Hi. All of a sudden the signature fails to embed. The dialogue box come up and I can make changes but when I export the signature is not there.
I've tried to update but get an error saying I need to close LR and then click continue but when I close LR the dialogue box with the continue button closes. I've tried all the different ways to close down LR but the result is the same.
Cheers
Go and edit your watermark, make sure nothing has gone bonkers with it.
Also, more than one watermark saved? Using the correct one?
Are you asking about Watermarks and the watermark editor window?
Some fonts aren't supported even though they may work with other programs. Try changing the font to something generic and test.
Yes. I'm referring to the watermark feature. I have a graphic which is set up as a preset. I've been using this for a couple of years.
The watermark check mark in the export panel is on.
Make sure the correct watermark is selected. Just checking the box, having that box checked, means nothing without making the correct selection of which watermark to use.
Are you talking about a watermark?
Yes. The watermark.
Thanks David. That was good advice. I went into the watermark editor to see if anything had gone "bonkers" and found that I had gone bonkers instead. I'd changed the name of the folder containing my watermark JPEGS the other day without realizing the consequences.
All good now Thanks.
