Canon C200 Exporting issues
Nov 07, 2018 Nov 07, 2018
Hello,
I have recently stated working with Raw footage from the C200 and when I try to export my project, i get a drastic change in brightness of color. I have tried switching between software and my main graphics card, but no luck as far as change. I have tried updating all my drivers but still no luck. Any help is greatly appreciated. Thank you!
Exported Image:
Image in Timeline (Desired Image)
454
Community Expert , Nov 08, 2018 Nov 08, 2018
Turn off max bitdepth and render, see how that goes.
Dont need max render, you have a dedicated gpu.
Adobe Employee ,
Hi dmovie,
Sorry for the export issue. Have you tried importing the exported file back into Premiere Pro and check the colors?
What are the export settings? What are the system specs(OS, RAM, GPU, CPU)?
Vidya
Vidya. I tried importing the file like you suggested back into Premiere Pro and no difference as far as looks with it is back in timeline. Still blown out image.
My export settings are as follows:
H.264
3840x1600
23.976
Square Pixels (1.0)
NTSC
Render at Maximum Depth
Encoding Setting
Performance High
Level 6.2
Bitrate Encoding: CBR
Target Bitrate: 100
Use Maximum Render Quality
Machine specs are:
Windows 10 64-bit
2x16gb DDR4 HyperX
MSI Geforce GTX 1080
i9 7900x
Do you seen any difference when using Export or Queue in Pr?
Ann. I did try it both through export and Queue and still same result.
Another update. I tried to do the same thing just now on my Macbook Pro and still same result. It looks fine in timeline but is blown out when exported.
That seemed to fixed the issue. I ended up download Premiere 12.1 and imported an xml to get the project done. However, just tested your suggestion and that seem to take care of it. Thanks Ann!
