3 Replies Latest reply on Nov 10, 2018 1:43 PM by Laubender
    Add comand Context Menu on image.
    Cris Ider Level 1
      Hi!
      My english is in progress, so I will try make a question about my problem.
      I use Indesign CS5 - Windows 7 64bits.
      I need a script or plugin to right click button on image, it appears the file name info in context menu.
      I know there is a link panel. But I need this in context menu.
      Is it possible?
      Thanks, anyway!
        • 1. Re: Add comand Context Menu on image.
          Laubender Adobe Community Professional & MVP
          Hi Cris,
          yes. The context menu is scriptable. That needs a startup script.
          And a selected image or the selected frame where the image is placed can be asked for the file name.
          But why do you think you'd need a script for this?
          Have the Links panel open and you get the information right away.
          Uwe
          • 2. Re: Add comand Context Menu on image.
            Another way to get the file name would be to use a function that is already in the context menu:
            Create Static Caption *
            The default would be the creation of a text frame holding the name.
            * Hm. That's a new function with InDesign CS6, I think. You are talking about CS5.
            Sorry.
            Uwe
            • 3. Re: Add comand Context Menu on image.
              Another idea:
              Without using a startup script with an event listening mechanism one could get the name of a selected image by invoking the Script Label panel. Before invoking the Script Label panel a script that you can start from the Scripts panel or by doing a keyboard shortcut would write the name as label to the selected object.
              You would have immediate access to the name and could copy it from the Script Label panel.
              I am accessing this script through the keyboard shortcut Strg + # on my German keyboard.
              For that I did a special keyboard shortcut set.
              I think, that's more useful than showing the name in the context menu.
              Uwe
