Hello I hope you can help with this all four cameras are Iphone and they are the same frame rate and resolution but for some reason one of the cameras come out as smaller in the multi camera sequence. All help is greatly appreciated.
I presume you have checked the file properties in the Project panel to make sure PrPro is interpreting that properly?
If it isn't reimport the clip.
If it is, go to the clip on the sequence, right click, and make sure scaling is set to 100% in the ECP.
Neil
Hello Neil
Thank you for the reply. It would seem that I have recorded it in the wrong size. The file is still in my computer. I don’t know how to import it in the same size, sorry I am new to this.
If you recorded it smaller that can be a problem. Up-scaling an image that much would be probably easy to see in a video cutting between clips.
You may need to either reshoot or if you can't, choose to use a sequence sized for the smaller clip, and have PrPro set to the Preferences option "Set to frame-size". That way the other clips will drop in correctly to show the full clip in the smaller sequence frame-size.
You may be looking at the central area of those clips in the multi-cam view in the monitor but in normal view they'll look fine.
You even would have the option to "zoom in" on those clips in editing after finishing the multi-camera cutting.
So if the smaller clip is 1080 and the others 4k, use a 1080 sequence matching the clip. Or a 720 sequence if it is in 1280x720.
Neil
I was thinking I could export the file that I have and match the settings. Can’t seem to see the corresponding figures
