I recently updated to Bridge 2019. It worked for about a day. Then it started crashing on launch every time. I went back to Bridge 2018, which also now crashes on launch. I've tried uninstalling, reinstalling, restarting, clearing preferences, clearing cache. Does anyone have any additional suggestions?
Hi there,
Sorry to hear about Bridge crashing, could you please let us know what operating system you're working?
The issue might be related to permissions, could you try creating a new user account on the computer and try launching Bridge on that account?
Sahil
A bit of an update: If I restart my Mac, Bridge usually crashes, but if I restart a few times, sometimes it doesn't crash. So it's not crashing 100% of the time, just about 90%.
OS Version: Mac OS X 10.13.6 (17G65)
I also have 2 external monitors in addition to my Macbook. This worked fine for Bridge 2018, but I know it has been an issue in the past.
I can create a user account, which is a long setup on a Mac. Should this be admin or standard? I run Bridge from an admin account.
I'm not sure if this info helps:
Time Awake Since Boot: 57 seconds
System Integrity Protection: enabled
Crashed Thread: 18 Mondo Worker
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
And this seems to have helped... Bridge CS5 crashes when opening
But when I closed and relaunched it crashed again... When I checked the folder, it was set back to read only...
Users/ [user] /Library/Application Support/Adobe/Bridge CS5 /
And back to crashing...
Still crashing. I tried downgrading today to version 9.0.0.204 --- I'll wait a few months and see if there is a more stable version.
Currently both Bridge 2018 and Bridge 2019 crash on my Mac immediately after launch. No solution I know of.
So I've been able to (possibly) isolate some of the problem. I've started a new thread with a more meaningful title: Bridge crashes with large collections
