tell application "Adobe InDesign CC 2015"
        activate
        set myFindGrep to ".+"
        set mySelectedParaStyle to "DM Product Code Split"
        set MyFoundWordsList to {}
        set find what of find grep preferences to myFindGrep
        set applied paragraph style of find grep preferences to mySelectedParaStyle as string
        set MyFoundWords to find grep
        repeat with i from 1 to count MyFoundWords
        set MyFoundWordsList to MyFoundWordsList & item i of MyFoundWords
        end repeat
        set lastInList to count MyFoundWordsList
        set mySave to (myDesktopJobFolderPath & (item lastInList of MyFoundWordsList) & ".indd")
      end tell
      [/applescript]
      I'm getting a couple of different errors on the line…
      [applescript]
      [/applescript]
      Error 1:
      [i]Can’t make text from character 1 to character 8 of story id 332 of document id 603 of application "Adobe InDesign CC 2018" into type vector.[/i]
      Error 2:
      [i]Can’t make text from character 1 to character 6 of story id 331 of document id 611 of application "Adobe InDesign CC 2018" into type vector.[/i]
      The text it's searching is just alpha/numeric codes, no special characters.
      thanks
      Shane
