Is there any way to move the time indicator of timeline to first frame of the layer using Photoshop script?
Jun 11, 2018 Jun 11, 2018
Currently, I am using following script to move time indicator between keyframes.
function next_key_frame() {
var d1 = new ActionDescriptor();
var d2 = new ActionDescriptor();
d2.putEnumerated( stringIDToTypeID( "trackID" ), stringIDToTypeID( "stdTrackID" ), stringIDToTypeID( "opacityTrack" ) );
d1.putObject( stringIDToTypeID( "trackID" ), stringIDToTypeID( "animationTrack" ), d2 );
executeAction( stringIDToTypeID( "nextKeyframe" ), d1, DialogModes.NO );
function prev_key_frame() {
    executeAction( stringIDToTypeID( "previousKeyframe" ), d1, DialogModes.NO );
But Now, I want to move the time indicator from 0th frame to the first frame of the Layer 2 directly using Photoshop script. Is there any way to do this?
To:
Actions and scripting
3.1K
Adobe
People's Champ ,
I have never worked with animation or timeline. But if you provide a simplified file with layers and your animation, I can try to do what you need if it works and I will have time for it.
Jun 12, 2018 Jun 12, 2018
scene.psd - Google Drive
r-bin this the animation file
People's Champ ,
OK. Not enough time to analyze. Here is a simplified script (only for CC2018 (2015.5 +)
Make the layer Layer2 activeLayer and run the script.
The script moves the frame from zero until the "Free Transform" command becomes available. This is the appearance time of the Layer2 layer
var d = new ActionDescriptor();
var r = new ActionReference();
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("time"));
r.putClass(stringIDToTypeID("timeline"));
d.putReference(stringIDToTypeID("null"), r);
d1.putInteger(stringIDToTypeID("seconds"), 0);
d1.putInteger(stringIDToTypeID("frame"), 0);
d1.putDouble(stringIDToTypeID("frameRate"), 30);
d.putObject(stringIDToTypeID("to"), stringIDToTypeID("timecode"), d1);
executeAction(stringIDToTypeID("set"), d, DialogModes.NO);
var cycle_cnt = 0;
while (cycle_cnt < 1000)
    next_frame();
    if (is_transform_enabled()) break;
    ++cycle_cnt;
function next_frame()
    try {
        d.putBoolean(stringIDToTypeID("toNextWholeSecond"), false);
        executeAction(stringIDToTypeID("nextFrame"), d, DialogModes.NO);
    catch (e) { throw(e); }
function is_transform_enabled()
    r.putEnumerated(charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
    d.putReference( charIDToTypeID( "null" ), r );
    d.putString (stringIDToTypeID("command"), "getCommandEnabled");
    d.putDouble(stringIDToTypeID("commandID"), 2207 );
    var ret = executeAction(stringIDToTypeID("uiInfo"), d, DialogModes.NO).getObjectValue(stringIDToTypeID("result")).getBoolean(stringIDToTypeID("enabled"));
    return ret;
Thanks a lot r-bin.
The script is works on Photoshop 2017 CC. But I want to use this script on Photoshop 2014 CC, 2015.5 CC and 2017 CC.
Is there any way to get the offset frames count directly using script?
If it is possible, we can easily move the indicator to start frame of the layer using following script.
function gotoFrame(frame) {
    var desc1 = new ActionDescriptor();
    var ref = new ActionReference();
    ref.putProperty(charIDToTypeID('Prpr'), stringIDToTypeID('time'));
    ref.putClass(stringIDToTypeID('timeline'));
    desc1.putReference(charIDToTypeID('null'), ref);
    var desc2 = new ActionDescriptor();
    desc2.putInteger(stringIDToTypeID('frame'), frame);
    desc1.putObject(charIDToTypeID('T  '), stringIDToTypeID('timecode'), desc2);
    executeAction(charIDToTypeID('setd'), desc1, DialogModes.NO);
gotoFrame(offset_frames_count - 1);
I have moved the timeline of the layer 2
to:
Above action generated following script via script listener
var idmoveAllTime = stringIDToTypeID( "moveAllTime" );
var desc8 = new ActionDescriptor();
var idtimeOffset = stringIDToTypeID( "timeOffset" );
var desc9 = new ActionDescriptor();
var idseconds = stringIDToTypeID( "seconds" );
desc9.putInteger( idseconds, 1 );
var idframe = stringIDToTypeID( "frame" );
desc9.putInteger( idframe, 29 );
var idframeRate = stringIDToTypeID( "frameRate" );
desc9.putDouble( idframeRate, 30.000000 );
var idtimecode = stringIDToTypeID( "timecode" );
desc8.putObject( idtimeOffset, idtimecode, desc9 );
executeAction( idmoveAllTime, desc8, DialogModes.NO );
Can we modify above code to get Offset time or frames?
People's Champ ,
Jun 13, 2018 Jun 13, 2018
OK. Here is the version that works even in CS6.
Replace the function is_transform_enabled() with this one.
    try { activeDocument.activeLayer.resize(100); } catch(e) { return false; }
    return true;
PS.Although all this is very stupid.
Now there is no way to get information about animation using scripts.
Photoshop allows you to change many parameters, but does not allow them to read.
This applies not only to animation.
Still there is a variant to read the data directly from the PSD file.
But it takes time to sort it out and I'm not sure that it is necessary and convenient.
Jul 11, 2018 Jul 11, 2018
I have tried is_transform_enabled()  function in Photoshop CC 2015.5 and 2017.
It gives following popup error message.
Is there any way to avoid this message box?
People's Champ ,
Unsuccessful way. But to remove this error you need to do this way
    app.displayDialogs = DialogModes.NO;
    return true;
Jul 16, 2018 Jul 16, 2018
Thank you r-bin
Doesn't this effect on the size of the layer ( Eg:- a Smart object which resized to 50%)
People's Champ ,
Do not quite understand. For a smart object, it also works and does not change its actual size regardless of its real scale.
By the way, you can use this variant as well
activeDocument.activeLayer.resize();
Guide ,
Brilliant work br r-bin​ and a spin off from the routine is that you can get the frame number if you need it for further processing...
var cycle_cnt = 0;
var currentFrame = 0;
    next_frame();
    currentFrame++;
    ++cycle_cnt;
alert(currentFrame);
Trying to get the frame number direct will only return 0-30 (framerate)
People's Champ ,
It is possible and so, if I understood correctly )
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("currentFrame"));
alert(executeActionGet(r).getInteger(stringIDToTypeID("currentFrame")));
Guide ,
Thank you I had missed that!
I was just testing a binary chop approach to see if was any faster....
main();
function main(){
//set to end using huge numbers
setToFrameAndTime(20000, 20000, 30);
var FC = getCurrentFrame();
MAX = FC;
MIN = 0;
while( (MAX - MIN) >1){
F = Math.floor(((MAX - MIN)/2)+MIN);
gotoFrame(F);
var result = isActive();
if(result){
    MAX=F;
    }else{
        MIN=F;
gotoFrame(MAX);
alert("Frame No: " + getCurrentFrame());
function isActive(){
try {activeDocument.activeLayer.resize(100); } catch(e) { return false; }
return true;
function getCurrentFrame(){
return executeActionGet(r).getInteger(stringIDToTypeID("currentFrame"));
function setToFrameAndTime(seconds, frame, frameRate){
d1.putInteger(stringIDToTypeID("seconds"), seconds);
d1.putInteger(stringIDToTypeID("frame"), frame);
d1.putDouble(stringIDToTypeID("frameRate"),Number( frameRate));
The following method will allow you to move the time indicator to a specific place, but I couldn't figure out how (via script or the GUI) to grab the timestamp of a particular key frame. If you know how to do that it should be easy to then use the method below for the purpose you described (I don't know if PS provides that functionality or not).
As r-bin mentioned, if you provided a sample .psd file it might help.
#target photoshop
setTimelineTime(2, 25, 30);
function setTimelineTime(seconds, frame, frameRate) {
    var timelineReference = new ActionReference();
    timelineReference.putProperty( s2t( "property" ), s2t( "time" ));
    timelineReference.putClass( s2t( "timeline" ));
    var timeDescriptor = new ActionDescriptor();
    timeDescriptor.putInteger( s2t( "seconds" ), seconds );
    timeDescriptor.putInteger( s2t( "frame" ), frame );
    timeDescriptor.putDouble( s2t( "frameRate" ), frameRate );
    var timelineDescriptor = new ActionDescriptor();
    timelineDescriptor.putReference( c2t( "null" ), timelineReference );
    timelineDescriptor.putObject( s2t( "to" ), s2t( "timecode" ), timeDescriptor );
    executeAction( s2t( "set" ), timelineDescriptor, DialogModes.NO );
function c2t (c) {
    return app.charIDToTypeID(c);
function s2t (s) {
    return app.stringIDToTypeID(s);
People's Champ ,
For your file there is a solution provided that the Layer2 animation ends no later than the animation of the other layers
Works even in CS6.
//if (get_curr_frame()) runMenuItem(stringIDToTypeID("timelineGoToFirstFrame")); // bad variant
goto_frame(0);
var x1 = get_frame_count();
runMenuItem(stringIDToTypeID("timelineMoveLayerInPoint"))
var x2 = get_frame_count();
executeAction(charIDToTypeID("undo"), undefined, DialogModes.NO);
goto_frame(x1-x2);
function get_curr_frame()
function get_frame_count()
    r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("frameCount"));
    return executeActionGet(r).getInteger(stringIDToTypeID("frameCount"));
function goto_frame(f)
    d1.putInteger(stringIDToTypeID("frame"), f);
PS. In general, it is necessary to duplicate the document. Delete all layers in it except activeLayer. Run the script to get (x1-x2). And in the original document do positioning on the frame (x1-x2).
I have not found the best yet.
Nov 07, 2018 Nov 07, 2018
Thanks r-bin​  for that excellent suggestion.    Unfortunately when dealing with longer videos,  moving through each frame to check for the enabled transforms is very slow.   it works!  but trying to come up with something faster.
Any other suggestions on how to locate the start time position of a layer in the timeline panel?
I've been digging around in the descriptors and just can't find anything.
The only other option I can think of is to add an event watcher,  and track the position of the layer as moveInPoint, moveOutPoints and moveAllTime events happen... but that seems so overly complicated when I just need to extract that number that I know Photoshop knows already.  Reaching out to community for suggestions.
People's Champ ,
Nov 08, 2018 Nov 08, 2018
I know almost nothing about animation and I don’t use it.
But the proposed method can be significantly accelerated by doing so.
var max_frame = executeActionGet(r).getInteger(stringIDToTypeID("frameCount"));
var step = max_frame/2;
var frame = Math.round(step);
var end_cnt = 0;
while (1)
    goto_frame(frame);
    step = Math.round(step/2);
    if (is_transform_enabled()) { if (step == 1) break; frame -= step; }
    else frame += step;
    if (step <= 1) ++end_cnt;
    if (end_cnt > 2) break;
function goto_frame(n)
    try {
        d1.putInteger(stringIDToTypeID("frame"), n);
function is_transform_enabled() // version for CS6
    return true;
But I do not guarantee that it does exactly what you want. 🙂
Thanks!  I'll give it a try!
People's Champ ,
Nov 11, 2018 Nov 11, 2018
For a high-quality script, you need a full-fledged algorithm for parsing a psd file.
This simple script does not do this, but it works (in CS6 too).
Check.
You can uncomment lines for positioning to Layer outTime.
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("layerID"));
r.putEnumerated(stringIDToTypeID("layer"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
var layer_id = executeActionGet(r).getInteger(stringIDToTypeID("layerID"));
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("frameRate"));
r.putEnumerated(stringIDToTypeID("timeline"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
var frame_rate = executeActionGet(r).getInteger(stringIDToTypeID("frameRate"));
var file = activeDocument.fullName;
activeDocument.save();
file.open("r");
file.encoding = "BINARY";
var len = file.length;
if (len > 200000) len = 200000;
var buff = file.read(len);
file.close();
while(1)
    var n = buff.indexOf("8BIMtmln");
    if (n >= 0)
        d.fromStream(buff.substr(n+16))
        if (layer_id == d.getInteger(stringIDToTypeID("layerID")))
            var n1 = d.getObjectValue(stringIDToTypeID("timeScope")).getObjectValue(stringIDToTypeID("inTime")).getInteger(stringIDToTypeID("numerator"));
            var n2 = d.getObjectValue(stringIDToTypeID("timeScope")).getObjectValue(stringIDToTypeID("inTime")).getInteger(stringIDToTypeID("denominator"));
            //var n1 = d.getObjectValue(stringIDToTypeID("timeScope")).getObjectValue(stringIDToTypeID("outTime")).getInteger(stringIDToTypeID("numerator"));
            //var n2 = d.getObjectValue(stringIDToTypeID("timeScope")).getObjectValue(stringIDToTypeID("outTime")).getInteger(stringIDToTypeID("denominator"));
            var frame = n1/n2*frame_rate;
            d1.putDouble(stringIDToTypeID("frameRate"), frame_rate);
            break;
        buff = buff.substr(n+8);
    else
        alert("ActiveLayer TimeLine not found");
        break;
edit: Fixed the script
Participant ,
Nov 12, 2018 Nov 12, 2018
ohh.. you got good magic there - I wasn't familiar with the "timeScope" key. But unfortunately it doesn't seem to be working for me.   (tested in CC2017 and CC2019)  Very interesting how you're able read the file into a stream buffer though,  good trick.
Thanks for the suggestion on post #16, ... I was starting to work on something similar where I hop around and check for a menu enabled.  ... but it wasn't as clean as your code. very appreciated.
People's Champ ,
Nov 13, 2018 Nov 13, 2018
OK. This is most likely a very large file. Here, try a script with a normal parser. Works in CC2018. Checked!
The file format must be PSD or PSB.
eval("@JSXBIN@ES@2.0@MyBbyBnACMCbyBn0ABgEbyBn0AFJFnASzDjMjFjOBAXzGjMjFjOjHjUjICfVzBjTDfEnftJHnASzEjNjVjMjUEBndBftJInASzDjSjFjUFCndAftKKbMn0ACJMnASFCCzBhLGnCzBhKHEXzKjDjIjBjSiDjPjEjFiBjUIfVDfERBVzBjJJfDffVEfBnnnnntfJNnASEBCHnnnd2ABntfASJDCzBhNKVBfAnndBnftCzChehdLVJfDnndATJDyBtZQnAVFfCABnzBjFMnbyBn0ABJSnAEjzFjBjMjFjSjUNfRBj"+
"MfffAFJ4D0AiAD40BhAE4B0AiAB40BiAF4C0AiABEAzLjHjFjUifjJjOjUjFjHjFjSOATMWbyBn0ABgYbyBn0AEJZnABXzEjOjBjNjFPfezEjUjIjJjTQfneKiQiTiEhAiQjBjSjTjFjSfJgbnABXzDjEjPjDRfeQfnbfJgcnABXzEjGjJjMjFSfeQfnbfOgebyhAn0ABgyhAbyBn0ACJhAnABXSfeQfXzIjGjVjMjMiOjBjNjFTfVSfAnfJyhAnABXRfeQfVSfAnfABnMnbyBn0ABJyhAnAEjNfRDFeXiEjPjDjVjNjFjOjUhAj"+
"OjPjUhAjZjFjUhAjTjBjWjFjEhBXPfeQfFctffACzKjJjOjTjUjBjOjDjFjPjGUVSfAjzIiEjPjDjVjNjFjOjUVfnnOhCbyhEn0ABJhEnABXSfeQfVSfAnfACUVSfAjzEiGjJjMjFWfnnnABnMnbyBn0ABJhHnAEjNfRBjMfffABS40BhAB0AzKiQiTiEifiQjBjSjTjFjSXAhICJhLnABXzFjQjBjSjTjFYfXzJjQjSjPjUjPjUjZjQjFZfjXfNyBnAMhLbyBn0ABghNbyBn0AhCOhOgyhObyBn0ABJhOnAEXzEjTjBjWjFgafX"+
"RfeQfnfABnMnbyBn0ACJyhOnAEjNfRDjMfXPfeQfFctffZyhOnAFcfAXRfeQfnJhQnAEXzEjPjQjFjOgbfXSfeQfRBFeBjSffJhRnABXzIjFjOjDjPjEjJjOjHgcfXSfeQfneGiCiJiOiBiSiZfOhTbyhTn0ACJhTnAEjNfRDXzFjFjSjSjPjSgdfXSfeQfXPfeQfFctffZyhTnAFcfAXgdfXSfeQfnJhVnASzDjQjPjTgeAndAftJhYnASzHjIjSjEifjMjFjOgfCndgaftJhanASzEjCjVjGjGhABEXzEjSjFjBjEhBfXSfeQf"+
"RBVgffCffnffJhbnASgeACGnVgffCnnntfJhdnASzDjQjTjChCDncfftJhenASzDjQjTjEhDEncfftOiAJiAnAShDEnctffACzChdhdhEEXzGjTjVjCjTjUjShFfVhAfBRCFdAFdMffnneMhYiCiQiTAB0EnOiBJiBnAShCDnctffAChEEXhFfVhAfBRCFdAFdMffnneMhYiCiQiTAC0EnOiDbyiDn0ADJiDnAEXzFjDjMjPjTjFhGfXSfeQfnfJyiDnAEjNfRDFeViXjSjPjOjHhAiQiTiEhPiQiTiChAjIjFjBjEjFjShBXPfe"+
"QfFctffZyiDnAFcfAUzChGhGhHhzBhBhIVhDfEhhIVhCfDnnnJiFnABXzOjDjPjMjPjSifjNjPjEjFifjMjFjOhJfeQfEjOfRBEXhBfXSfeQfRBFdEffffnfJiGnASgeACGnCGnXhJfeQfdEnnnntfJiInAEXzEjTjFjFjLhKfXSfeQfRCVgefAFdAffJiKnABXzSjJjNjBjHjFifjSjFjTjPjVjSjDjFifjMjFjOhLfeQfEjOfRBEXhBfXSfeQfRBFdEffffnfJiLnASgeACGnCGnXhLfeQfdEnnnntfJiNnAEXhKfXSfeQfRCV"+
"gefAFdAffJiPnABXzOjMjBjZjFjSifjTjFjDjUifjMjFjOhMfeQfEjOfRBEXhBfXSfeQfRBdVhCfDFdIFdEffffnfJiQnABXzOjMjBjZjFjSifjJjOjGjPifjMjFjOhNfeQfEjOfRBEXhBfXSfeQfRBdVhCfDFdIFdEffffnfJiRnABXzLjMjBjZjFjSifjDjPjVjOjUhOfeQfEjOfRBEXhBfXSfeQfRBFdCffffnfJiTnABXzYjHjMjPjCifjMjBjZjFjSifjNjBjTjLifjJjOjGjPifjQjPjThPfeQfCGCGVgefAXhNfeQfnnd"+
"VhCfDFdQFdInnnfJiUnABXzOjJjNjBjHjFifjEjBjUjBifjQjPjThQfeQfCGCGVgefAXhMfeQfnndVhCfDFdIFdEnnnfJiWnABXhOfeQfEXzDjBjCjThRfjzEiNjBjUjIhSfRBXhOfeQfffnfJiYnASgeACGndVhCfDFdSFdKnnntfJianABXzGjMjBjZjFjSjThTfeQfEjzFiBjSjSjBjZhUfntnfJicnAEXhKfXSfeQfRCVgefAFdAffaiebjAn0AgfJjAnABQzAhVfXhTfeQfVJfFEjzGiPjCjKjFjDjUhWfntnfJjCnABXzG"+
"jCjPjVjOjEjThXfQhVfXhTfeQfVJfFAREEjOfRBEXhBfXSfeQfRBFdEffffEjOfRBEXhBfXSfeQfRBFdEffffEjOfRBEXhBfXSfeQfRBFdEffffEjOfRBEXhBfXSfeQfRBFdEfffffnfJjDnASgeACGnnndQntfJjFnABXzOjMjBjZjFjSifjDjIjBjOjOjFjMjThYfQhVfXhTfeQfVJfFEjOfRBEXhBfXSfeQfRBFdCffffnfJjGnASgeACGnnndCntfJjInABXzMjDjIjBjOjOjFjMifjJjOjGjPhZfQhVfXhTfeQfVJfFEjhU"+
"fntnfajKbjMn0AEJjMnABQhVfXhZfQhVfXhTfeQfVJfFVzBjOhafGEjhWfntnfJjNnABXzKjDjIjBjOjOjFjMifjJjEhbfQhVfXhZfQhVfXhTfeQfVJfFVhafGEjOfRBEXhBfXSfeQfRBFdCffffnfJjOnABXzQjDjIjBjOjOjFjMifjEjBjUjBifjMjFjOhcfQhVfXhZfQhVfXhTfeQfVJfFVhafGEjOfRBEXhBfXSfeQfRBdVhCfDFdIFdEffffnfJjPnASgeACGndVhCfDFdKFdGnnntfAVhafGAXhYfQhVfXhTfeQfVJfFBy"+
"BzBhchdJjSnASzLjDjIifjJjOjGjPifjMjFjOheHCHnXhYfQhVfXhTfeQfVJfFdGnnftJjUnASzKjCjNjPjEjFifjTjJjHjOhfIEXhBfXSfeQfRBFdEffnftJjVnASgeACGnnndEntfOjXbyjXn0ADJjXnAEXhGfXSfeQfnfJyjXnAEjNfRDCGnEXzLjUjPiVjQjQjFjSiDjBjTjFiAfEXzIjUjPiTjUjSjJjOjHiBfVgefARBFdQffnfehGiMjBjZjFjShAiCjMjFjOjEhAiNjPjEjFhAjQjBjSjTjFhAjFjSjSjPjShBKKiPiG"+
"iGiTiFiUhdnXPfeQfFctffZyjXnAFcfACzChBhdiCVhffInneEhYiCiJiNnJjZnABXzKjCjMjFjOjEifjNjPjEjFiDfQhVfXhTfeQfVJfFEXhBfXSfeQfRBFdEffnfJjanASgeACGnnndEntfJjcnABXzHjPjQjBjDjJjUjZiEfQhVfXhTfeQfVJfFEXIfEXhBfXSfeQfRBFdBffRBFdAffnfJjdnABXzIjDjMjJjQjQjJjOjHiFfQhVfXhTfeQfVJfFEXIfEXhBfXSfeQfRBFdBffRBFdAffnfJjenABXzFjGjMjBjHjTiGfQhV"+
"fXhTfeQfVJfFEXIfEXhBfXSfeQfRBFdBffRBFdAffnfJjfnAEXhBfXSfeQfRBFdBffJkAnASgeACGnnndEntfJkCnASzIjEjBjUjBifjMjFjOiHJEjOfRBEXhBfXSfeQfRBFdEffffnftJkDnASgeACGnnndEntfJkFnABXzEjEjBjUjBiIfQhVfXhTfeQfVJfFEXhBfXSfeQfRBViHfJffnfJkGnABXzLjEjBjUjBifjPjGjGjTjFjUiJfQhVfXhTfeQfVJfFVgefAnfJkHnASgeACGnViHfJnnntfJkJnASzCjYhRiKKEjOfRB"+
"EXhFfXiIfQhVfXhTfeQfVJfFRCFdAFdEffffnftJkKnASzCjYhSiLLEjOfRBEXhFfXiIfQhVfXhTfeQfVJfFRCCGViKfKnndEFdEffffnftJkLnASzCjYhTiMMEXIfEXhFfXiIfQhVfXhTfeQfVJfFRCCGCGViKfKViLfLnnnndIFdBffRBFdAffnftJkMnASzCjYhUiNNCKnCzBhFiOCGnViMfMdBnnndEdEnnftOkNJkNnASiNNndAffAChEViNfNnndEnJkPnABXPfQhVfXhTfeQfVJfFEXhFfXiIfQhVfXhTfeQfVJfFRCCG"+
"CGViKfKViLfLnnnndJViMfMffnfJkQnABXiIfQhVfXhTfeQfVJfFEXhFfXiIfQhVfXhTfeQfVJfFRBCGCGCGCGViKfKViLfLnnnndJViMfMnnViNfNnnffnfJkRnABXiJfQhVfXhTfeQfVJfFCGnCGCGCGCGViKfKViLfLnnnndJViMfMnnViNfNnnnnntAVJfFAXhOfeQfByBhdakWbkYn0ADJkYnASDOXiIfQhVfXhTfeQfVJfFnftJkanASgeAXiJfQhVfXhTfeQfVJfFnfflkcbyken0ABOkeblAn0AFclAnAEXhFfVDfORC"+
"FdEFdEffDRBFeEjMjZjJjEfRBFeEjTjIjNjEfRBFeEiTjPiMjEfDblDn0ACJlDnABXzIjMjBjZjFjSifjJjEiPfQhVfXhTfeQfVJfFEjOfRBEXhFfVDfORCFdMFdEffffnfDlEnAhVtblHn0AFJlHnASzKjNjFjUjBifjDjPjVjOjUiQPEjOfRBEXhFfVDfORCFdMFdEffffnftJlJnASzIjNjFjUjBjEjBjUjBiRQEXhFfVDfORBFdQffnftJlLnAShaGndAftllNblPn0ADOlPblRn0ACJlRnASBREjOfRBEXhFfViRfQRCCGV"+
"hafGnndMFdEffffnftclTnAEXhFfViRfQRCCGVhafGnndEFdEffCRBFeEjUjNjMjOfRBFeEjDjVjTjUfCblWn0ADJlWnABXzIjUjJjNjFjMjJjOjFiSfQhVfXhTfeQfVJfFEjzQiBjDjUjJjPjOiEjFjTjDjSjJjQjUjPjSiTfntnfJlXnAEXzKjGjSjPjNiTjUjSjFjBjNiUfXiSfQhVfXhTfeQfVJfFRBEXhFfViRfQRCCGVhafGnndQVBfRffffDlYnAhVtblbn0ADJlbnABXiRfQhVfXhTfeQfVJfFEjiTfntnfJlcnAEXiU"+
"fXiRfQhVfXhTfeQfVJfFRBEXhFfViRfQRCCGVhafGnndQVBfRffffDldnAhVtAUzCjcjciVChEEXhFfViRfQRCVhafGFdEffnneEhYiCiJiNChEEXhFfViRfQRCVhafGFdEffnneEhYiChWhUnnbmDn0ADJmDnAEXhGfXSfeQfnfJmEnAEjNfRDCGnEXiAfEXiBfVgefARBFdQffnfehEiMjBjZjFjShAjNjFjUjBjEjBjUjBhAjQjBjSjTjFhAjFjSjSjPjShBKKiPiGiGiTiFiUhdnXPfeQfFctffZmFnAFcfJmInAShaGCGnC"+
"GVBfRnndQnnntfJmKnATiQPyBfAViQfPDmNnAhVtbmQn0AFJmQnABXzMjTjNjBjSjUifjPjCjKjFjDjUiWfQhVfXhTfeQfVJfFEjiTfntnfJmRnAEXiUfXiWfQhVfXhTfeQfVJfFRBEXhFfVDfORBFdUffffJmSnABXzTjTjNjBjSjUifjPjCjKjFjDjUifjPjGjGjTjFjUiXfQhVfXhTfeQfVJfFCGVgefAnndUnfJmTnABXzPjTjNjBjSjUifjPjCjKjFjDjUifjJjEiYfQhVfXhTfeQfVJfFEXzJjHjFjUiTjUjSjJjOjHiZf"+
"XiWfQhVfXhTfeQfVJfFRBEjzQjTjUjSjJjOjHiJiEiUjPiUjZjQjFiJiEiafRBFeCiJiEffffnfDmUnAhVtJmXnASBREjOfRBEXhFfVDfORCFdIFdEffffnftJmZnASzBjYibSCGnVBfRdMnnftJmanASgeACGnVibfSnnntfJmcnASDOEXhFfVDfORBVibfSffnffAUiVChEEXhFfVDfORCFdAFdEffnneEhYiCiJiNChEEXhFfVDfORCFdAFdEffnneEhYiChWhUnnbnAn0ACOnAbnCn0ADJnCnAEXhGfXSfeQfnfJnDnAEjNf"+
"RDCGnEXiAfEXiBfVgefARBFdQffnfehAiMjBjZjFjShAiEjBjUjBhAjQjBjSjTjFhAjFjSjSjPjShBKKiPiGiGiTiFiUhdnXPfeQfFctffZnEnAFcfACiCXCfXiIfQhVfXhTfeQfVJfFCKVgefAXiJfQhVfXhTfeQfVJfFnnnnnDnHnAhVtAnAVJfFAXhOfeQfByBhdOnMbynMn0ADJnMnAEXhGfXSfeQfnfJynMnAEjNfRDCGnEXiAfEXiBfVgefARBFdQffnfeZiGjJjMjFhAjSjFjBjEhAjFjSjSjPjShBKKiPiGiGiTiFiUh"+
"dnXPfeQfFctffZynMnAFcfAXgdfXSfeQfnJnOnAEXhGfXSfeQfnfJnQnAShABnbffZnSnAFctABnMnbyBn0ACJnUnAEjNfRBjMfffZynUnAFcfATJ4F0AiAib4S0AiAhe4H0AiAhf4I0AiAD4O0AiAge40BiAiH4J0AiAiK4K0AiAiL4L0AiAiM4M0AiAiN4N0AiAiQ4P0AiAiR4Q0AiAha4G0AiAhA4B0AiAgf4C0AiAhC4D0AiAhD4E0AiAB4R0AiAATAhVCnVnfJnYnABXzRjHjFjUifjUjJjNjFjMjJjOjFifjEjFjTjDicf"+
"XZfjXfNyBnAMnYbyBn0ABgnabyBn0ABanbbyndn0ABOndbynfn0ABZnfnAXiSfQhVfXhTfeQfVJf0AChEXiPfQhVfXhTfeQfVJfAViPfBnnnAVJf0AXhOfeQfByBhdABnMnbyBn0ABJ2DBnAEjNfRBjMfffACJ40BiAiP40BhABBAhVC2EBnf0DhVByB");
var p = new PSD_Parser(activeDocument);
if (p.parse())
    var d = p.get_timeline_desc(layer_id);
    if (d)
    else
else
    alert("Failed!");
Unfortunatly Still not working, the file is very small (only 42k)  just 2 simple layers with timeline properties.  I'm getting a "Layer Blend Mode" parse Error this time.   I'm on Windows if that makes a difference, and this was in CC 2018.  I'll test on Mac...
I'd love to learn more about you're parsing trick!  looks very handy.  Thanks for your assistance.
People's Champ ,
Could you give me your file for research?
I am still debugging my parser and I don’t want to open its code yet.
I use this information to parse a file. Adobe Photoshop File Formats Specification
You can try to understand the file structure yourself if you want. )
Layer TimeLineInfo is located in the layer metadata section "8BIMshmd" in the "8BIMtmln" subsection.
Unfortunately, through AM-code, it is possible to read layer metadata only for the "8BIMcust" subsection containing data such as layerXMP and layerTime.
File is here: Dropbox - test.psd
Let me know if you need any additional testing.
People's Champ ,
Ok. Thank you!
You found a bug at me.
I made a change in the code at the last moment and this resulted in a negative number of layers for your file. In addition, I found another inaccuracy in determining the start of the layer.
Check. Now it works for me with your file )
eval("@JSXBIN@ES@2.0@MyBbyBnAEMAbyBn0ABJAnAEjzFjBjMjFjSjUBfRDVzBjFCfAFeFiFjSjSjPjSFctffABC40BhAB0AzGifjBjMjFjSjUD0AMDbyBn0ABgFbyBn0AFJGnASzDjMjFjOEAXzGjMjFjOjHjUjIFfVzBjTGfEnftJInASzEjNjVjMjUHBndBftJJnASzDjSjFjUICndAftKLbNn0ACJNnASICCzBhLJnCzBhKKEXzKjDjIjBjSiDjPjEjFiBjULfVGfERBVzBjJMfDffVHfBnnnnntfJOnASHBCKnnnd2ABntfASMDC"+
"zBhNNVEfAnndBnftCzChehdOVMfDnndATMDyBtZRnAVIfCABnCnbyBn0ABJTnAEjDfRBjCfffAFM4D0AiAG40BhAH4B0AiAI4C0AiAE40BiABEAzMifjHjFjUifjJjOjUjFjHjFjSPAUMXbyBn0ABgZbyBn0AFOgaJganASEGndBffACzChdhdQVEfGjzJjVjOjEjFjGjJjOjFjERfnnnJgcnASIAAnnftagebhAn0AFJhAnASzCjDhQSCEXLfVGfFRBCJnVMfBdAnffnftJhBnASzCjDhRTDEXLfVGfFRBCJnVMfBdBnffnftJh"+
"DnASzDjWjBjMUECJVTfDCKnVSfCd2ABnnnnftOhFJhFnASUEhzBhNVCJCNnVUfEd2nfnfnnndBnffACzBhGWVSfCnndkAnJhHnAEXzEjQjVjTjIXfVIfARBVUfEffAVMfBACKnVEfGdCnCyBzBhcYOhKZhKnAXzBhQZfVIf0ACQVEfGnndBnZhMnAVIf0ABnCnbyBn0ABJhOnAEjDfRBjCfffAHU4E0AiAM4B0AiAG40BhAS4C0AiAT4D0AiAI40BiAE4B0AhACFAzKifjHjFjUifjTjIjPjSjUgaAhPMhSbyBn0ABghUbyBn0AE"+
"JhVnABXzEjOjBjNjFgbfezEjUjIjJjTgcfneKiQiTiEhAiQjBjSjTjFjSfJhXnABXzDjEjPjDgdfegcfnbfJhYnABXzEjGjJjMjFgefegcfnbfOhabhcn0AGJhcnASzBjSgfAEjzPiBjDjUjJjPjOiSjFjGjFjSjFjOjDjFhAfntnftJhdnAEXzLjQjVjUiQjSjPjQjFjSjUjZhBfVgffARCEjzQjTjUjSjJjOjHiJiEiUjPiUjZjQjFiJiEhCfRBFeIjQjSjPjQjFjSjUjZffEjhCfRBFeGjGjPjSjNjBjUffffJhenAEXzNjQj"+
"VjUiJjEjFjOjUjJjGjJjFjShDfVgffARCEjhCfRBFeIjEjPjDjVjNjFjOjUffXzCjJjEhEfVgefCffgyiBbyBn0ABJiBnASzGjGjPjSjNjBjUhFBEXzJjHjFjUiTjUjSjJjOjHhGfEjzQjFjYjFjDjVjUjFiBjDjUjJjPjOiHjFjUhHfRBVgffAffRBEjhCfRBFeGjGjPjSjNjBjUffffnffABnCnnciDnAVhFfBCRCFeJiQjIjPjUjPjTjIjPjQFeViMjBjSjHjFhAiEjPjDjVjNjFjOjUhAiGjPjSjNjBjUfRBnfCbyiHn0ABD"+
"iHnAzAhItbiKn0ACJiKnAEjBfRDFegfiEjPjDjVjNjFjOjUhAjGjPjSjNjBjUhAjOjPjUhAiQiTiEhAjPjShAiQiTiChBXgbfegcfFctffZiLnAngyiObyBn0ACJiOnABXgefegcfXzIjGjVjMjMiOjBjNjFhJfVgefCnfJyiOnABXgdfegcfVgefCnfABnCnbyBn0ABJyiOnAEjBfRDFeXiEjPjDjVjNjFjOjUhAjOjPjUhAjZjFjUhAjTjBjWjFjEhBXgbfegcfFctffACzKjJjOjTjUjBjOjDjFjPjGhKVgefCjzIiEjPjDjV"+
"jNjFjOjUhLfnnOiQbyiSn0ABJiSnABXgefegcfVgefCnfAChKVgefCjzEiGjJjMjFhMfnnnABnCnbyBn0ABJiVnAEjDfRBjCfffADge40BhAgf40BiAhF4B0AiABCAzKiQiTiEifiQjBjSjTjFjShNAiWCJiZnABXzFjQjBjSjTjFhOfXzJjQjSjPjUjPjUjZjQjFhPfjhNfNyBnAMiZbyBn0ABgibbyBn0AhDOicgyicbyBn0ABJicnAEXzEjTjBjWjFhQfXgdfegcfnfABnCnbyBn0ACJyicnAEjBfRDjCfXgbfegcfFctffZy"+
"icnAFcfAXgdfegcfnOieZienAFcfAhzBhBhRXgefegcfnJjAnAEXzEjPjQjFjOhSfXgefegcfRBFeBjSffJjBnABXzIjFjOjDjPjEjJjOjHhTfXgefegcfneGiCiJiOiBiSiZfOjDbyjDn0ACJjDnAEjBfRDXzFjFjSjSjPjShUfXgefegcfXgbfegcfFctffZyjDnAFcfAXhUfXgefegcfnJjFnASzGjPjGjGjTjFjUhVAndAftJjInASzHjIjSjEifjMjFjOhWCndgaftJjKnASzEjCjVjGjGhXBEXzEjSjFjBjEhYfXgefegc"+
"fRBVhWfCffnffJjLnAShVACJnVhWfCnnntfJjNnASzDjQjTjChZDncfftJjOnASzDjQjTjEhaEncfftOjQJjQnAShaEnctffACQEXzGjTjVjCjTjUjShbfVhXfBRCFdAFdMffnneMhYiCiQiTAB0EnOjRJjRnAShZDnctffACQEXhbfVhXfBRCFdAFdMffnneMhYiCiQiTAC0EnOjTbyjTn0ADJjTnAEXzFjDjMjPjTjFhcfXgefegcfnfJyjTnAEjBfRDFeViXjSjPjOjHhAiQiTiEhPiQiTiChAjIjFjBjEjFjShBXgbfegcfF"+
"ctffZyjTnAFcfAUzChGhGhdhhRVhafEhhRVhZfDnnnJjVnABXzOjDjPjMjPjSifjNjPjEjFifjMjFjOhefegcfEjPfRBEXhYfXgefegcfRBFdEffffnfJjWnAShVACJnCJnXhefegcfdEnnnntfJjYnAEXzEjTjFjFjLhffXgefegcfRCVhVfAFdAffJjanABXzSjJjNjBjHjFifjSjFjTjPjVjSjDjFifjMjFjOiAfegcfEjPfRBEXhYfXgefegcfRBFdEffffnfJjbnAShVACJnCJnXiAfegcfdEnnnntfJjdnAEXhffXgefeg"+
"cfRCVhVfAFdAffJjfnABXzOjMjBjZjFjSifjTjFjDjUifjMjFjOiBfegcfEjPfRBEXhYfXgefegcfRBdVhZfDFdIFdEffffnfJkAnABXzOjMjBjZjFjSifjJjOjGjPifjMjFjOiCfegcfEjPfRBEXhYfXgefegcfRBdVhZfDFdIFdEffffnfJkBnABXzLjMjBjZjFjSifjDjPjVjOjUiDfegcfEjgafRBEXhYfXgefegcfRBFdCffffnfJkDnABXzYjHjMjPjCifjMjBjZjFjSifjNjBjTjLifjJjOjGjPifjQjPjTiEfegcfCJC"+
"JVhVfAXiCfegcfnndVhZfDFdQFdInnnfJkEnABXzOjJjNjBjHjFifjEjBjUjBifjQjPjTiFfegcfCJCJVhVfAXiBfegcfnndVhZfDFdIFdEnnnfJkGnABXiDfegcfEXzDjBjCjTiGfjzEiNjBjUjIiHfRBXiDfegcfffnfJkInAShVACJndVhZfDFdSFdKnnntfJkKnABXzGjMjBjZjFjSjTiIfegcfEjzFiBjSjSjBjZiJfntnfJkMnAEXhffXgefegcfRCVhVfAFdAffakObkQn0AgfJkQnABQhIfXiIfegcfVMfFEjzGiPjCj"+
"KjFjDjUiKfntnfJkSnABXzGjCjPjVjOjEjTiLfQhIfXiIfegcfVMfFAREEjPfRBEXhYfXgefegcfRBFdEffffEjPfRBEXhYfXgefegcfRBFdEffffEjPfRBEXhYfXgefegcfRBFdEffffEjPfRBEXhYfXgefegcfRBFdEfffffnfJkTnAShVACJnnndQntfJkVnABXzOjMjBjZjFjSifjDjIjBjOjOjFjMjTiMfQhIfXiIfegcfVMfFEjPfRBEXhYfXgefegcfRBFdCffffnfJkWnAShVACJnnndCntfJkYnABXzMjDjIjBjOjOj"+
"FjMifjJjOjGjPiNfQhIfXiIfegcfVMfFEjiJfntnfakabkcn0AEJkcnABQhIfXiNfQhIfXiIfegcfVMfFVzBjOiOfGEjiKfntnfJkdnABXzKjDjIjBjOjOjFjMifjJjEiPfQhIfXiNfQhIfXiIfegcfVMfFViOfGEjPfRBEXhYfXgefegcfRBFdCffffnfJkenABXzQjDjIjBjOjOjFjMifjEjBjUjBifjMjFjOiQfQhIfXiNfQhIfXiIfegcfVMfFViOfGEjPfRBEXhYfXgefegcfRBdVhZfDFdIFdEffffnfJkfnAShVACJndV"+
"hZfDFdKFdGnnntfAViOfGAXiMfQhIfXiIfegcfVMfFByBYJlCnASzLjDjIifjJjOjGjPifjMjFjOiRHCKnXiMfQhIfXiIfegcfVMfFdGnnftJlEnASzKjCjNjPjEjFifjTjJjHjOiSIEXhYfXgefegcfRBFdEffnftJlFnAShVACJnnndEntfOlHbylHn0ADJlHnAEXhcfXgefegcfnfJylHnAEjBfRDCJnEXzLjUjPiVjQjQjFjSiDjBjTjFiTfEXzIjUjPiTjUjSjJjOjHiUfVhVfARBFdQffnfehGiMjBjZjFjShAiCjMjFjO"+
"jEhAiNjPjEjFhAjQjBjSjTjFhAjFjSjSjPjShBKKiPiGiGiTiFiUhdnXgbfegcfFctffZylHnAFcfACzChBhdiVViSfInneEhYiCiJiNnJlJnABXzKjCjMjFjOjEifjNjPjEjFiWfQhIfXiIfegcfVMfFEXhYfXgefegcfRBFdEffnfJlKnAShVACJnnndEntfJlMnABXzHjPjQjBjDjJjUjZiXfQhIfXiIfegcfVMfFEXLfEXhYfXgefegcfRBFdBffRBFdAffnfJlNnABXzIjDjMjJjQjQjJjOjHiYfQhIfXiIfegcfVMfFEXL"+
"fEXhYfXgefegcfRBFdBffRBFdAffnfJlOnABXzFjGjMjBjHjTiZfQhIfXiIfegcfVMfFEXLfEXhYfXgefegcfRBFdBffRBFdAffnfJlPnAEXhYfXgefegcfRBFdBffJlQnAShVACJnnndEntfJlSnASzIjEjBjUjBifjMjFjOiaJEjPfRBEXhYfXgefegcfRBFdEffffnftJlTnAShVACJnnndEntfJlVnABXzEjEjBjUjBibfQhIfXiIfegcfVMfFEXhYfXgefegcfRBViafJffnfJlWnABXzLjEjBjUjBifjPjGjGjTjFjUicf"+
"QhIfXiIfegcfVMfFVhVfAnfJlXnAShVACJnViafJnnntfJlZnASzCjYhRidKEjPfRBEXhbfXibfQhIfXiIfegcfVMfFRCFdAFdEffffnftJlanASzCjYhSieLEjPfRBEXhbfXibfQhIfXiIfegcfVMfFRCCJVidfKnndEFdEffffnftJlbnASzCjYhTifMEXLfEXhbfXibfQhIfXiIfegcfVMfFRCCJCJVidfKViefLnnnndIFdBffRBFdAffnftJlcnASzCjYhUjANCNnCzBhFjBCJnViffMdBnnndEdEnnftOldJldnASjANnd"+
"AffACQVjAfNnndEnJlfnABXgbfQhIfXiIfegcfVMfFEXhbfXibfQhIfXiIfegcfVMfFRCCJCJVidfKViefLnnnndJViffMffnfJmAnABXibfQhIfXiIfegcfVMfFEXhbfXibfQhIfXiIfegcfVMfFRBCJCJCJCJVidfKViefLnnnndJViffMnnVjAfNnnffnfJmBnABXicfQhIfXiIfegcfVMfFCJnCJCJCJCJVidfKViefLnnnndJViffMnnVjAfNnnnnntAVMfFAXiDfegcfByBYamGbmIn0ADJmInASGOXibfQhIfXiIfegcf"+
"VMfFnftJmKnAShVAXicfQhIfXiIfegcfVMfFnfflmMbymOn0ABOmObmQn0AFcmQnAEXhbfVGfORCFdEFdEffDRBFeEjMjZjJjEfRBFeEjTjIjNjEfRBFeEiTjPiMjEfDbmTn0ACJmTnABXzIjMjBjZjFjSifjJjEjCfQhIfXiIfegcfVMfFEjPfRBEXhbfVGfORCFdMFdEffffnfDmUnAhItbmXn0AFJmXnASzKjNjFjUjBifjDjPjVjOjUjDPEjPfRBEXhbfVGfORCFdMFdEffffnftJmZnASzIjNjFjUjBjEjBjUjBjEQEXhbf"+
"VGfORBFdQffnftJmbnASiOGndAftlmdbmfn0ADOmfbnBn0ACJnBnASEREjPfRBEXhbfVjEfQRCCJViOfGnndMFdEffffnftcnDnAEXhbfVjEfQRCCJViOfGnndEFdEffCRBFeEjUjNjMjOfRBFeEjDjVjTjUfCbnGn0ADJnGnABXzIjUjJjNjFjMjJjOjFjFfQhIfXiIfegcfVMfFEjzQiBjDjUjJjPjOiEjFjTjDjSjJjQjUjPjSjGfntnfJnHnAEXzKjGjSjPjNiTjUjSjFjBjNjHfXjFfQhIfXiIfegcfVMfFRBEXhbfVjEfQ"+
"RCCJViOfGnndQVEfRffffDnInAhItbnLn0ADJnLnABXjEfQhIfXiIfegcfVMfFEjjGfntnfJnMnAEXjHfXjEfQhIfXiIfegcfVMfFRBEXhbfVjEfQRCCJViOfGnndQVEfRffffDnNnAhItAUzCjcjcjICQEXhbfVjEfQRCViOfGFdEffnneEhYiCiJiNCQEXhbfVjEfQRCViOfGFdEffnneEhYiChWhUnnbnTn0ADJnTnAEXhcfXgefegcfnfJnUnAEjBfRDCJnEXiTfEXiUfVhVfARBFdQffnfehEiMjBjZjFjShAjNjFjUjBjE"+
"jBjUjBhAjQjBjSjTjFhAjFjSjSjPjShBKKiPiGiGiTiFiUhdnXgbfegcfFctffZnVnAFcfJnYnASiOGCJnCJVEfRnndQnnntfJnanATjDPyBfAVjDfPDndnAhItb2ABn0AFJ2ABnABXzMjTjNjBjSjUifjPjCjKjFjDjUjJfQhIfXiIfegcfVMfFEjjGfntnfJ2BBnAEXjHfXjJfQhIfXiIfegcfVMfFRBEXhbfVGfORBFdUffffJ2CBnABXzTjTjNjBjSjUifjPjCjKjFjDjUifjPjGjGjTjFjUjKfQhIfXiIfegcfVMfFCJVhV"+
"fAnndUnfJ2DBnABXzPjTjNjBjSjUifjPjCjKjFjDjUifjJjEjLfQhIfXiIfegcfVMfFEXhGfXjJfQhIfXiIfegcfVMfFRBEjhCfRBFeCiJiEffffnfD2EBnAhItJ2HBnASEREjPfRBEXhbfVGfORCFdIFdEffffnftJ2JBnASzBjYjMSCJnVEfRdMnnftJ2KBnAShVACJnVjMfSnnntfJ2MBnASGOEXhbfVGfORBVjMfSffnffAUjICQEXhbfVGfORCFdAFdEffnneEhYiCiJiNCQEXhbfVGfORCFdAFdEffnneEhYiChWhUnnb2"+
"QBn0ACO2QBb2SBn0ADJ2SBnAEXhcfXgefegcfnfJ2TBnAEjBfRDCJnEXiTfEXiUfVhVfARBFdQffnfehAiMjBjZjFjShAiEjBjUjBhAjQjBjSjTjFhAjFjSjSjPjShBKKiPiGiGiTiFiUhdnXgbfegcfFctffZ2UBnAFcfACiVXFfXibfQhIfXiIfegcfVMfFCNVhVfAXicfQhIfXiIfegcfVMfFnnnnnD2XBnAhItAnAVMfFAXiDfegcfByBYO2gcBby2gcBn0ADJ2gcBnAEXhcfXgefegcfnfJy2gcBnAEjBfRDCJnEXiTfEXi"+
"UfVhVfARBFdQffnfegaiGjJjMjFhAjSjFjBjEhAjFjSjSjPjSjShBKKiPiGiGiTiFiUhdnXgbfegcfFctffZy2gcBnAFcfAXhUfXgefegcfnJ2geBnAEXhcfXgefegcfnfJ2hABnAShXBnbffZ2hCBnAFctABnCnbyBn0ACJ2hEBnAEjDfRBjCfffZy2hEBnAFcfAThV40BiAhX4B0AiAM4F0AiAhW4C0AiAjM4S0AiAhZ4D0AiAha4E0AiAG4O0AiAiR4H0AiAiS4I0AiAia4J0AiAid4K0AiAie4L0AiAif4M0AiAjA4N0AiAj"+
"D4P0AiAiO4G0AiAjE4Q0AiAE4R0AiAATAhIC2hFBnfJ2hIBnABXzRjHjFjUifjUjJjNjFjMjJjOjFifjEjFjTjDjNfXhPfjhNfNyBnAM2hIBbyBn0ABg2hKBbyBn0ABa2hLBby2hNBn0ABO2hNBby2hPBn0ABZ2hPBnAXjFfQhIfXiIfegcfVMf0ACQXjCfQhIfXiIfegcfVMfAVjCfBnnnAVMf0AXiDfegcfByBYABnCnbyBn0ABJ2hTBnAEjDfRBjCfffACM40BiAjC40BhABBAhIC2hUBnf0DhIByB");
if (p.parse())
    if (d)
        var s1 = d.getObjectValue(stringIDToTypeID("timeScope")).getObjectValue(stringIDToTypeID("start")).getInteger(stringIDToTypeID("numerator"));
        var s2 = d.getObjectValue(stringIDToTypeID("timeScope")).getObjectValue(stringIDToTypeID("start")).getInteger(stringIDToTypeID("denominator"));
        var frame = (n1/n2 + s1/s2)*frame_rate;
    else
else
    alert("Failed!");
