Adobe Acrobat X Pro does not open!
Nov 10, 2018 Nov 10, 2018
Ho dovuto riformattare il disco rigido. Ho reinstallato tutti i programmi, anche Adobe Design and Web premium CS6. Da allora non mi è possibile di aprire Acrobat X Pro. Uso Windows 10.
Ma perché non si apre più e prima della formatazione ha funzionato benissimo?
Vi ringrazio anticipatamente per una risposta
Barbara
General troubleshooting
670
Adobe Employee , Nov 14, 2018 Nov 14, 2018
Hi Barbara,
As mentioned above, Acrobat X is incompatible with Windows 10, problems with it are to be expected. You may visit the following help document for the same: Older versions of Acrobat (XI, X, 9) system requirements
You may try running Acrobat in compatibility mode for windows 7 using the steps mentioned above which worked in some cases.
Let us know if you need any help.
Shivam
Adobe Employee ,
Nov 12, 2018 Nov 12, 2018
Hi Barbara,
As per the issue description mentioned above, Acrobat X doesn't open on a Windows 10 machine, is that correct?
Acrobat X is end of life and not supported on Windows 10. Adobe Acrobat X and Adobe Reader X End of Support | Adobe Document Cloud  Older versions of Acrobat (XI, X, 9) system requirements
You may try running Acrobat in compatibility mode using the steps given below. It may or may not work.
Locate Acrobat icon on the desktop > right-click > Properties
Compatibility tab > run this program in compatibility mode for > select windows 7
Shivam
Hi Shiwam
No, it's not correct. Bevore I had to add a new hard disc, I used the same Windows 10 version, how I use now and Acrobat was working very well. All other Adobe CS6 programs are working good.
Thank you for replay
Barbara
Adobe Employee ,
Hi Barbara,
Shivam
