Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Add Watermark is not working in AEM 6.4
Avatar
Former Community Member
Hi Experts,
We are applying the watermarking as per below Link:
Watermarking
But getting the below error:
com.adobe.granite.workflow.WorkflowException: Process execution resulted in an error
at com.adobe.granite.workflow.core.job.HandlerBase.executeProcess(HandlerBase.java:204)
at com.adobe.granite.workflow.core.job.JobHandler.process(JobHandler.java:261)
at org.apache.sling.event.impl.jobs.JobConsumerManager$JobConsumerWrapper.process(JobConsumerManager.java:502)
at org.apache.sling.event.impl.jobs.queues.JobQueueImpl.startJob(JobQueueImpl.java:293)
at org.apache.sling.event.impl.jobs.queues.JobQueueImpl.access$100(JobQueueImpl.java:60)
at org.apache.sling.event.impl.jobs.queues.JobQueueImpl$1.run(JobQueueImpl.java:229)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.adobe.granite.workflow.WorkflowException: Failed to execute process
at com.day.cq.workflow.compatibility.CQWorkflowProcessRunner.execute(CQWorkflowProcessRunner.java:108)
at com.adobe.granite.workflow.core.job.HandlerBase.executeProcess(HandlerBase.java:194)
... 8 more
Caused by: com.day.cq.workflow.WorkflowException: com.day.cq.dam.commons.watermark.WatermarkingException: Unable to create layer from asset image
at com.day.cq.dam.core.process.WaterMarkProcess.execute(WaterMarkProcess.java:162)
at com.day.cq.workflow.compatibility.CQWorkflowProcessRunner.execute(CQWorkflowProcessRunner.java:93)
... 9 more
Caused by: com.day.cq.dam.commons.watermark.WatermarkingException: Unable to create layer from asset image
at com.day.cq.dam.core.process.WaterMarkProcess.execute(WaterMarkProcess.java:142)
... 10 more
Can you help us and guide us like what may be the cause.
Samer
1 Accepted Solution
Avatar
Correct answer by
Level 10
Workaround is using the Java ImageIO (Java Platform SE 7 )  API.
Write a custom Watermark step and pass the Asset Inputstream to these methods. It will apply a watermark to the workflow payload.
Avatar
Level 10
I will test this one my end. I also reached out to the team with this issue.
Avatar
Level 10
I am seeing the same issue here.
Avatar
Level 10
I have coded a workaround for this - it works. Notice the watermark below.
Avatar
Correct answer by
Level 10
Avatar
Thanks Scott.
Can you share your sample to me if possible at my email ID sameryadav@gmail.com. So that quickly we can check at our end.
Samer
Avatar
Employee
Hi, I tried workflow steps https://helpx.adobe.com/experience-manager/6-4/assets/using/watermarking.html and it worked for me. note few points: - By default opacity is 20 so to check increase this to say 80-90 and increase font size. - Try on small image may be 640*480 to see it on test server. I tried and it works fine for me. Thanks
Avatar
Hi Gaurav,
Can you check for .tif and .psd file?
Samer
Avatar
Employee
Hi Sameer, This is mentioned in the doc "AEM Assets supports text to be used as a watermark to watermark the web-renderable image formats, such as GIF, PNG, JPEG, and BMP." Thanks
Avatar
Level 2
I'm working on watermarking Image files. I'm only able to watermark png and jpeg files. watermark didnot apply on .bmp and gif.
Am I missing any configuration?
Avatar
Level 1
I am also facing the same issue. Have you got any resolution for this ?
Thanks and Regards,
Gajanan
