Acrobat DC crashes when launching output preview
Nov 12, 2018 Nov 12, 2018
After updating to Mojave 10.14.1 from High Sierra, any time I try to launch output preview, the app crashes. This happens whether by shortcut key command or choosing the tool. Is this a bug that will be fixed (others experiencing it), or something I need to try a re-install on?
General troubleshooting
1.4K
Adobe Employee ,
Nov 13, 2018 Nov 13, 2018
Hi brentm,
As per the issue description mentioned above, Acrobat DC is crashing when launching outpout preview in Acrobat, is that correct?
I tried replicating the issue on Mac OS Mojave 10.14.1 with Acrobat DC's version 2019.008.20080 but the issue was not reproducible.
Could you check if you have the latest patch installed for Acrobat on the machine?  You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Also, let us know if there is any error message when Acrobat crashes?
Does this happen when you are working on a specific pdf file or with all the files?
Let us know if you need any help.
Shivam
I also have the same  crash problem with "uitvoervoorbeeld" ( Dutch ) after updating to Mojave 10.14.1
I re-installed but still crashes with every pdf I try.
Do you have any 3rd party plug-ins installed?
Nov 14, 2018 Nov 14, 2018
I'am a little happy, I have 2 screens, one Imac 27'' and a cinema display 23''
The crash problem only happens on the second screen.
I tried different backgrounds without result.
I did a re-install without 3rd party plug-ins
Adobe Employee ,
Hi Leo goedegebure,
Could you try creating a new user account on the machine by clicking Apple menu > System Preferences, then click Users & Groups  ( Mac) Login into that account and check if Acrobat is still crashing upon launching output preview?
-Shivam
Hello Shivam
When I make a new account and login, Acrobat isn't crashing.
but I'am not really happy with this solution....
Adobe Employee ,
Nov 15, 2018 Nov 15, 2018
Hi leo goedegebure,
Could you try resetting preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. reboot the machine after resetting preferences and try again?
Let us know how it goes.
Shivam
I have tried this, and I think I have the problem narrowed down further. Acrobat will launch Output Preview without crashing because it now opens the tool onto the same window as my document (main monitor) using default preferences. Previously, the default open location was on my 2nd monitor and it immediately crashed. Now however, after the tool is open and I attempt to drag the output preview window from my main monitor to my 2nd monitor, Acrobat immediately crashes. Just as before I reset Acrobat preferences, if I had the document open on my 2nd monitor and then launched output preview, it didn't crash. In that case I can then move my document to the main monitor, move the tool's window back and forth between monitors without anything crashing. It appears the problem is when the tool attempts to initially open on the 2nd monitor with the document on the main monitor, or the tool is moved to the 2nd monitor after opening on the 1st monitor.
Nov 18, 2018 Nov 18, 2018
Exactly same here with second monitor!
Nov 29, 2018 Nov 29, 2018
Same here, when the document is on the same monitor as the Output preview window it doesn't crash...
Hello Shivam
For me the same result as brentm42423806. It crashes on screen1 or on screen2 when replacing.
L.G.
Thanks for the trick to get it to not crash by launching output preview on the 2nd monitor. I have the same configuration. Mine does not crash on the 2nd monitor either.
Yes, it happens when launching output preview.
We are using the most recent version (2019.008.20080).
Architecture: x86_64
Build: 19.8.20080.306727
AGM: 4.30.81
CoolType: 5.14.5
JP2K: 1.2.2.41572
It crashes regardless of the file we have open.
Here's the crash report.
Process:           AdobeAcrobat [7962]
Path:              /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
Identifier:        com.adobe.Acrobat.Pro
Version:           19.008.20080 (19.008.20080)
Code Type:         X86-64 (Native)
Parent Process:    ??? [1]
Responsible:       AdobeAcrobat [7962]
User ID:           503
Date/Time:         2018-11-13 07:55:18.114 -0700
OS Version:        Mac OS X 10.14.1 (18B75)
Report Version:    12
Anonymous UUID:    DC7DCD2B-4680-5BF7-0CEB-B12C9EC7D50A
Time Awake Since Boot: 140000 seconds
System Integrity Protection: enabled
Crashed Thread:    0  Dispatch queue: com.apple.main-thread
Exception Type:    EXC_CRASH (SIGABRT)
Exception Codes:   0x0000000000000000, 0x0000000000000000
Exception Note:    EXC_CORPSE_NOTIFY
Application Specific Information:
Assertion failed: (type == kCGImageComponent8BitInteger), function img_data_depth, file /BuildRoot/Library/Caches/com.apple.xbs/Sources/CoreGraphics/CoreGraphics-1247.4.1/CoreGraphics/Images/CGSImage.c, line 5889.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib   0x00007fff774acb86 __pthread_kill + 10
1   libsystem_pthread.dylib  0x00007fff77562c50 pthread_kill + 285
2   libsystem_c.dylib        0x00007fff774161c9 abort + 127
3   libsystem_c.dylib        0x00007fff773de868 __assert_rtn + 320
4   com.apple.CoreGraphics   0x00007fff4a5e1240 img_data_lock + 9844
5   com.apple.CoreGraphics   0x00007fff4a5dadd7 CGSImageDataLock + 1256
6   com.apple.CoreGraphics   0x00007fff4a5da890 RIPImageDataInitializeShared + 177
7   com.apple.CoreGraphics   0x00007fff4a5da43e RIPImageCacheGetRetained + 661
8   com.apple.CoreGraphics   0x00007fff4a5d9f64 ripc_AcquireRIPImageData + 293
9   com.apple.CoreGraphics   0x00007fff4a62460c ripc_DrawImages + 4743
10  com.apple.CoreGraphics   0x00007fff4a6228ec CGContextDrawImages + 188
11  com.apple.coreui         0x00007fff5f18fd5f DrawNinePartImageWithOperation + 5502
12  com.apple.coreui         0x00007fff5f18e635 DrawNinePartElementFromRenditionWithOperation + 416
13  com.apple.coreui         0x00007fff5f16fa2e -[CUIThemeFacet _drawSpecificRenditionKey:rendition:inFrame:context:alpha:operation:isFocused:isFlipped:effects:] + 406
14  com.apple.coreui         0x00007fff5f16f889 -[CUIThemeFacet _drawSpecificRenditionKey:inFrame:context:isFocused:isFlipped:effects:] + 153
15  com.apple.coreui         0x00007fff5f16f7d0 -[CUIThemeFacet drawInFrame:isFocused:context:effects:] + 142
16  com.apple.coreui         0x00007fff5f187aee CUICoreThemeRenderer::DrawSimple(CUIRenditionKey*, CUIDescriptor const*, signed char) + 552
17  com.apple.coreui         0x00007fff5f16e661 CUIRenderer::Draw(CGRect, CGContext*, __CFDictionary const*, __CFDictionary const**) + 1719
18  com.apple.coreui         0x00007fff5f16df78 CUIDraw + 278
19  com.apple.AppKit         0x00007fff4780df96 __44-[NSAppearance _drawInRect:context:options:]_block_invoke + 47
20  com.apple.AppKit         0x00007fff476f8dee -[NSCompositeAppearance _callCoreUIWithBlock:options:] + 364
21  com.apple.AppKit         0x00007fff4780df61 -[NSAppearance _drawInRect:context:options:] + 105
22  com.apple.AppKit         0x00007fff47c889f5 __25-[NSWidgetView drawRect:]_block_invoke + 158
23  com.apple.AppKit         0x00007fff477eeed8 _withOverlaidDictionary + 135
24  com.apple.AppKit         0x00007fff47c8894a -[NSWidgetView drawRect:] + 114
25  com.apple.AppKit         0x00007fff47811755 _NSViewDrawRect + 66
26  com.apple.AppKit         0x00007fff477fc552 -[NSView _drawRect:clip:] + 1745
27  com.apple.AppKit         0x00007fff477fb3f3 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1400
28  com.apple.AppKit         0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622
29  com.apple.AppKit         0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622
30  com.apple.AppKit         0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622
31  com.apple.AppKit         0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622
32  com.apple.AppKit         0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622
33  com.apple.AppKit         0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622
34  com.apple.AppKit         0x00007fff477f94f8 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 938
35  com.apple.AppKit         0x00007fff477f9128 -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 65
36  com.apple.AppKit         0x00007fff477f6a5a -[NSView _oldDisplayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 1887
37  com.apple.AppKit         0x00007fff477f6099 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 253
38  com.apple.AppKit         0x00007fff477f2c86 -[NSView displayIfNeeded] + 1300
39  com.adobe.Acrobat.framework  0x00000001103f9e99 0x10fed9000 + 5377689
40  com.adobe.Acrobat.framework  0x00000001103d56f3 0x10fed9000 + 5228275
41  com.adobe.Acrobat.framework  0x00000001103629d2 0x10fed9000 + 4757970
42  com.adobe.Acrobat.framework  0x0000000110389133 0x10fed9000 + 4915507
43  com.adobe.Acrobat.framework  0x0000000110033473 0x10fed9000 + 1418355
44  com.adobe.Acrobat.framework  0x0000000110143bd9 0x10fed9000 + 2534361
45  com.adobe.Acrobat.framework  0x000000011014c5cc 0x10fed9000 + 2569676
46  com.adobe.Acrobat.framework  0x000000011014d8fc 0x10fed9000 + 2574588
47  com.adobe.Acrobat.framework  0x000000011014d840 0x10fed9000 + 2574400
48  com.adobe.Acrobat.framework  0x0000000110793aa9 0x10fed9000 + 9153193
49  com.adobe.Acrobat.framework  0x0000000110a65eec 0x10fed9000 + 12111596
50  com.adobe.Acrobat.framework  0x00000001107015be 0x10fed9000 + 8553918
51  com.adobe.Acrobat.framework  0x00000001107017ac 0x10fed9000 + 8554412
52  com.adobe.Acrobat.framework  0x0000000110d2fbad 0x10fed9000 + 15035309
53  com.adobe.Acrobat.framework  0x0000000110d2ccd4 0x10fed9000 + 15023316
54  com.adobe.Acrobat.framework  0x0000000110eafd2d 0x10fed9000 + 16608557
55  com.adobe.Acrobat.framework  0x0000000110d6c78e 0x10fed9000 + 15284110
56  com.adobe.Acrobat.framework  0x0000000110d6efcd 0x10fed9000 + 15294413
57  com.adobe.Acrobat.framework  0x000000011071e761 0x10fed9000 + 8673121
58  com.adobe.Acrobat.framework  0x000000011071e581 0x10fed9000 + 8672641
59  com.adobe.Acrobat.framework  0x00000001109406c9 0x10fed9000 + 10909385
60  com.adobe.Acrobat.framework  0x000000011093c990 0x10fed9000 + 10893712
61  com.apple.AppKit         0x00007fff47920d63 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5668
62  com.apple.AppKit         0x00007fff47854d8b -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2319
63  com.apple.AppKit         0x00007fff47854231 -[NSWindow(NSEventRouting) sendEvent:] + 481
64  com.apple.AppKit         0x00007fff476f14a8 -[NSApplication(NSEvent) sendEvent:] + 336
65  com.apple.AppKit         0x00007fff476decf1 -[NSApplication run] + 755
66  com.adobe.Acrobat.framework  0x000000010fee16a8 0x10fed9000 + 34472
67  com.adobe.Acrobat.framework  0x000000010fedffba RunAcrobat + 243
68  com.adobe.Acrobat.Pro    0x000000010dc59f3f main + 86
69  libdyld.dylib            0x00007fff7736e08d start + 1
Thread 1:: Dispatch queue: NSOperationQueue 0x600003b39aa0 (QOS: UNSPECIFIED)
0   libsystem_kernel.dylib   0x00007fff774aa876 __semwait_signal + 10
1   libsystem_c.dylib        0x00007fff77435830 nanosleep + 199
2   com.apple.Foundation     0x00007fff4c5ac04b +[NSThread sleepForTimeInterval:] + 156
3   com.adobe.Acrobat.framework  0x0000000111074fb8 0x10fed9000 + 18464696
4   com.apple.Foundation     0x00007fff4c506d5a -[__NSOperationInternal _start:] + 686
5   com.apple.Foundation     0x00007fff4c53145f __NSOQSchedule_f + 227
6   libdispatch.dylib        0x00007fff7731ed53 _dispatch_call_block_and_release + 12
7   libdispatch.dylib        0x00007fff7731fdcf _dispatch_client_callout + 8
8   libdispatch.dylib        0x00007fff773225dc _dispatch_continuation_pop + 427
9   libdispatch.dylib        0x00007fff77321c7e _dispatch_async_redirect_invoke + 718
10  libdispatch.dylib        0x00007fff7732dd26 _dispatch_root_queue_drain + 325
11  libdispatch.dylib        0x00007fff7732e4bd _dispatch_worker_thread2 + 90
12  libsystem_pthread.dylib  0x00007fff7755f70e _pthread_wqthread + 619
13  libsystem_pthread.dylib  0x00007fff7755f435 start_wqthread + 13
Thread 2:
0   libsystem_kernel.dylib   0x00007fff774aa1b2 __psynch_cvwait + 10
1   libsystem_pthread.dylib  0x00007fff775635cb _pthread_cond_wait + 724
2   com.adobe.AGM            0x000000010dddca5a 0x10ddcf000 + 55898
3   com.adobe.AGM            0x000000010dddc98d 0x10ddcf000 + 55693
4   com.adobe.AGM            0x000000010e12c98d 0x10ddcf000 + 3529101
5   libsystem_pthread.dylib  0x00007fff77560339 _pthread_body + 126
6   libsystem_pthread.dylib  0x00007fff775632a7 _pthread_start + 70
7   libsystem_pthread.dylib  0x00007fff7755f445 thread_start + 13
Thread 3:
Thread 4:
Thread 5:: com.apple.NSEventThread
0   libsystem_kernel.dylib   0x00007fff774a6c2a mach_msg_trap + 10
1   libsystem_kernel.dylib   0x00007fff774a7174 mach_msg + 60
2   com.apple.CoreFoundation 0x00007fff4a191da2 __CFRunLoopServiceMachPort + 337
3   com.apple.CoreFoundation 0x00007fff4a1912f1 __CFRunLoopRun + 1654
4   com.apple.CoreFoundation 0x00007fff4a190a28 CFRunLoopRunSpecific + 463
5   com.apple.AppKit         0x00007fff476eeadd _NSEventThread + 160
6   libsystem_pthread.dylib  0x00007fff77560339 _pthread_body + 126
7   libsystem_pthread.dylib  0x00007fff775632a7 _pthread_start + 70
8   libsystem_pthread.dylib  0x00007fff7755f445 thread_start + 13
Thread 6:
2   com.adobe.Acrobat.framework  0x000000011033c849 0x10fed9000 + 4601929
3   com.adobe.Acrobat.framework  0x000000011032d0b7 0x10fed9000 + 4538551
4   com.adobe.Acrobat.framework  0x000000011113f7ad 0x10fed9000 + 19294125
5   com.adobe.Acrobat.framework  0x0000000110327f10 0x10fed9000 + 4517648
6   com.adobe.Acrobat.framework  0x00000001103369b8 0x10fed9000 + 4577720
7   libsystem_pthread.dylib  0x00007fff77560339 _pthread_body + 126
8   libsystem_pthread.dylib  0x00007fff775632a7 _pthread_start + 70
9   libsystem_pthread.dylib  0x00007fff7755f445 thread_start + 13
Thread 7:
0   libsystem_kernel.dylib   0x00007fff774a88a6 read + 10
1   com.adobe.Acrobat.framework  0x000000011032b421 0x10fed9000 + 4531233
2   com.adobe.Acrobat.framework  0x0000000110329359 0x10fed9000 + 4522841
3   com.adobe.Acrobat.framework  0x00000001103327cc 0x10fed9000 + 4560844
4   com.adobe.Acrobat.framework  0x0000000110327f10 0x10fed9000 + 4517648
5   com.adobe.Acrobat.framework  0x00000001103369b8 0x10fed9000 + 4577720
Thread 8:
0   libsystem_kernel.dylib   0x00007fff774ad052 kevent + 10
1   com.adobe.Acrobat.framework  0x0000000111ab502b 0x10fed9000 + 29212715
2   com.adobe.Acrobat.framework  0x00000001119d5dcc 0x10fed9000 + 28298700
3   libsystem_pthread.dylib  0x00007fff77560339 _pthread_body + 126
4   libsystem_pthread.dylib  0x00007fff775632a7 _pthread_start + 70
5   libsystem_pthread.dylib  0x00007fff7755f445 thread_start + 13
Thread 9:
5   com.adobe.AcrobatPlugin.EFS  0x000000011b93f3a9 0x11b925000 + 107433
6   com.apple.Foundation     0x00007fff4c4ed014 __NSThread__start__ + 1218
Thread 10:: com.apple.NSURLConnectionLoader
5   com.apple.CFNetwork      0x00007fff490934e5 -[__CoreSchedulingSetRunnable runForever] + 195
Thread 11:
0   libsystem_kernel.dylib   0x00007fff774ade82 __select + 10
1   com.adobe.AcrobatPlugin.Comments    0x000000011ade1ebb 0x11aa45000 + 3788475
2   com.adobe.AcrobatPlugin.Comments    0x000000011ade24c3 0x11aa45000 + 3790019
3   com.adobe.AcrobatPlugin.Comments    0x000000011ade28b3 0x11aa45000 + 3791027
4   com.adobe.AcrobatPlugin.Comments    0x000000011ad6ae45 0x11aa45000 + 3300933
5   com.adobe.AcrobatPlugin.Comments    0x000000011af8355b 0x11aa45000 + 5498203
Thread 12:
2   com.adobe.Acrobat.framework  0x0000000111aa8604 0x10fed9000 + 29160964
3   com.adobe.Acrobat.framework  0x0000000111aa6191 0x10fed9000 + 29151633
4   com.adobe.Acrobat.framework  0x0000000111aa60e9 0x10fed9000 + 29151465
Thread 13:
2   com.adobe.headlights.LogSessionFramework    0x0000000119d9459c boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3   com.adobe.headlights.LogSessionFramework    0x0000000119d92ebf boost::this_thread::hiden::sleep_for(timespec const&) + 191
4   com.adobe.headlights.LogSessionFramework    0x0000000119d2856a void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5   com.adobe.headlights.LogSessionFramework    0x0000000119d237b7 RealTimeProcessor::WorkerThread(int) + 3683
6   com.adobe.headlights.LogSessionFramework    0x0000000119d92239 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 14:: com.apple.CFSocket.private
1   com.apple.CoreFoundation 0x00007fff4a1bf9d3 __CFSocketManager + 639
2   libsystem_pthread.dylib  0x00007fff77560339 _pthread_body + 126
3   libsystem_pthread.dylib  0x00007fff775632a7 _pthread_start + 70
4   libsystem_pthread.dylib  0x00007fff7755f445 thread_start + 13
Thread 15:
0   libsystem_kernel.dylib   0x00007fff774a6c66 semaphore_wait_trap + 10
1   com.adobe.AIDE           0x000000010e77b972 CTThreading::OSSemaphore::Wait() + 16
2   com.adobe.AIDE           0x000000010e77aa1a CTThreading::ThreadSafeQueue::Dequeue() + 22
3   com.adobe.AIDE           0x000000010e77af64 CTThreading::WorkerThread::Start() + 38
4   com.adobe.AIDE           0x000000010e77a76a CTThreading::PthreadStart(void*) + 14
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
0   libsystem_pthread.dylib  0x00007fff7755f428 start_wqthread + 0
1   ???                      0x0000600000cbe940 0 + 105553129630016
Thread 25:
1   ???                      0x0000000054485244 0 + 1414025796
Thread 26:
1   ???                      0x0000000200000000 0 + 8589934592
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x000000010feae5c0  rcx: 0x00007ffee1f9fe88  rdx: 0x0000000000000000
  rdi: 0x0000000000000307  rsi: 0x0000000000000006  rbp: 0x00007ffee1f9fec0  rsp: 0x00007ffee1f9fe88
   r8: 0x0000000000001701   r9: 0xcccccccccccccccd  r10: 0x0000000000000000  r11: 0x0000000000000206
  r12: 0x0000000000000307  r13: 0x000000010f2e4000  r14: 0x0000000000000006  r15: 0x000000000000002d
  rip: 0x00007fff774acb86  rfl: 0x0000000000000206  cr2: 0x00007fffaa178188
Logical CPU: 0
Error Code:  0x02000148
Trap Number: 133
Binary Images:
   0x10dc59000 -    0x10dc59fff +com.adobe.Acrobat.Pro (19.008.20080 - 19.008.20080) <B0E5A575-1F00-3838-8534-139840444702> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
   0x10dc5e000 -    0x10ddb7fff +com.adobe.ACE (AdobeACE 2.20.02.41668 - 2.20.02.41668) <4F5F2FB8-6939-3F95-AB83-EE18E8DFE239> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
   0x10ddcf000 -    0x10e2b6ff7 +com.adobe.AGM (AdobeAGM 4.30.80.1 - 4.30.81.1) <F546780C-B337-377C-8325-71175E386696> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
   0x10e371000 -    0x10e38afff +com.adobe.BIB (AdobeBIB 1.2.03.41668 - 1.2.03.41668) <356C42CD-B75A-35EA-90B6-3EC75EA74A3A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
   0x10e393000 -    0x10e66afff +com.adobe.CoolType (AdobeCoolType 5.14.05.41668 - 5.14.05.41668) <AD542820-E4F8-30BF-9C76-7CB11800A9BB> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
   0x10e6b7000 -    0x10e7edfff +com.adobe.AIDE (1.5.0 - 1.5.0.34124) <CE69D37F-2D03-3B1D-8E63-C04CCC3FC37A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
   0x10e85d000 -    0x10e863fff +com.adobe.AdobeCrashReporter (7.7 - 7.7.0) <FA36FB74-CC30-3BFC-BC2C-4025E64F8C6A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
   0x10f279000 -    0x10f2a9fff +com.adobe.ARE (AdobeARE 1.5.02.41668 - 1.5.02.41668) <5603CC0B-15B4-3855-8BF6-6CC317CD471B> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
   0x10fdf8000 -    0x10fe766a7  dyld (635.2) <1780094A-8FE2-3EAA-B4A3-C4CF14BC5196> /usr/lib/dyld
   0x10fed9000 -    0x112436fff +com.adobe.Acrobat.framework (19.008.20080 - 19.008.20080) <4081F060-407B-30DB-9CBB-0AC54A0519DE> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
   0x114a90000 -    0x114a93047  libobjc-trampolines.dylib (750.1) <EAFE392F-7BD6-3988-9C6F-DFD359AE0AD3> /usr/lib/libobjc-trampolines.dylib
   0x114b6d000 -    0x114b71fff +AcrobatUpdateHelperLib.dylib (1) <3F981C5B-F26C-32CA-B4DA-B01D5884F76D> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib
   0x114bf6000 -    0x114c28ff7 +com.adobe.pip (7.4.1.11.44704) <E684FABD-A1CD-329F-80BE-AF6C2FEB415F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
   0x114c5e000 -    0x114c80ff7 +com.adobe.AcrobatPlugin.Updater (19.008.20071 - 19.008.20071) <F301A429-1043-3C3A-8241-5F23C69E9A99> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater
   0x114c8a000 -    0x114ca9fff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <0B2D4DF2-8040-3205-B7E4-220385090BB9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
   0x114cf3000 -    0x114d81ff7 +com.adobe.AcrobatPlugin.PDDom (19.008.20071 - 19.008.20071) <3473DC10-EEF6-3AE0-BCB5-E37506397DDE> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/PDDom.acroplugin/Contents/MacOS/PDDom
   0x115118000 -    0x1152dbff7 +com.adobe.amtlib (10.0.0.274 - 10.0.0.274) <36A6E7C9-2F17-3B9B-87B4-893566003D72> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib
   0x1155bd000 -    0x115711fff +com.quite.plugin.QI+ 4 XB (4.0c  - 4.0.2r1) <3FE6EBB7-681F-3EE4-BDE7-26589765724A> /Library/Application Support/Adobe/*/QI+ 4 XB
   0x119752000 -    0x119772ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.41773 - 3.9.0.41773) <290F26BE-690E-3264-850B-23A145F67798> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
   0x119797000 -    0x1197d5ff7 +libcryptocme.dylib (0) <FBB5731B-265B-32EB-A2A2-78FD28833E45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libcryptocme.dylib
   0x1197ed000 -    0x11984bff7 +libccme_base.dylib (0) <59589393-1392-3DAA-8F3F-8840826C9420> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base.dylib
   0x119876000 -    0x1198acfff +libccme_asym.dylib (0) <F7C87F5D-DCB5-3C46-BDB6-5CD936125F18> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_asym.dylib
   0x1198c7000 -    0x11998aff7 +libccme_ecc_accel_fips.dylib (0) <ECA407E7-BD54-34A6-B85B-E99EEE6A9F45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc_accel_fips.dylib
   0x119992000 -    0x1199fbff7 +libccme_ecc.dylib (0) <DA65C6FE-D7F5-305E-BF42-CA3AD7B6C554> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc.dylib
   0x119a32000 -    0x119a8bff7 +libccme_base_non_fips.dylib (0) <FF0F0C06-3F5D-3BA4-9CFB-E90702E171F1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base_non_fips.dylib
   0x119b2d000 -    0x119b2fffb  com.apple.textencoding.unicode (5.0 - 5.0) <8F8EAF7E-BE4A-363A-A855-B817C81CF951> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
   0x119c92000 -    0x119dd0fff +com.adobe.headlights.LogSessionFramework (7.4.1.11.44704) <3FB068A4-9343-3185-870E-F922267BFA19> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/LogSession.framework/LogSession
   0x11aa45000 -    0x11b1e8ff7 +com.adobe.AcrobatPlugin.Comments (19.008.20080 - 19.008.20080) <BBE19F81-7C9B-3A0B-9CF4-82B7BE188A46> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments
   0x11b3ee000 -    0x11b53eff7 +IMSLib.dylib (10.0.0.35 - 10.0.0.35) <0F67F73D-2BD4-3432-AB6F-47C632068CBB> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib
   0x11b607000 -    0x11b692ff7 +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <71CC53CB-2483-3BEC-A044-04EF257425DB> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
   0x11b925000 -    0x11b949ff7 +com.adobe.AcrobatPlugin.EFS (19.008.20071 - 19.008.20071) <185C5BB2-3CE9-3893-8958-69EA0475FD04> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS
   0x11ba03000 -    0x11ba5bff7 +com.adobe.AcrobatPlugin.Spelling (19.008.20071 - 19.008.20071) <48C860BB-E2F4-3F47-BC4A-74D7EADC86D7> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Spelling.acroplugin/Contents/MacOS/Spelling
   0x11ba67000 -    0x11bad3fff +com.adobe.linguistic.LinguisticManager (13.0.0 - 23526) <93A6AC53-0C96-31C5-9AFB-06087D7BAE0A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
   0x11cf50000 -    0x11d081fff +com.adobe.ICUUnicode (58.2 - 3.61) <550AB59F-78EF-35F4-8F94-AD3EE47B603E> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUUnicode.framework/Versions/58.2/ICUUnicode
   0x11d0f0000 -    0x11d1ddff7 +com.lextek.onix (3.16.2.5 - 3.16.2.5) <96673EB4-7999-31D0-915B-628DB0757858> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Onix.framework/Onix
   0x11d3a4000 -    0x11d50bfff +com.adobe.AcrobatPlugin.DigSig (19.008.20071 - 19.008.20071) <B3FF4ED6-A280-3B63-A1A8-84F1EF3EB514> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/DigSig.acroplugin/Contents/MacOS/DigSig
   0x11d527000 -    0x11de65fff +com.adobe.AcrobatPlugin.PPKLite (19.008.20080 - 19.008.20080) <115B8015-53F5-3E26-A9E8-1262F44B8EF5> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/PPKLite.acroplugin/Contents/MacOS/PPKLite
   0x11df0c000 -    0x11df98fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 15 - 91.163280) <1F825AAD-53E1-3053-A4B1-E71E1F4DE216> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
   0x120262000 -    0x121098fff +com.adobe.AcrobatPlugin.AcroForm (19.008.20071 - 19.008.20071) <4006C196-90AF-390B-83D3-489D38D55790> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/AcroForm.acroplugin/Contents/MacOS/AcroForm
   0x121513000 -    0x12184dff7 +com.adobe.AcrobatPlugin.EScript (19.008.20071 - 19.008.20071) <B724F036-A0BA-308E-862A-4480EE339D24> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EScript.acroplugin/Contents/MacOS/EScript
   0x12c66c000 -    0x12df6cfff +com.adobe.ICUData (58.2 - 3.61) <EA74F255-A2C8-3749-9DA5-071E6AED9FC2> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUData.framework/Versions/58.2/ICUData
   0x130174000 -    0x130236ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.41572) <89226A68-F0F9-3517-8DF5-24DB610A2C98> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x7fff3ff3f000 - 0x7fff3ff5aff7  libJapaneseConverter.dylib (73) <BFCBCBC5-3925-3A25-B13F-A8F3ECE5DE3A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x7fff3ffc0000 - 0x7fff40339fff  com.apple.RawCamera.bundle (8.11.0 - 1031.1.3) <FE033C75-0F5C-3F38-8A11-36A32E9D3F47> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff4033c000 - 0x7fff40487ff7  com.apple.AMDMTLBronzeDriver (2.2.8 - 2.0.2) <DEFFC096-0D52-3F03-A7B5-DE22B4810D75> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff460ba000 - 0x7fff462a8fff  com.apple.avfoundation (2.0 - 1542.10.104.1) <A3A0B581-CA6E-31E1-AE67-5DB8EABFEA04> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff462a9000 - 0x7fff46378fff  com.apple.audio.AVFAudio (1.0 - ???) <6FB8FD22-713D-347C-8278-9170077EE8AD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff46486000 - 0x7fff46486fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <A09CB6D5-3F8A-3E05-B0EB-63878296A059> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff46487000 - 0x7fff4649dfef  libCGInterfaces.dylib (506.19.1) <8A894DB4-A48B-31A0-9316-DC41061D9549> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff4649e000 - 0x7fff46b3efe3  com.apple.vImage (8.1 - ???) <DB23E2A0-EA06-3073-AA7E-2873556714A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff46b3f000 - 0x7fff46db6fd7  libBLAS.dylib (1243.200.4) <76710990-AE2B-300E-88BB-797ABAD74956> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff46db7000 - 0x7fff46e29fe7  libBNNS.dylib (38.200.5) <5F3A4021-8FF8-30E8-B84A-AA2BD70F4151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff46e2a000 - 0x7fff471d0fff  libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff471d1000 - 0x7fff471e6ffb  libLinearAlgebra.dylib (1243.200.4) <E923DA33-B142-3A73-A80A-642878D19099> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff471e7000 - 0x7fff471ecff3  libQuadrature.dylib (3.200.2) <6FFAC142-415D-3AF0-BC09-336302F11934> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff471ed000 - 0x7fff4726affb  libSparse.dylib (79.200.5) <0D7E71A4-10D2-3979-B386-D2426ADAF6D7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff4726b000 - 0x7fff4727effb  libSparseBLAS.dylib (1243.200.4) <00D6FC17-B739-3259-90A4-92AC8BBE03D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff4727f000 - 0x7fff47463ff3  libvDSP.dylib (671.220.1) <2F576522-08B1-3C65-8F00-3427E938ADDA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff47464000 - 0x7fff47519ff3  libvMisc.dylib (671.220.1) <29F59097-A256-38E9-9D55-BF56E9139CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff4751a000 - 0x7fff4751afff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <221E4FEF-0431-3316-8281-22B6F8315A09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff4751b000 - 0x7fff4757effb  com.apple.Accounts (113 - 113) <516F1A48-D158-3888-91AC-E1C7C3F9CCDD> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff47581000 - 0x7fff476caffb  com.apple.AddressBook.framework (11.0 - 1885) <0C7FCB1A-15C2-38E8-8085-D484650F5140> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff476cb000 - 0x7fff484ebff3  com.apple.AppKit (6.9 - 1671.10.106) <179A5F4A-6467-31BD-93F2-CC27E046221E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff4853d000 - 0x7fff4853dfff  com.apple.ApplicationServices (50.1 - 50.1) <470C0943-30AD-3BA2-AFCE-EB7DD26E1709> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff4853e000 - 0x7fff485a9ff7  com.apple.ApplicationServices.ATS (377 - 453.11) <7599E619-EE21-3EB7-875B-AE3B8D3E13BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff48642000 - 0x7fff48761fff  libFontParser.dylib (228.6) <E800074F-62CF-340A-A5A7-B8BE5B560045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff48762000 - 0x7fff487adfff  libFontRegistry.dylib (228.12) <480D472D-C8FB-321D-86EC-2EA6927A97AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff4880c000 - 0x7fff4883fff7  libTrueTypeScaler.dylib (228.6) <D23BFDE4-8664-335A-B43B-A13A8EF29E40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff488a9000 - 0x7fff488adff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <90641B6B-D07B-3577-B594-965825544B60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff4894a000 - 0x7fff4899cff3  com.apple.HIServices (1.22 - 627.14.2) <01F309D6-32E7-3C4F-A38B-8206EE3076CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff4899d000 - 0x7fff489abff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <67BC5855-B7A3-39E6-B5DD-52B287EB1532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff489ac000 - 0x7fff489f8fff  com.apple.print.framework.PrintCore (14.0 - 503.7) <C13BC56A-65F4-35B1-9E33-51FE6F3B06FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff489f9000 - 0x7fff48a34ff7  com.apple.QD (3.12 - 407.2) <94A30038-C545-327A-B1C0-E19C79D62BAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff48a35000 - 0x7fff48a41ff7  com.apple.speech.synthesis.framework (8.1.0 - 8.1.0) <823830AC-62A6-36CC-A659-6BC10F2AC6F5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff48a42000 - 0x7fff48cdeff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <F56518BA-B21B-32D8-B077-40A989815F46> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff48ce0000 - 0x7fff48ce0fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <B0F229C4-E8AF-3EB3-8241-7576A115D69F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff49044000 - 0x7fff49405ff7  com.apple.CFNetwork (975.0.3 - 975.0.3) <99BD4FA0-8BD3-35E5-8FB1-C757D439716C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff4941a000 - 0x7fff4941afff  com.apple.Carbon (158 - 158) <BF1EC28F-CBA8-3B2F-B9FA-E583BC2D6C1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff4941b000 - 0x7fff4941effb  com.apple.CommonPanels (1.2.6 - 98) <F1E1C47B-FD1A-30A4-B41B-87BD8B178B56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff4941f000 - 0x7fff49726ff7  com.apple.HIToolbox (2.1.1 - 917.2) <0B91F11C-0895-3A7B-9A3B-2B6B1267EA1A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff49727000 - 0x7fff4972affb  com.apple.help (1.3.8 - 66) <4392A63F-9B58-3248-BF73-B46AD3744E6E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff4972b000 - 0x7fff49730ff7  com.apple.ImageCapture (9.0 - 1530.1) <47915C3C-DED4-3E0C-9155-6B130FFF89BB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff49731000 - 0x7fff497c5ff3  com.apple.ink.framework (10.9 - 225) <D6503F37-7EBC-32C1-95CC-A35EFC54E7ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff497c6000 - 0x7fff497e0fff  com.apple.openscripting (1.7 - 179) <BDE14D25-4D82-3EBC-8EF2-D1F6BC957B07> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff49801000 - 0x7fff49802fff  com.apple.print.framework.Print (14.0 - 267.3) <5CD250DF-98AD-30B8-A5D5-47634FF9E74D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff49803000 - 0x7fff49805ff7  com.apple.securityhi (9.0 - 55006) <C5308CBC-6736-31A7-905B-C635C6D43FDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff49806000 - 0x7fff4980cff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C38B9CB-DD45-3A7B-9D4C-631855A4EE32> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff4980d000 - 0x7fff49932fff  com.apple.cloudkit.CloudKit (736.130 - 736.130) <049A491D-025D-3DD6-8EC9-5BFD4B96A809> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff49933000 - 0x7fff49933fff  com.apple.Cocoa (6.11 - 23) <4D5D4968-E233-3598-B434-E1009D48A628> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff49941000 - 0x7fff49a0dfff  com.apple.ColorSync (4.13.0 - 3340) <0618DA46-5A5E-339D-BB2F-ED66A2BFCCF9> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff49a0e000 - 0x7fff49b02ff3  com.apple.contacts (1.0 - 2900) <E5A10BFE-FAE6-3B2B-BC2F-44EB262EEA06> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
0x7fff49ba8000 - 0x7fff49c38fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A7F8E168-AB1D-36F4-9693-CFEF12BC197D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff49c9e000 - 0x7fff49cc9ff7  com.apple.CoreBluetooth (1.0 - 1) <61235BEA-BF5F-31B2-B9C1-DE722E15840F> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff49cca000 - 0x7fff4a06bfef  com.apple.CoreData (120 - 866.1) <B74013FA-621B-30F9-8CFE-3290FF63C2B8> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff4a06c000 - 0x7fff4a155ff7  com.apple.CoreDisplay (101.3 - 104.4) <52C96B6A-B119-3BE2-B47D-65F12E987609> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff4a156000 - 0x7fff4a5a3fe7  com.apple.CoreFoundation (6.9 - 1560.12) <B5BDC307-6C89-3DE0-B4B9-4C2C650E4528> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff4a5a5000 - 0x7fff4ac32ff7  com.apple.CoreGraphics (2.0 - 1247.4.1) <D2F1DD53-09BD-307B-8B80-46B259530ED8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff4ac34000 - 0x7fff4af5dfff  com.apple.CoreImage (14.1.0 - 710.2.240) <CAEE3AAA-0781-311A-B987-72C7332C1A3F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff4af5e000 - 0x7fff4afdffff  com.apple.corelocation (2245.8.12) <F5E2C817-2D01-3401-89F0-B024FE296FC6> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff4b03f000 - 0x7fff4b2adff7  com.apple.CoreML (1.0 - 1) <A6C41E33-935A-3C1A-9FC3-0372E580A5D7> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff4b2ae000 - 0x7fff4b3afff3  com.apple.CoreMedia (1.0 - 2282.19.104.4) <2FF4819F-0D06-38D5-9403-4DA3F6F37D76> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4b3b0000 - 0x7fff4b412fff  com.apple.CoreMediaIO (900.0 - 5025) <A9CC940A-9E7C-35A4-A1E6-DADD66200378> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff4b413000 - 0x7fff4b413fff  com.apple.CoreServices (934 - 934) <EBA4A3BF-0B07-3E1B-9C14-8E6879453C6C> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff4b414000 - 0x7fff4b492ffb  com.apple.AE (771 - 771) <BBFEAB6C-B1F9-3D22-934E-8298155AC459> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff4b493000 - 0x7fff4b76bff7  com.apple.CoreServices.CarbonCore (1178.11 - 1178.11) <9FBE7BFB-3A81-37AC-8E15-E6F7932BBDC0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff4b76c000 - 0x7fff4b7b6ff7  com.apple.DictionaryServices (1.2 - 284.16.3) <D9388630-E7F2-321E-81FF-EBD5F3B47A52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff4b7b7000 - 0x7fff4b7bfffb  com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <E40A3C4A-79C7-37D8-999B-D1169A06870B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff4b7c0000 - 0x7fff4b98bfff  com.apple.LaunchServices (934 - 934) <FD3D313D-997B-388B-B208-29774CDDF897> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff4b98c000 - 0x7fff4ba2efff  com.apple.Metadata (10.7.0 - 1191.52) <5A758D93-4BBD-3C6D-861B-000536ED9B2D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff4ba2f000 - 0x7fff4ba7aff7  com.apple.CoreServices.OSServices (934 - 934) <1D2AC09A-653F-3C2D-B5B9-F9ABA307E51C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff4ba7b000 - 0x7fff4bae9ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C6A34D09-9707-3F28-838F-63B59B8A12D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff4baea000 - 0x7fff4bb0effb  com.apple.coreservices.SharedFileList (71.27 - 71.27) <B46A15E0-4C10-3616-BE49-58E07EC463FE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff4be56000 - 0x7fff4bfbbffb  com.apple.CoreText (352.0 - 584.25) <AC3B4909-564A-3C26-B055-7687E5DE1697> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff4bfbc000 - 0x7fff4bff9fff  com.apple.CoreVideo (1.8 - 0.0) <C7BB7D0F-3AF2-3046-A387-A802BCA52A3A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff4bffa000 - 0x7fff4c090ffb  com.apple.framework.CoreWLAN (13.0 - 1370.8) <735EEBA3-C63B-38C8-A1A7-23B12C2E9550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4c220000 - 0x7fff4c22bffb  com.apple.DirectoryService.Framework (10.14 - 207.200.4) <222097B7-D721-3F27-9798-ACC95E73F233> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff4c22c000 - 0x7fff4c2e6ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <9F007E61-83AD-3DB5-B3D5-CB4F1EDF746A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff4c30d000 - 0x7fff4c312fff  com.apple.DiskArbitration (2.7 - 2.7) <C53C1905-9BCF-3AE8-8BB3-C8A2C7DB7D25> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff4c4db000 - 0x7fff4c8a9fff  com.apple.Foundation (6.9 - 1560.12) <B5DC275C-12C9-320A-A117-C8FE9034931A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff4c91a000 - 0x7fff4c94aff3  com.apple.GSS (4.0 - 2.0) <721B6FEF-9E0E-311B-8CAF-93ADEE2AE548> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff4ca64000 - 0x7fff4cb6eff3  com.apple.Bluetooth (6.0.9 - 6.0.9f2) <0EDECAF3-FF86-3F7D-B916-2D7E67FF67AE> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff4cbd0000 - 0x7fff4cc62ff7  com.apple.framework.IOKit (2.0.2 - 1483.220.15) <B58031DE-A6B7-3685-840F-361670C06836> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff4cc64000 - 0x7fff4cc6eff7  com.apple.IOSurface (255.1 - 255.1) <538F0257-A408-36AF-AB1E-1D7037D6359E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff4cc6f000 - 0x7fff4ccc4ff3  com.apple.ImageCaptureCore (1.0 - 1530.1) <C053A62A-AA27-3E5F-97EE-8781E75028EB> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff4ccc5000 - 0x7fff4ce63fff  com.apple.ImageIO.framework (3.3.0 - 1821.6.4.1) <00BF9654-021D-33C7-B681-461F3EF357FD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff4ce64000 - 0x7fff4ce68ffb  libGIF.dylib (1821.6.4.1) <032CA0C2-8AAA-3D3F-8E61-25CE9267C2A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff4ce69000 - 0x7fff4cf4efef  libJP2.dylib (1821.6.4.1) <FED43EEB-2B6C-32FC-94A2-297DA8CE4D87> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff4cf4f000 - 0x7fff4cf74ff7  libJPEG.dylib (1821.6.4.1) <DD334010-2B8D-3A5E-BC17-39A9D94AC92D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff4d247000 - 0x7fff4d26dfe7  libPng.dylib (1821.6.4.1) <EBAAB8C0-33A7-3C13-B96C-8B6AB8287C7A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff4d26e000 - 0x7fff4d270ff7  libRadiance.dylib (1821.6.4.1) <E9BCF8B3-DA07-3F80-B51F-5793BD38AE4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff4d271000 - 0x7fff4d2bffff  libTIFF.dylib (1821.6.4.1) <C432D21E-2DA5-3B69-BD04-BA7B6DBEAE2F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff4d5c1000 - 0x7fff4e344fff  com.apple.JavaScriptCore (14606 - 14606.2.104.1.1) <3313A815-BFC9-3DED-B778-FCE6F8367A7C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff4e35c000 - 0x7fff4e375fff  com.apple.Kerberos (3.0 - 1) <8BE3D524-257D-3663-A937-F1AC76BDF4D9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff4e376000 - 0x7fff4e3abffb  com.apple.LDAPFramework (2.4.28 - 194.5) <DC361FB9-4B59-311E-8CC5-07FF9A9C673F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff4e633000 - 0x7fff4e63dfff  com.apple.MediaAccessibility (1.0 - 114.4) <29D89F2B-6254-3D0D-BD0C-8472FCA373F4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff4e6f7000 - 0x7fff4ed94fff  com.apple.MediaToolbox (1.0 - 2282.19.104.4) <7603C180-8050-3355-A851-A67B6A4197AD> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff4ed96000 - 0x7fff4ee29fff  com.apple.Metal (157.60 - 157.60) <B38C577A-CD24-30AD-A396-219945949F39> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff4ee2b000 - 0x7fff4ee45ff3  com.apple.MetalKit (1.0 - 113) <8949A0FA-337E-3C28-94D1-35853D69761B> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff4ee46000 - 0x7fff4ee66ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <A9E87429-4788-3B2F-B970-4052F16C5961> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff4ee67000 - 0x7fff4eee5ff7  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <80DE2FD1-85DB-3E98-98BD-F22A2600DD25> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff4eee6000 - 0x7fff4ef0efff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <49039DEE-D0EC-33FF-BE10-997A520D2E38> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff4ef0f000 - 0x7fff4f041ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <425D1FA4-17A3-3D00-8BE4-7A682FF279B5> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff4f042000 - 0x7fff4f05dff7  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <BB1651A0-05CD-3F97-8355-39CD326C0AFD> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff4f05e000 - 0x7fff4f05eff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <3910EC50-5B16-3695-B867-741E3B54FA8B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff5025d000 - 0x7fff50269ffb  com.apple.NetFS (6.0 - 4.0) <529E29A9-5E77-3A8C-A982-CF55F949FE5D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff5026a000 - 0x7fff503a9ff7  com.apple.Network (1.0 - 1) <ADE86D62-7847-32D4-96E7-FD05CFC20B97> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff52d29000 - 0x7fff52d81ff7  com.apple.opencl (2.12.7 - 2.12.7) <CCAC9774-C4BF-33C1-AC87-F2AEB972632F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff52d82000 - 0x7fff52d9eff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <7E4EFF02-2596-31E6-88DE-29C89E2837E4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff52d9f000 - 0x7fff52dabffb  com.apple.OpenDirectory (10.14 - 207.200.4) <52A3918E-0F7A-33FD-87EE-21A37B37D13B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff5370e000 - 0x7fff53710fff  libCVMSPluginSupport.dylib (17.0.37) <E47B2819-913A-3588-A3F5-CE3EDA8551A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff53711000 - 0x7fff53716ff3  libCoreFSCache.dylib (163.20) <BF8F04DD-C1A1-3D2A-BF3F-639FE907E28D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff53717000 - 0x7fff5371bfff  libCoreVMClient.dylib (163.20) <45A2C724-F3D1-316A-9A41-CAB8E2A390EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff5371c000 - 0x7fff53724ffb  libGFXShared.dylib (17.0.37) <C26CA5C7-8DFC-3BE9-9873-C7A51F139FB0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff53725000 - 0x7fff53730fff  libGL.dylib (17.0.37) <8DCB2714-ECB1-39EC-931D-C58D9E91B51C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff53731000 - 0x7fff5376bfef  libGLImage.dylib (17.0.37) <B64C775F-C64F-35D7-8179-1E4F20E76BA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff538df000 - 0x7fff5391cfff  libGLU.dylib (17.0.37) <B0D434EF-F5AC-3C0A-84DF-FFAFC57F3759> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff542cc000 - 0x7fff542dbff3  com.apple.opengl (17.0.37 - 17.0.37) <6BCCA53E-5621-32ED-BA9A-38B1C2499ED5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff5465d000 - 0x7fff547a7fff  com.apple.QTKit (7.7.3 - 3034) <D612DC6C-0AA8-3D41-9E17-E8219984FC65> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff547a8000 - 0x7fff54a03fff  com.apple.imageKit (3.0 - 1067) <A43B90AB-8FCB-35BF-996A-CEB28B67EEB5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff54a04000 - 0x7fff54af0fff  com.apple.PDFKit (1.0 - 737.3) <F6981903-7259-3D89-B70E-855F970D84E7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff54af1000 - 0x7fff55007ff7  com.apple.QuartzComposer (5.1 - 370) <AA2ED670-1970-3888-B7DB-D11192EBF6BB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff55008000 - 0x7fff5502eff3  com.apple.quartzfilters (1.10.0 - 83) <06F25528-5474-39BF-BCD4-DD6B3203EA3C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff5502f000 - 0x7fff55135ff7  com.apple.QuickLookUIFramework (5.0 - 775) <41F1FDD0-C99A-36D3-AC3A-A5E604D77F63> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff55136000 - 0x7fff55136fff  com.apple.quartzframework (1.5 - 23) <EB8812C6-F126-3262-9B6A-A7A440DFBF8A> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff55137000 - 0x7fff5538ffff  com.apple.QuartzCore (1.11 - 694.22.4.1) <1F5A49A9-370C-311B-B67C-DEA6DF6D2983> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff55390000 - 0x7fff553e9ff7  com.apple.QuickLookFramework (5.0 - 775) <A4CA709A-2828-3F04-8786-7FAC8A95B98B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff555b0000 - 0x7fff555c8ffb  com.apple.SafariServices.framework (14606 - 14606.2.104.1.1) <189C4DE0-5B88-388F-9CD1-AC15C3936CC2> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff55bc4000 - 0x7fff55bdcfff  com.apple.ScriptingBridge (1.4 - 77) <3502C869-965C-3D65-AC25-D18636CBA127> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff55bdd000 - 0x7fff55f03ff7  com.apple.security (7.0 - 58286.220.15) <6725D63D-378F-3751-8602-3122016E4AA4> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff55f04000 - 0x7fff55f93fff  com.apple.securityfoundation (6.0 - 55185.200.14) <236BACD7-163F-3F35-B710-2C62988AA251> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff55f94000 - 0x7fff55fc4ffb  com.apple.securityinterface (10.0 - 55109.200.8) <F2E44252-2A22-30FD-9706-E33EF75C3ED2> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff55fc5000 - 0x7fff55fc9ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <C200EC23-CAFB-33E8-AF3D-5B36420A21B1> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff55fca000 - 0x7fff56013ff3  com.apple.sociald.Social (???) <85FFE5E9-1201-359D-A9BC-20EC07B2F0B6> /System/Library/Frameworks/Social.framework/Versions/A/Social
0x7fff56386000 - 0x7fff563f6ff3  com.apple.SystemConfiguration (1.17 - 1.17) <EED5BC9B-CE8D-343C-BCDC-04A79F704828> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff56657000 - 0x7fff569b9ff7  com.apple.VideoToolbox (1.0 - 2282.19.104.4) <AA64D2D5-B992-301C-B39E-90852E2DFC95> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff56cc7000 - 0x7fff57255fe7  libwebrtc.dylib (7606.2.104.1.1) <813EBF5C-B865-3A01-BF1F-8DB7A287FF35> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff57256000 - 0x7fff58ad8ff3  com.apple.WebCore (14606 - 14606.2.104.1.1) <50CEEC5A-34FC-339A-A05F-257D9D0F4666> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff58ad9000 - 0x7fff58cc8ffb  com.apple.WebKitLegacy (14606 - 14606.2.104.1.1) <D42DC5C3-C35F-3990-A7CE-9871C4F4902C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff58cc9000 - 0x7fff591c6ff7  com.apple.WebKit (14606 - 14606.2.104.1.1) <BFA28A42-A2DA-31A7-86F9-4838F5FEC3B1> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff5965d000 - 0x7fff59702fe7  com.apple.APFS (1.0 - 1) <E00222C4-E8CF-302A-8AF3-E8BB9B1C3B0E> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff59c98000 - 0x7fff59ca2fff  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <5C60531F-2E5F-3837-B1FC-2E933A774ED0> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff59e81000 - 0x7fff59f24ffb  com.apple.accounts.AccountsDaemon (113 - 113) <BA3596C5-E05F-3342-91F6-92D40E904756> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
0x7fff59f25000 - 0x7fff59f56ff7  com.apple.framework.accountsui (1.0 - 63.1.0.4) <F86129B4-A5C7-3B0E-A579-084A0FB0DBE2> /System/Library/PrivateFrameworks/AccountsUI.framework/Versions/A/AccountsUI
0x7fff59fd4000 - 0x7fff5a130ffb  com.apple.AddressBook.core (1.0 - 1) <55D01A2A-C878-3089-8615-F3510A5B1687> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore
0x7fff5a14c000 - 0x7fff5a14dff3  com.apple.AggregateDictionary (1.0 - 1) <1DEBBE36-8945-3AD8-BD48-2850AD845711> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff5a4fa000 - 0x7fff5a643ff3  com.apple.AnnotationKit (1.0 - 232.3.27) <6CDA223B-CBDF-3960-AC34-BAD648CB580B> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff5a749000 - 0x7fff5a775ff7  com.apple.framework.Apple80211 (13.0 - 1376.2) <821DE2A3-1CAD-3A7D-A2DD-41EBA3A6FEF3> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff5aa51000 - 0x7fff5aa60fcf  com.apple.AppleFSCompression (96.200.3 - 1.0) <E093776E-C367-3CCF-BFD5-623476A89E9A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff5ab5e000 - 0x7fff5ab69fff  com.apple.AppleIDAuthSupport (1.0 - 1) <5362D9AD-A2AE-3436-97CE-C353124504E5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff5abaa000 - 0x7fff5abf3ff3  com.apple.AppleJPEG (1.0 - 1) <9A690E6E-F987-3660-BED6-B1A4D1906B6C> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff5abf4000 - 0x7fff5ac04ff3  com.apple.AppleLDAP (10.14 - 46.200.2) <1CA0C188-D060-3B80-84A1-6FA90812AF11> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP
0x7fff5ae1f000 - 0x7fff5ae3fffb  com.apple.aps.framework (4.0 - 4.0) <F737E01A-E9D1-3A9A-B54B-CA1B9750A08D> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff5ae40000 - 0x7fff5ae44ff7  com.apple.AppleSRP (5.0 - 1) <B8E2BEC9-FAFB-3E26-BF26-E2E58C545006> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff5ae45000 - 0x7fff5ae6dff7  com.apple.applesauce (1.0 - ???) <60BB16D6-DE7E-356A-B9DE-F73EE179934A> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff5af34000 - 0x7fff5af37ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A2EE39BD-C721-33BD-8549-E087C04CF784> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff5af38000 - 0x7fff5af88fff  com.apple.AppleVAFramework (5.0.44 - 5.0.44) <A7D2AD26-D52A-39E0-8296-1ADDDB6B6CED> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff5afd3000 - 0x7fff5afe9ffb  com.apple.AssertionServices (1.0 - 1) <8FB0D908-6C46-3399-92D6-4E7D4B5F4F19> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff5b325000 - 0x7fff5b5c8ffb  com.apple.AuthKit (1.0 - 1) <8920796A-C818-3163-B6D0-FD05D1A6ADF5> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff5b799000 - 0x7fff5b7a2ff3  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <972F41B3-7DF7-3BF1-ACCA-A093A4328ADF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff5b7a3000 - 0x7fff5b845ff7  com.apple.backup.framework (1.10 - ???) <46534B04-DD0E-357B-9CB5-F88AAC6AF4ED> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff5b846000 - 0x7fff5b8b7ffb  com.apple.BaseBoard (360.24 - 360.24) <AC0E4924-994E-3B54-869C-C831B4DE0136> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff5b8c0000 - 0x7fff5b8c6ff3  com.apple.BezelServicesFW (317 - 317) <44601C3E-4808-38A4-A554-71F36000B003> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0x7fff5b940000 - 0x7fff5b97cffb  com.apple.bom (14.0 - 197) <8BD14107-DB70-3800-9377-618CA230B40A> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff5c04a000 - 0x7fff5c078fff  com.apple.CalendarAgentLink (8.0 - 250) <3741CC99-814F-3E74-97A7-B658D8DB5C72> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fff5c75b000 - 0x7fff5c7a8fff  com.apple.ChunkingLibrary (194 - 194) <13F1F769-E8E7-372A-8F0B-2BB4B7753248> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff5c850000 - 0x7fff5c8dfffb  com.apple.CloudDocs (1.0 - 575.120) <94232936-1B40-3EAF-B731-883A4872BCE4> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff5d468000 - 0x7fff5d471fff  com.apple.CommonAuth (4.0 - 2.0) <93CF1D80-A3A8-378B-9DF7-BF17A206C57D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff5d485000 - 0x7fff5d49bffb  com.apple.commonutilities (8.0 - 900) <BE71A0AD-7ED9-3B2A-BF7D-DA7841640FE0> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff5d74f000 - 0x7fff5d7b9ff7  com.apple.AddressBook.ContactsFoundation (8.0 - ???) <2A910333-619F-3A27-B40E-0A4BF0F75AA8> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff5d7ba000 - 0x7fff5d7deffb  com.apple.contacts.ContactsPersistence (1.0 - ???) <6CE2F528-5CD6-35AE-B5BB-30070C5755B6> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff5d931000 - 0x7fff5dd08fef  com.apple.CoreAUC (273.0.0 - 273.0.0) <288EC7ED-A86A-30D0-ADE2-56C33CD93AA8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff5dd09000 - 0x7fff5dd3afff  com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <507AC58B-4527-353B-99CB-67FF183BD4D5> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff5dd58000 - 0x7fff5dd7afff  com.apple.CoreAnalytics.CoreAnalytics (1.0 - 1) <698E1B63-B193-3431-A1C7-9B8D2D62088C> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff5ddd2000 - 0x7fff5de24ffb  com.apple.corebrightness (1.0 - 1) <1AE1A7AE-506D-3A52-B710-9CFB16414EDC> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff5df68000 - 0x7fff5df71fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8D971ACD-6A26-30A9-9C5B-BCBF60A661F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff5e183000 - 0x7fff5e197fff  com.apple.CoreEmoji (1.0 - 69.19.8) <E909BE8D-AE0C-327E-BE0A-D60B1F4012A4> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff5e35d000 - 0x7fff5e451ff7  com.apple.CoreHandwriting (161 - 1.2) <0BD558D9-387B-34BA-8FAA-F1F75F1F9F01> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff5e614000 - 0x7fff5e62affb  com.apple.CoreMediaAuthoring (2.2 - 958) <FD761818-0B54-3DA6-B41C-20263BC2EDAE> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff5e76d000 - 0x7fff5e7dfff7  com.apple.CoreNLP (1.0 - 130.15.22) <401F5284-A984-32A1-A547-CC8156381070> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff5e962000 - 0x7fff5e966ff7  com.apple.CoreOptimization (1.0 - 1) <AEF88F43-C928-3DCB-95D6-C6706B565422> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff5e967000 - 0x7fff5e9f4ff7  com.apple.CorePDF (4.0 - 414) <28DEBFFB-BABE-3493-8230-12CE3E5EC1E3> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff5ea9a000 - 0x7fff5eaa2ffb  com.apple.CorePhoneNumbers (1.0 - 1) <F47CA56F-6760-3282-BFD8-C8C8D2C33ECF> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff5eaa3000 - 0x7fff5eafffff  com.apple.CorePrediction (1.0 - 1) <BD34AB8C-8899-3BB1-95A2-0A2A1C901ADC> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5ec31000 - 0x7fff5ec62fff  com.apple.CoreServicesInternal (357 - 357) <2D012EB3-83BF-3E51-A2BE-41AF26F2DDF0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff5f02c000 - 0x7fff5f0baff7  com.apple.CoreSymbolication (10.1 - 64460.6) <F985088F-5323-3D84-80FE-3A3135C4A320> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff5f14a000 - 0x7fff5f276fff  com.apple.coreui (2.1 - 498.46) <7637C723-B16D-3001-B3AC-0612349D1CC5> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff5f277000 - 0x7fff5f3fcfff  com.apple.CoreUtils (5.7.4 - 574.17) <CA6C08FE-319A-30C6-9F07-68D12A9FA04E> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff5f453000 - 0x7fff5f4b6ffb  com.apple.framework.CoreWiFi (13.0 - 1370.8) <B44C1B90-3642-3108-96EC-5E3A8FA158E7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff5f4b7000 - 0x7fff5f4c8ffb  com.apple.CrashReporterSupport (10.13 - 938.23) <36754BB2-680F-36AE-A5DE-548B4F41F0AE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff5f54b000 - 0x7fff5f55aff3  com.apple.framework.DFRFoundation (1.0 - 211) <B11AD3BE-42D3-3274-912E-153C015D72EE> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff5f55b000 - 0x7fff5f55fff7  com.apple.DSExternalDisplay (3.1 - 380) <B6B26BB3-2DC9-34D0-817E-EB612432EC96> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff5f5a3000 - 0x7fff5f5e1fff  com.apple.datadetectors (5.0 - 390) <23B6955E-FFDD-36D3-B66C-C321D84CB1A3> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff5f5e2000 - 0x7fff5f659ffb  com.apple.datadetectorscore (7.0 - 590.24) <1C9AC888-8B75-3CF3-AD70-42D40C435E67> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff5f6a7000 - 0x7fff5f6e8fff  com.apple.DebugSymbols (185 - 185) <12419E0F-BC7A-3F3A-AA53-5F068DAED725> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff5f6e9000 - 0x7fff5f842ff7  com.apple.desktopservices (1.13.1 - ???) <D63561E0-6153-33AD-9689-E0B9167D82C8> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff5f8dd000 - 0x7fff5f8deff7  com.apple.diagnosticlogcollection (10.0 - 1000) <66A9915F-B247-38F7-A43D-0AB68CFAF6F3> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fff5f974000 - 0x7fff5fa46ff7  com.apple.DiskImagesFramework (480.220.2 - 480.220.2) <9921E083-1159-3671-92E5-868A88A11B1B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff5fa47000 - 0x7fff5fb0bfff  com.apple.DiskManagement (12.0 - 1530) <F844A618-613A-3609-9C31-621D92FB75DD> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff5fb0c000 - 0x7fff5fb10ff7  com.apple.DisplayServicesFW (3.1 - 380) <511645F4-94EB-33A0-A076-66402F52581A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff5fbb4000 - 0x7fff5fbb7fff  com.apple.EFILogin (2.0 - 2) <8FCA68D2-CEA5-39F6-B222-AC31FCF79D1D> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff60384000 - 0x7fff6039bff3  com.apple.Engram (1.0 - 1) <A7A2BA5D-34D9-30DB-BEC5-DCCBBC98BE60> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff6039c000 - 0x7fff606cffff  com.apple.vision.EspressoFramework (1.0 - 120) <7B2CB758-7FD9-3D6B-9BD4-AFD254008BEF> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff6088a000 - 0x7fff60cb2fff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <CCBC466A-1AD4-3B0B-80B2-D6CFCBB37FC0> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff60ce5000 - 0x7fff60d71ff7  com.apple.FileProvider (125.129 - 125.129) <31642A56-F183-3DA3-8713-745358CAE55D> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff60d8a000 - 0x7fff6120aff7  com.apple.FinderKit (1.7 - ???) <7D933EAA-7B52-327E-B77F-DF63A0C03481> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fff645d4000 - 0x7fff645d5fff  libmetal_timestamp.dylib (902.1.60) <16F3973E-20CB-3FFA-9C8B-A2287AF03AA0> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff65c7a000 - 0x7fff65c7fff7  com.apple.GPUWrangler (3.25.6 - 3.25.6) <F65BC9B4-77AB-3254-8432-9F7D3B0E169E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff6602f000 - 0x7fff66054ff7  com.apple.GenerationalStorage (2.0 - 285.101) <089301DF-60C9-3BED-9357-2F91336C1579> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff6606d000 - 0x7fff66aa2ff7  com.apple.GeoServices (1.0 - 1364.21.8.31.5) <8C22C9A9-B322-3CED-9714-9F3365845C4C> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff66ae5000 - 0x7fff66af4fff  com.apple.GraphVisualizer (1.0 - 5) <C7040CD7-6CAB-3878-B29E-21F1665341D0> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff66af5000 - 0x7fff66b02fff  com.apple.GraphicsServices (1.0 - 1.0) <F099E6ED-E08D-3F37-B381-0DF3109B27AA> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff66c45000 - 0x7fff66cbafff  com.apple.Heimdal (4.0 - 2.0) <D3A3285B-A45D-38A9-A4E9-D58D76674071> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff66cbb000 - 0x7fff66ceafff  com.apple.HelpData (2.3 - 184) <56A7277E-B1C3-3AD8-AF4B-8BAA41D6E640> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff67793000 - 0x7fff678a2ff3  com.apple.ids (10.0 - 1000) <63A00A35-7F7B-34FF-B9B2-160CD6E4697E> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff678a3000 - 0x7fff679aafff  com.apple.idsfoundation (10.0 - 1000) <7E85F5A1-C419-3F47-9E6F-81EFE1D2EFB1> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff67f63000 - 0x7fff67fc8ff3  com.apple.imfoundation (10.0 - 1000) <0B3040A6-7DD8-3C63-BECC-F0846DDC368C> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff6809c000 - 0x7fff680a5fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <DCE6223D-D65D-39F2-90BC-34A1808EF6BD> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff680a6000 - 0x7fff680adffb  com.apple.IOAccelerator (400.27 - 400.27) <6FA8A133-57A7-3C35-BF94-8469B09885FB> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff680b1000 - 0x7fff680cafff  com.apple.IOPresentment (1.0 - 42.6) <C115E88F-5E16-3804-8ACD-29C0F8895EFA> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff684df000 - 0x7fff6850eff7  com.apple.IconServices (379 - 379) <0A25D75C-35A7-3ED5-8900-EBC05522B5A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff68639000 - 0x7fff6863dfff  com.apple.InternationalSupport (1.0 - 10.15.6) <F0E300AD-1E67-3D57-B179-C2212F7CD00C> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff686aa000 - 0x7fff686b7fff  com.apple.IntlPreferences (2.0 - 227.15.8) <329CA6FA-7A55-35F2-AB6D-A6F0E65BA23F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff687ad000 - 0x7fff687c0fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <1DB4E862-C010-38BA-B535-5DAD679FEADA> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff687db000 - 0x7fff688d2fff  com.apple.LanguageModeling (1.0 - 159.15.15) <E524CC46-42C7-3046-AD6C-5D5D768EA478> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff688d3000 - 0x7fff68914ff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <90C1CFE1-9935-3F4F-8A9B-1DD697F2FF3D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff6891b000 - 0x7fff68921ff7  com.apple.LinguisticData (1.0 - 238.15.29) <A8DEE139-5D20-3BAC-AF5E-4E5E0C42C795> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff68a1a000 - 0x7fff68a1fffb  com.apple.LoginUICore (4.0 - 4.0) <2528E230-11E9-3436-ADCF-ED149F50A264> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff68a87000 - 0x7fff68aa1fff  com.apple.LookupFramework (1.2 - 251) <603045DC-6529-34F6-83B5-59065274AEC4> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
0x7fff6917f000 - 0x7fff69182fff  com.apple.Mangrove (1.0 - 25) <8744DBF9-3375-392C-8EE6-24373E0D19E8> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff6920d000 - 0x7fff6920fff3  com.apple.marco (10.0 - 1000) <994AADC2-F63E-3AA3-9059-15F2B45EA926> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff69210000 - 0x7fff69237ffb  com.apple.MarkupUI (1.0 - 232.3.27) <B78BC7CF-A267-3E53-A876-6F5C02BB2AB8> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff692a0000 - 0x7fff692d3ff3  com.apple.MediaKit (16 - 906) <15D4EDA2-AAAC-3CF3-BB2B-3A92AECC932D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff6967d000 - 0x7fff696a5ffb  com.apple.spotlight.metadata.utilities (1.0 - 1191.52) <38A9B11A-9D5C-3CCA-A163-EC17242FDC68> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff696a6000 - 0x7fff69738fff  com.apple.gpusw.MetalTools (1.0 - 1) <5B86F005-D12D-3B0B-8906-808926D3DA12> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff6974d000 - 0x7fff69766fff  com.apple.MobileAssets (1.0 - 437.200.49) <0C9B7077-BFCF-3A2E-8F54-D7C2820893FD> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff698e2000 - 0x7fff698fdff3  com.apple.MobileKeyBag (2.0 - 1.0) <6E36F030-D7E8-341D-A493-414F5E13B1E9> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff6990e000 - 0x7fff6998aff7  com.apple.Montreal (1.0 - 42.15.8) <F7AAEEC2-B981-30C4-995F-4D98FB808984> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff6998b000 - 0x7fff699b5ff7  com.apple.MultitouchSupport.framework (2410.5 - 2410.5) <8D87A3ED-4CBD-300F-92E3-B1B79D7E0BF3> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff69c28000 - 0x7fff69c32fff  com.apple.NetAuth (6.2 - 6.2) <55DC741A-A01A-380C-B2D3-244241DA1F2C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff6a3b7000 - 0x7fff6a3b9fff  com.apple.OAuth (25 - 25) <8938B438-399A-3B1A-99DF-956A5A5BF8FF> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fff6a4fe000 - 0x7fff6a554fff  com.apple.OTSVG (1.0 - ???) <5F2E7A0E-384E-3545-A9D5-EC4406E92AF4> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff6b5b3000 - 0x7fff6b6b9ff7  com.apple.PencilKit (1.0 - 1) <188DB13A-53B4-3F3C-8433-193AEAFDF17D> /System/Library/PrivateFrameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff6b6ba000 - 0x7fff6b6c9ff3  com.apple.PerformanceAnalysis (1.217 - 217) <8560F263-31F4-3CCA-84B1-30C296DC1A7D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff6b924000 - 0x7fff6b924fff  com.apple.PhoneNumbers (1.0 - 1) <739CE787-1F32-3EE3-90C7-4D0522A25092> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff6d1e1000 - 0x7fff6d206ff7  com.apple.pluginkit.framework (1.0 - 1) <279FC41A-AEAA-3400-9AE7-1FC6E53BC549> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff6d231000 - 0x7fff6d243ff3  com.apple.PowerLog (1.0 - 1) <F9F2A6D3-79EB-3DFE-9197-1EA780767CC5> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff6d631000 - 0x7fff6d688ff7  com.apple.ProtectedCloudStorage (1.0 - 1) <C37D89CF-707A-3151-A37B-911AF6BF3B23> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff6d689000 - 0x7fff6d6a7ff7  com.apple.ProtocolBuffer (1 - 263) <C5AC21FB-74AD-3FC2-B231-B1376751BBAE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff6d83b000 - 0x7fff6d83eff3  com.apple.QuickLookNonBaseSystem (1.0 - 1) <ABB9436A-7E52-3232-ACE8-45083130C82A> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff6d83f000 - 0x7fff6d855ff3  com.apple.QuickLookThumbnailing (1.0 - 1) <AAF7A93C-5553-3476-B2F2-B8B1DA2BEF54> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff6d856000 - 0x7fff6d8aef0f  com.apple.ROCKit (24 - 24) <5437F6F7-453F-3D75-9E87-D2A090D82D25> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff6d9aa000 - 0x7fff6d9b6ff3  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1336.220.5) <79F17D52-38B4-360E-88AC-CF1E3944CA7E> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff6d9c9000 - 0x7fff6d9ecffb  com.apple.RemoteViewServices (2.0 - 128) <68530B4D-B2C0-3271-941B-D9EA62095727> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff6d9ed000 - 0x7fff6da01fff  com.apple.xpc.RemoteXPC (1.0 - 1336.220.5) <D258016E-4FE2-3E99-9699-33D56BADD619> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff6e85a000 - 0x7fff6e8a4ff7  com.apple.Safari.SafeBrowsing (14606 - 14606.2.104.1.1) <E7BC40BA-F760-3F28-9E07-7253A08B77D7> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff6f2d5000 - 0x7fff6f34efff  com.apple.ShareKit (577 - 577) <274D28E2-0DB2-3D22-9B3F-DC3D1A061700> /System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/ShareKit
0x7fff6f34f000 - 0x7fff6f357ffb  com.apple.coreservices.SharePointManager (1.0 - 57.1) <CC640F04-85B2-3617-B52F-1CE400549380> /System/Library/PrivateFrameworks/SharePointManagement.framework/Versions/A/SharePointManagement
0x7fff6f35c000 - 0x7fff6f47afff  com.apple.Sharing (1214.9 - 1214.9) <2A377CA5-C66F-3913-8401-951A3AE4D299> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6f47b000 - 0x7fff6f49aff3  com.apple.shortcut (2.16 - 101) <D724B49E-C972-31CC-B47C-8CB769A3E0B0> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff6f49b000 - 0x7fff6f4adff7  com.apple.sidecar-core (1.0 - 38.1) <ED88E1A7-F24F-32A4-A0B7-933A01EF669B> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff6f4ae000 - 0x7fff6f4beffb  com.apple.sidecar-ui (1.0 - 38.1) <C4D00FAC-A43D-3B25-A684-FB8D74D46CBE> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff7022d000 - 0x7fff704deff3  com.apple.SkyLight (1.600.0 - 336.81.5) <DE7FD278-A178-3A5B-8A26-7295340A54BE> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff70cae000 - 0x7fff70cbbfff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <816EC315-3E76-37B7-A495-B4AE031DA439> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff70d77000 - 0x7fff70fdfffb  com.apple.spotlight.index (10.7.0 - 1191.52) <35500671-A576-3B70-B7B0-BA16E8AF31D6> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff7139f000 - 0x7fff713deff3  com.apple.StreamingZip (1.0 - 1) <3F13DFEE-A6C9-3815-9120-B5CA6987662E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff713df000 - 0x7fff71450ffb  com.apple.Suggestions (6.0 - 226) <7B04BAF2-B734-3238-8F38-74629ADE6CF2> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fff71b1b000 - 0x7fff71ba8ff7  com.apple.Symbolication (10.1 - 64460.8) <1B488612-4C7F-3D9D-B6DC-64CF8D2CB3D6> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff71ba9000 - 0x7fff71bb2ffb  com.apple.SymptomDiagnosticReporter (1.0 - 820.227.2) <922102BF-0F85-3396-910B-B27255F15A4F> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff71e04000 - 0x7fff71e30fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <E41D573A-C356-344E-9E67-809F30D9DEF4> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff720b1000 - 0x7fff720beffb  com.apple.TCC (1.0 - 1) <B84E7234-A993-328C-A054-EFEB0402C55C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff72330000 - 0x7fff723f7ff7  com.apple.TextureIO (3.8.4 - 3.8.1) <F9D5F55D-9A33-326E-8B2F-B533CC91DD64> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff72455000 - 0x7fff72470fff  com.apple.ToneKit (1.0 - 1) <B353747A-3E09-3FA3-BDB2-598A891ACA8A> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff72471000 - 0x7fff72499ffb  com.apple.ToneLibrary (1.0 - 1) <3AEA8490-6454-3156-B11D-6B816EA2FE9A> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff724b1000 - 0x7fff724b2fff  com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <BD0BE410-E172-3585-82B2-869A1FE43092> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff724b8000 - 0x7fff72672fff  com.apple.UIFoundation (1.0 - 551) <7B73C4E0-256B-3C59-8E18-475A42BE0B12> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff726c1000 - 0x7fff726c7fff  com.apple.URLFormatting (59 - 59.34) <D104A904-5B18-368E-8290-35212094D9F5> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff73361000 - 0x7fff7344aff7  com.apple.ViewBridge (401.1 - 401.1) <B93A89EB-4421-3FF1-AA28-EBC3AC5076FE> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff738cf000 - 0x7fff73b3bffb  libAWDSupportFramework.dylib (886) <F277AAEA-4ACE-3918-9651-8E4730AC4ACF> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff73b3c000 - 0x7fff73b4dfff  libprotobuf-lite.dylib (886) <04FE1231-9041-3C52-9C20-AA094C532C92> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff73b4e000 - 0x7fff73bb0ff7  libprotobuf.dylib (886) <D5E8BAE2-D40B-3A29-9CB7-23242FCE14EA> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff73bb1000 - 0x7fff73bf7fff  com.apple.awd (1.0 - 930.11) <5CB90468-CD2B-3741-A950-0916E1C8CBBE> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff73c6a000 - 0x7fff73c6dfff  com.apple.dt.XCTTargetBootstrap (1.0 - 1) <697834E4-FEFD-305C-80EE-5052E61573FA> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff73c75000 - 0x7fff73cd5ff7  com.apple.xquery (1.3.1 - 30) <DB666CD4-4C35-316A-8D7A-CF8CD6CEF36F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
0x7fff7409e000 - 0x7fff740a0ff3  com.apple.loginsupport (1.0 - 1) <5F1E000D-0674-3413-AB3E-83F7974666FB> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff740a1000 - 0x7fff740b6fff  com.apple.login (3.0 - 3.0) <474C5E41-1326-3E78-A154-218D618D6BD4> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff740ed000 - 0x7fff7411fffb  com.apple.contacts.vCard (1.0 - ???) <FE9F0A13-7FB7-334B-97C1-5730E388C84D> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff742c6000 - 0x7fff742d9ffb  libAccessibility.dylib (2402.39.1) <8DCEF4C2-7004-391B-B872-980AE10BB077> /usr/lib/libAccessibility.dylib
0x7fff7435a000 - 0x7fff74392fff  libCRFSuite.dylib (41.15.4) <62EDD39F-6D1B-334B-A9A2-5800714255BB> /usr/lib/libCRFSuite.dylib
0x7fff74395000 - 0x7fff743a0ff7  libChineseTokenizer.dylib (28.15.3) <8CD1C213-7F62-3F02-BFB1-D0A5EFF92AB0> /usr/lib/libChineseTokenizer.dylib
0x7fff743a1000 - 0x7fff7442dff7  libCoreStorage.dylib (546.50.1) <F56AD958-416C-38EA-9829-DEAAB1F0C155> /usr/lib/libCoreStorage.dylib
0x7fff74431000 - 0x7fff74432ff7  libDiagnosticMessagesClient.dylib (107) <C542CB3C-AA44-3D7F-B88C-79CC31B481AB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff74469000 - 0x7fff7462cff7  libFosl_dynamic.dylib (18.3.2) <6EF1CB2A-2BDA-3458-B631-F794D72660FD> /usr/lib/libFosl_dynamic.dylib
0x7fff74682000 - 0x7fff746a1fff  libMobileGestalt.dylib (645.220.9) <F303B3D9-C6AD-30B9-9414-09DB34357E12> /usr/lib/libMobileGestalt.dylib
0x7fff746a2000 - 0x7fff746a2fff  libOpenScriptingUtil.dylib (179) <0664670D-C7E1-3D27-814B-B9C445AAF0DC> /usr/lib/libOpenScriptingUtil.dylib
0x7fff747e3000 - 0x7fff747e4ffb  libSystem.B.dylib (1252.200.5) <D5AFCC78-2AC2-37EB-B0EF-BB00FD38ED00> /usr/lib/libSystem.B.dylib
0x7fff747e5000 - 0x7fff7486dff7  libTelephonyUtilDynamic.dylib (3609) <56815350-CAD8-33A0-B958-D7503B4DC519> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff7486e000 - 0x7fff7486ffff  libThaiTokenizer.dylib (2.15.1) <A8235B04-F541-3856-BE2E-B58EE0483AD9> /usr/lib/libThaiTokenizer.dylib
0x7fff74882000 - 0x7fff74898ffb  libapple_nghttp2.dylib (1.24.1) <B8D45114-3868-3154-BC35-22597E3E7D8A> /usr/lib/libapple_nghttp2.dylib
0x7fff74899000 - 0x7fff748c2ffb  libarchive.2.dylib (54.200.3) <B47C54A0-3A30-374A-BD99-2304B9B0EC82> /usr/lib/libarchive.2.dylib
0x7fff748c3000 - 0x7fff74942fef  libate.dylib (1.13.8) <C647A80F-6F80-3FDA-A9B4-92800999F963> /usr/lib/libate.dylib
0x7fff74946000 - 0x7fff74946ff3  libauto.dylib (187) <01824E49-F2EF-3FC1-ABF3-782EFDF6CA17> /usr/lib/libauto.dylib
0x7fff74947000 - 0x7fff74a1cff7  libboringssl.dylib (109.220.4) <40015722-01B3-3E55-84ED-07448ACDA101> /usr/lib/libboringssl.dylib
0x7fff74a1d000 - 0x7fff74a2dff3  libbsm.0.dylib (39.200.18) <5E5098D0-F7B2-32A1-8038-E709F6718D4E> /usr/lib/libbsm.0.dylib
0x7fff74a2e000 - 0x7fff74a3cfff  libbz2.1.0.dylib (38.200.3) <4EE3C5E8-BEF3-3910-A231-B1AE2B437E01> /usr/lib/libbz2.1.0.dylib
0x7fff74a3d000 - 0x7fff74a94ff7  libc++.1.dylib (400.9.4) <D4AB366F-48A9-3C7D-91BD-41198F69DD57> /usr/lib/libc++.1.dylib
0x7fff74a95000 - 0x7fff74aaafff  libc++abi.dylib (400.17) <BA948A32-9024-3E55-98D4-18E31F6AED25> /usr/lib/libc++abi.dylib
0x7fff74aab000 - 0x7fff74aabff3  libcharset.1.dylib (51.200.6) <D998A58B-E4A8-3685-9A6A-43AFC28100EB> /usr/lib/libcharset.1.dylib
0x7fff74aac000 - 0x7fff74abcffb  libcmph.dylib (6.15.1) <5D776FF6-DF7F-3EDD-B920-C07ED76C672B> /usr/lib/libcmph.dylib
0x7fff74abd000 - 0x7fff74ad5ffb  libcompression.dylib (52.200.13) <EA767836-CBDC-318D-AC14-963C90D6CC67> /usr/lib/libcompression.dylib
0x7fff74d80000 - 0x7fff74d96fff  libcoretls.dylib (155.220.1) <3F98C144-397C-36A2-84F1-BB0D841D3D89> /usr/lib/libcoretls.dylib
0x7fff74d97000 - 0x7fff74d98ff3  libcoretls_cfhelpers.dylib (155.220.1) <0C190169-8EB8-3BA2-89BB-60265BB502F9> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff74e4e000 - 0x7fff74f36ff7  libcrypto.0.9.8.dylib (76.200.2) <0B2819E5-A99F-3165-904D-3A659669D8C7> /usr/lib/libcrypto.0.9.8.dylib
0x7fff75262000 - 0x7fff753faff7  libcrypto.42.dylib (22.200.4) <EFCEE49A-759B-3A9A-A164-ECD1A98D40F9> /usr/lib/libcrypto.42.dylib
0x7fff753fb000 - 0x7fff75406ff7  libcsfde.dylib (546.50.1) <65E8F1F1-665A-381E-8932-D7CBA451991B> /usr/lib/libcsfde.dylib
0x7fff7540f000 - 0x7fff75465ffb  libcups.2.dylib (462.9) <51E06E95-891F-3B88-A8C3-35B514C57239> /usr/lib/libcups.2.dylib
0x7fff7548f000 - 0x7fff754e3ff3  libcurl.4.dylib (105.200.2) <607613FE-3D84-3035-9C79-C6F72AF287D7> /usr/lib/libcurl.4.dylib
0x7fff7559d000 - 0x7fff7559dfff  libenergytrace.dylib (17.200.1) <D62ED169-B91C-3CCB-ADF5-E66AE4007B51> /usr/lib/libenergytrace.dylib
0x7fff755cf000 - 0x7fff755d4ff7  libgermantok.dylib (17.15.2) <9CBF0658-E83B-32E6-B674-3EE72D22C041> /usr/lib/libgermantok.dylib
0x7fff755d5000 - 0x7fff755daff7  libheimdal-asn1.dylib (520.220.2) <5302394C-ECF0-3C3B-BA67-4830EEF3CC40> /usr/lib/libheimdal-asn1.dylib
0x7fff75606000 - 0x7fff756f7ff7  libiconv.2.dylib (51.200.6) <3240A278-F537-3EC8-BE0C-983797520A50> /usr/lib/libiconv.2.dylib
0x7fff756f8000 - 0x7fff7595bffb  libicucore.A.dylib (62108.0.1) <969815D4-A345-31BB-82B7-0C3B58CA7E90> /usr/lib/libicucore.A.dylib
0x7fff759a8000 - 0x7fff759a9fff  liblangid.dylib (128.15.1) <F79B6250-C0B1-3E8E-851F-6CA33B4311A3> /usr/lib/liblangid.dylib
0x7fff759aa000 - 0x7fff759c2fff  liblzma.5.dylib (10.200.3) <3ADDFA63-F37A-3C9C-91E4-58EE3113B9A1> /usr/lib/liblzma.5.dylib
0x7fff759da000 - 0x7fff75a8afff  libmecab.1.0.0.dylib (779.19.2) <314FE1B9-3B4E-3B89-A101-33CE7B78FCE6> /usr/lib/libmecab.1.0.0.dylib
0x7fff75a8b000 - 0x7fff75cc8fff  libmecabra.dylib (779.19.2) <0ECEC3FC-935D-3EA5-8B3D-5CBD4E80AB78> /usr/lib/libmecabra.dylib
0x7fff75ea0000 - 0x7fff761f8fff  libnetwork.dylib (1229.221.1) <CE7ACD18-109F-382E-963B-C68419E301A1> /usr/lib/libnetwork.dylib
0x7fff76289000 - 0x7fff76a0ffe7  libobjc.A.dylib (750.1) <9CE27EC3-3A12-35D1-8F2F-3550B9668259> /usr/lib/libobjc.A.dylib
0x7fff76a10000 - 0x7fff76a11fff  libodfde.dylib (24.50.1) <B948D85A-165F-3E58-A8DD-24CF6454380A> /usr/lib/libodfde.dylib
0x7fff76a22000 - 0x7fff76a26ffb  libpam.2.dylib (22.200.1) <8C419238-675A-3C41-B8D4-95E391CA630F> /usr/lib/libpam.2.dylib
0x7fff76a29000 - 0x7fff76a5fff7  libpcap.A.dylib (79.200.4) <5939AB23-B2A9-3C03-B6C1-4F0E5A21D9FC> /usr/lib/libpcap.A.dylib
0x7fff76a60000 - 0x7fff76a9cff3  libpcre.0.dylib (9) <E756BD3C-C54E-3D7D-85C3-90195F4342B5> /usr/lib/libpcre.0.dylib
0x7fff76b79000 - 0x7fff76b91ffb  libresolv.9.dylib (65.200.2) <0FEAEB01-B926-37FA-AB47-99BAC481C10B> /usr/lib/libresolv.9.dylib
0x7fff76bd0000 - 0x7fff76be2ff7  libsasl2.2.dylib (211) <205CC13E-4ED7-3CE9-987F-12B28C6115A7> /usr/lib/libsasl2.2.dylib
0x7fff76be3000 - 0x7fff76be4ff7  libspindump.dylib (267.1) <528373EB-C7E9-3682-80CC-0EFCE0F3391D> /usr/lib/libspindump.dylib
0x7fff76be5000 - 0x7fff76dbcfe7  libsqlite3.dylib (274.20) <4434B695-BC65-30D6-AFED-1B6488DB3D2E> /usr/lib/libsqlite3.dylib
0x7fff76ebf000 - 0x7fff76f0cfff  libssl.44.dylib (22.200.4) <CF4931A6-5928-3E2B-8E31-1854F36B0C19> /usr/lib/libssl.44.dylib
0x7fff76f0d000 - 0x7fff76f5eff7  libstdc++.6.dylib (104.1) <0E48A478-4CFD-3111-8027-1047508A1D73> /usr/lib/libstdc++.6.dylib
0x7fff76f95000 - 0x7fff76fc5fff  libtidy.A.dylib (16.1) <435FB24F-0289-3330-B485-713909D6DA44> /usr/lib/libtidy.A.dylib
0x7fff76fe9000 - 0x7fff77048ff3  libusrtcp.dylib (1229.221.1) <7AB42596-89F7-3026-8289-AB2682153A36> /usr/lib/libusrtcp.dylib
0x7fff77049000 - 0x7fff7704cffb  libutil.dylib (51.200.4) <91EE9BF4-FB06-3260-B502-7EFDAD5AF59B> /usr/lib/libutil.dylib
0x7fff7704d000 - 0x7fff7705afff  libxar.1.dylib (404) <4B4D0206-0B62-3E89-AD07-E7BB9E4DFA68> /usr/lib/libxar.1.dylib
0x7fff7705f000 - 0x7fff77142fff  libxml2.2.dylib (32.8) <1CE77741-2E67-34B6-BB9F-B8E043966FCE> /usr/lib/libxml2.2.dylib
0x7fff77143000 - 0x7fff7716bff3  libxslt.1.dylib (16.1) <F191E8B9-7530-30CA-873B-2FA2BF2D6374> /usr/lib/libxslt.1.dylib
0x7fff7716c000 - 0x7fff7717effb  libz.1.dylib (70.200.4) <99A3D725-8388-38B4-B66C-5E9006E6F072> /usr/lib/libz.1.dylib
0x7fff771ac000 - 0x7fff771adffb  liblog_network.dylib (1229.221.1) <831417A5-7989-3BA5-B120-784B5EF83A54> /usr/lib/log/liblog_network.dylib
0x7fff771ef000 - 0x7fff771f3ff3  libcache.dylib (81) <FE21A7E9-DBEB-33AC-836B-785AD036ACF4> /usr/lib/system/libcache.dylib
0x7fff771f4000 - 0x7fff771feff3  libcommonCrypto.dylib (60118.220.1) <1099E427-6E81-3059-87AF-6F5FD81CA998> /usr/lib/system/libcommonCrypto.dylib
0x7fff771ff000 - 0x7fff77206fff  libcompiler_rt.dylib (63.4) <A4D9CF37-D076-3CE9-95F1-DA89DA1601B6> /usr/lib/system/libcompiler_rt.dylib
0x7fff77207000 - 0x7fff77210ff3  libcopyfile.dylib (146.200.3) <4BCDADBF-79F5-3829-B47D-64DA0D44BCBF> /usr/lib/system/libcopyfile.dylib
0x7fff77211000 - 0x7fff77295fdf  libcorecrypto.dylib (602.220.6) <E1046E01-A2FD-35B4-B018-ACC372F3880E> /usr/lib/system/libcorecrypto.dylib
0x7fff7731c000 - 0x7fff77356ff7  libdispatch.dylib (1008.220.2) <D8B56783-152A-34A8-94E9-8E6BAE049384> /usr/lib/system/libdispatch.dylib
0x7fff77357000 - 0x7fff77386fff  libdyld.dylib (635.2) <1B79A5CE-125F-301F-A441-C1869573AED0> /usr/lib/system/libdyld.dylib
0x7fff77387000 - 0x7fff77387ffb  libkeymgr.dylib (30) <A73AA788-C35C-3284-BFCA-95B1BBDF0CF3> /usr/lib/system/libkeymgr.dylib
0x7fff77388000 - 0x7fff77394ff7  libkxld.dylib (4903.221.2) <16D75C5C-584A-3848-84C0-3BFB312AEB92> /usr/lib/system/libkxld.dylib
0x7fff77395000 - 0x7fff77395ff7  liblaunch.dylib (1336.220.5) <95EB6EAF-2DC5-344F-BADB-CA4E35E4E503> /usr/lib/system/liblaunch.dylib
0x7fff77396000 - 0x7fff7739bfff  libmacho.dylib (921) <ECC4E97C-575E-3A08-8191-BF02D7D4E637> /usr/lib/system/libmacho.dylib
0x7fff7739c000 - 0x7fff7739effb  libquarantine.dylib (86.220.1) <6AE5AEEC-A9FD-3CF8-92DD-12B5AFBE12DE> /usr/lib/system/libquarantine.dylib
0x7fff7739f000 - 0x7fff773a0ff3  libremovefile.dylib (45.200.2) <D74A307B-3DC7-3992-B16C-DACB8207BE13> /usr/lib/system/libremovefile.dylib
0x7fff773a1000 - 0x7fff773b8ff3  libsystem_asl.dylib (356.200.4) <EC9D8AD4-E5CB-3765-804A-9E1E9DC045D2> /usr/lib/system/libsystem_asl.dylib
0x7fff773b9000 - 0x7fff773b9fff  libsystem_blocks.dylib (73) <26419398-C30C-30F1-B656-A92AFA9560F6> /usr/lib/system/libsystem_blocks.dylib
0x7fff773ba000 - 0x7fff77442fff  libsystem_c.dylib (1272.200.26) <3DEEE96E-6DF6-35AD-8654-D69AC26B907B> /usr/lib/system/libsystem_c.dylib
0x7fff77443000 - 0x7fff77446ff7  libsystem_configuration.dylib (963.200.27) <02CC3996-B34E-333C-8806-AE2699D34424> /usr/lib/system/libsystem_configuration.dylib
0x7fff77447000 - 0x7fff7744aff7  libsystem_coreservices.dylib (66) <254B6849-2C8F-302C-8616-B8324A11AB30> /usr/lib/system/libsystem_coreservices.dylib
0x7fff7744b000 - 0x7fff77451ffb  libsystem_darwin.dylib (1272.200.26) <974E9EF7-DE72-34B7-B056-0A81C10DF8EB> /usr/lib/system/libsystem_darwin.dylib
0x7fff77452000 - 0x7fff77458ff7  libsystem_dnssd.dylib (878.200.35) <FFC665AA-B257-35AD-BD8B-32FD42C2EEC1> /usr/lib/system/libsystem_dnssd.dylib
0x7fff77459000 - 0x7fff774a5ff3  libsystem_info.dylib (517.200.9) <0707C387-D7DE-372E-8FF1-3DE5C91932D6> /usr/lib/system/libsystem_info.dylib
0x7fff774a6000 - 0x7fff774cdff7  libsystem_kernel.dylib (4903.221.2) <0E882078-7330-3B49-AA5D-3CDB5645A4E5> /usr/lib/system/libsystem_kernel.dylib
0x7fff774ce000 - 0x7fff77519ff7  libsystem_m.dylib (3158.200.7) <43D1796B-954F-37D6-B1AC-9D80DF0655A2> /usr/lib/system/libsystem_m.dylib
0x7fff7751a000 - 0x7fff7753eff7  libsystem_malloc.dylib (166.220.1) <3B196122-4E0D-3E3F-AA3E-5115B976DE26> /usr/lib/system/libsystem_malloc.dylib
0x7fff7753f000 - 0x7fff7754aff3  libsystem_networkextension.dylib (767.220.1) <C54EB8F6-F305-3452-8DB1-F7DA6859AF8C> /usr/lib/system/libsystem_networkextension.dylib
0x7fff7754b000 - 0x7fff77552fff  libsystem_notify.dylib (172.200.21) <BCCB222F-DC64-3954-A836-DCCE6659CA5A> /usr/lib/system/libsystem_notify.dylib
0x7fff77553000 - 0x7fff7755cfef  libsystem_platform.dylib (177.200.16) <B75B04AD-69FE-3ADE-84D2-C17972FC8F49> /usr/lib/system/libsystem_platform.dylib
0x7fff7755d000 - 0x7fff77567fff  libsystem_pthread.dylib (330.220.2) <4958273C-4273-3501-8137-E44249E10D9C> /usr/lib/system/libsystem_pthread.dylib
0x7fff77568000 - 0x7fff7756bff7  libsystem_sandbox.dylib (851.220.9) <4D6433A8-C703-3ED9-82EB-B9E481A0FD2F> /usr/lib/system/libsystem_sandbox.dylib
0x7fff7756c000 - 0x7fff7756eff3  libsystem_secinit.dylib (30.220.1) <6C681113-8C48-3256-BEF6-0C3723DEB926> /usr/lib/system/libsystem_secinit.dylib
0x7fff7756f000 - 0x7fff77576ff7  libsystem_symptoms.dylib (820.227.2) <3147D594-F41F-35FD-BF0B-6B8B66A407DE> /usr/lib/system/libsystem_symptoms.dylib
0x7fff77577000 - 0x7fff7758cff7  libsystem_trace.dylib (906.220.1) <D5045DC5-A165-3238-A470-1796F12BF84F> /usr/lib/system/libsystem_trace.dylib
0x7fff7758e000 - 0x7fff77593ffb  libunwind.dylib (35.4) <41222EF6-2233-3CF4-947A-15D48CB8C030> /usr/lib/system/libunwind.dylib
0x7fff77594000 - 0x7fff775c4fff  libxpc.dylib (1336.220.5) <B2137772-E202-3656-A089-F6DD517007D5> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
task_for_pid: 113
thread_create: 0
thread_set_state: 0
  Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
  Calls made by all processes on this machine:
task_for_pid: 108756
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=639.5M resident=0K(0%) swapped_out_or_unallocated=639.5M(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
                            VIRTUAL   REGION
REGION TYPE                    SIZECOUNT (non-coalesced)
ATS (font support)            32.3M    8
ATS (font support) (reserved)    8K    3     reserved VM address space (unallocated)
Accelerate framework          1536K   12
Activity Tracing               256K    2
CG backing stores             64.6M   10
CG image                      1412K   50
CoreAnimation                 8832K   40
CoreGraphics                     8K    2
CoreImage                      232K   32
CoreUI image data             5384K   64
CoreUI image file              488K    9
Foundation                      28K    3
Image IO                      4908K    3
Kernel Alloc Once                8K    2
MALLOC                       630.8M  456
MALLOC guard page               48K   12
MALLOC_NANO (reserved)       384.0M    2     reserved VM address space (unallocated)
Memory Tag 242                  12K    2
SQLite page cache               64K    2
STACK GUARD                   56.1M   28
Stack                         22.2M   32
VM_ALLOCATE                   3976K   70
__DATA                        54.9M  441
__FONT_DATA                      4K    2
__LINKEDIT                   222.3M   44
__TEXT                       417.2M  420
__UNICODE                      564K    2
libnetwork                     640K    8
mapped file                  277.5M  102
shared memory                 14.8M   32
TOTAL                          2.2G 1865
TOTAL, minus reserved VM space 1.8G 1865
Dec 10, 2018 Dec 10, 2018
Hi I have the same problem,  (Adobe Acrobat Pro crashing when trying to move a document from secondary monitor to main monitor) and found something that works on my combo. (IMAC 5K 27 inch late 2014 processor: 4GHz intel core I7 macOS MOJAVE 10.14.1)
In the preferences window choose 5th option from the top. "full screen'". You can change that . With me it was on "this monitor". I changed that option to "biggest monitor". I can now drag between my two screens without any problem. Hope it works for others....
Best, Marcel
Dec 12, 2018 Dec 12, 2018
The most recent update released Dec 11, 2018 may have solved the problem.
