6 Replies Latest reply on Nov 12, 2018 10:58 AM by S Hopkins
    Move objet below the text line
    franz joelv69400054 Level 1
      I need help, I'm a novice in javascript, but I like to automate my query is after pasting the object into the text line, it is possible to move the same height of the object down and after apply textwrap
      in this way
      Thanks for your help
        • 1. Re: Move objet below the text line
          S Hopkins Adobe Community Professional
          Rectangle that holds placed image has a number of properties that are part of the anchoredObjectSettings. The following snippet may help. This where placedRef is a reference to the placed object and ancSettings is the anchored settings property record. You will need to set other properties to control the horizontal settings.
          var yOffset = "10pts";
          var placedRef = insRef.place(myFile);
          var imageRef = placedRef[0];
          var rectRef = imageRef.parent;
          var ancSettings = {anchoredPosition:AnchorPosition.ANCHORED,
              anchorPoint:AnchorPoint.TOP_LEFT_ANCHOR,
              verticalReferencePoint:VerticallyRelativeTo.LINE_BASELINE,
              verticalAlignment:VerticalAlignment.TOP_ALIGN,
              anchorYoffset:yOffset};
          rectRef.anchoredObjectSettings.properties=ancSettings;
          Hope this helps
          1 person found this helpful
          • 2. Re: Move objet below the text line
            Hi S Hopkins thanks for your help,the script is great but I would like the image to be kept within the text line and not as an anchored object.
            • 3. Re: Move objet below the text line
              Oops, that's what we get for assuming. Maybe the following will help:
              To move a page item relative use the move method with undefined:
              app.scriptPreferences.measurementUnit = MeasurementUnits.POINTS;
              rectRef.move(undefined, [0, 72]); //moves item vertically 72 points
              To move a page item given a specific measurement use move without undefined.
              To calculate the position of the item relative to the last line of a paragraph, use the line's baseline property
              var yOffset = 36;
              var bLine = myPage.textFrames[0].paragraphs[0].lines[-1].baseline;
              //Baseline includes the top margin, so you need to subtract that:
              var marTop = myPage.marginPreferences.top;
              bLine = bLine - marTop;
              var x0 = rectRef.geometricBounds[0];
              var yPosition = bLine + yOffset;
              rectRef.move([x0,yPosition]);  //moves item to page position 36 points below referenced paragraph
              • 4. Re: Move objet below the text line
                I appreciate your help but only position the first image correctly, and how to make the yOffset variable capture the value of the height of the selected object, something like yOffset=app.selection [0].height
                var yOffset = 123.405;
                var rectRef=app.selection[0]
                var myPage=app.activeWindow.activePage;
                rectRef.textWrapPreferences.textWrapMode =TextWrapModes.JUMP_OBJECT_TEXT_WRAP;
                • 5. Re: Move objet below the text line
                  payalm68947498 Level 2
                  Hi Franz,
                  var AncFrame = app.documents[0].pages[0].textFrames.add();
                  AncFrame.place("ImagePath+ImageName");
                  AncFrame.textWrapPreferences.textWrapMode =TextWrapModes.jumpObjectTextWrap;
                  • 6. Re: Move objet below the text line
                    Not too sure what you mean by "selection"; hopefully you mean the last-placed image.
                    The following places images from an array below the first paragraph of the page. They will be placed 200px from the left and left aligned with 8 pts gap (space) between:
                    var placedItem, imageRef, rectRef, gBounds, yPos, x0;
                    var yOffset = 36; //gap below first paragraph
                    var yGap = 8; //gap between images
                    var x0=200;
                    var myFiles = getFile ("Choose files", "*.png", true);
                    var myPage = app.documents[0].pages[0];
                    yPos = (bLine + marTop) + yOffset;
                    for (i=0; i<myFiles.length; i++){
                    placedItem = myPage.place(myFiles[i]);
                    imageRef = placedItem [0];
                    gBounds = rectRef.geometricBounds;
                    rectRef.move([x0,yPos]);
                    yPos = yPos + (gBounds[2]-gBounds[0] + yGap);
                    function getFile (filePrompt, typeFilter, useMultiple) {
                    var fileRef = File.openDialog(filePrompt, typeFilter, useMultiple);
                    if (fileRef==null) {
                        throw ("User cancelled");
                        } else {
                            return fileRef;
                    This should give you something to play with.
