After updating to Mojave 10.14.1 from High Sierra, any time I try to launch output preview, the app crashes. This happens whether by shortcut key command or choosing the tool. Is this a bug that will be fixed (others experiencing it), or something I need to try a re-install on?
Hi brentm,
As per the issue description mentioned above, Acrobat DC is crashing when launching outpout preview in Acrobat, is that correct?
I tried replicating the issue on Mac OS Mojave 10.14.1 with Acrobat DC's version 2019.008.20080 but the issue was not reproducible.
Could you check if you have the latest patch installed for Acrobat on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Also, let us know if there is any error message when Acrobat crashes?
Does this happen when you are working on a specific pdf file or with all the files?
Let us know if you need any help.
Shivam
I also have the same crash problem with "uitvoervoorbeeld" ( Dutch ) after updating to Mojave 10.14.1
I re-installed but still crashes with every pdf I try.
Do you have any 3rd party plug-ins installed?
I'am a little happy, I have 2 screens, one Imac 27'' and a cinema display 23''
The crash problem only happens on the second screen.
I tried different backgrounds without result.
I did a re-install without 3rd party plug-ins
Hi Leo goedegebure,
Could you try creating a new user account on the machine by clicking Apple menu > System Preferences, then click Users & Groups ( Mac) Login into that account and check if Acrobat is still crashing upon launching output preview?
-Shivam
Hello Shivam
When I make a new account and login, Acrobat isn't crashing.
but I'am not really happy with this solution....
Hi leo goedegebure,
Could you try resetting preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. reboot the machine after resetting preferences and try again?
Let us know how it goes.
Shivam
I have tried this, and I think I have the problem narrowed down further. Acrobat will launch Output Preview without crashing because it now opens the tool onto the same window as my document (main monitor) using default preferences. Previously, the default open location was on my 2nd monitor and it immediately crashed. Now however, after the tool is open and I attempt to drag the output preview window from my main monitor to my 2nd monitor, Acrobat immediately crashes. Just as before I reset Acrobat preferences, if I had the document open on my 2nd monitor and then launched output preview, it didn't crash. In that case I can then move my document to the main monitor, move the tool's window back and forth between monitors without anything crashing. It appears the problem is when the tool attempts to initially open on the 2nd monitor with the document on the main monitor, or the tool is moved to the 2nd monitor after opening on the 1st monitor.
Exactly same here with second monitor!
Same here, when the document is on the same monitor as the Output preview window it doesn't crash...
Hello Shivam
For me the same result as brentm42423806. It crashes on screen1 or on screen2 when replacing.
L.G.
Thanks for the trick to get it to not crash by launching output preview on the 2nd monitor. I have the same configuration. Mine does not crash on the 2nd monitor either.
Yes, it happens when launching output preview.
We are using the most recent version (2019.008.20080).
Architecture: x86_64
Build: 19.8.20080.306727
AGM: 4.30.81
CoolType: 5.14.5
JP2K: 1.2.2.41572
It crashes regardless of the file we have open.
Here's the crash report.
Process: | AdobeAcrobat [7962] |
Path: | /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat |
Identifier: | com.adobe.Acrobat.Pro |
Version: | 19.008.20080 (19.008.20080) |
Code Type: | X86-64 (Native) |
Parent Process: | ??? [1] |
Responsible: | AdobeAcrobat [7962] |
User ID: | 503 |
Date/Time: | 2018-11-13 07:55:18.114 -0700 |
OS Version: | Mac OS X 10.14.1 (18B75) |
Report Version: | 12 |
Anonymous UUID: | DC7DCD2B-4680-5BF7-0CEB-B12C9EC7D50A |
Time Awake Since Boot: 140000 seconds
System Integrity Protection: enabled
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_CRASH (SIGABRT) |
Exception Codes: | 0x0000000000000000, 0x0000000000000000 |
Exception Note: | EXC_CORPSE_NOTIFY |
Application Specific Information:
Assertion failed: (type == kCGImageComponent8BitInteger), function img_data_depth, file /BuildRoot/Library/Caches/com.apple.xbs/Sources/CoreGraphics/CoreGraphics-1247.4.1/CoreGraphics/Images/CGSImage.c, line 5889.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib | 0x00007fff774acb86 __pthread_kill + 10 | |
1 libsystem_pthread.dylib | 0x00007fff77562c50 pthread_kill + 285 | |
2 libsystem_c.dylib | 0x00007fff774161c9 abort + 127 | |
3 libsystem_c.dylib | 0x00007fff773de868 __assert_rtn + 320 | |
4 com.apple.CoreGraphics | 0x00007fff4a5e1240 img_data_lock + 9844 | |
5 com.apple.CoreGraphics | 0x00007fff4a5dadd7 CGSImageDataLock + 1256 | |
6 com.apple.CoreGraphics | 0x00007fff4a5da890 RIPImageDataInitializeShared + 177 | |
7 com.apple.CoreGraphics | 0x00007fff4a5da43e RIPImageCacheGetRetained + 661 | |
8 com.apple.CoreGraphics | 0x00007fff4a5d9f64 ripc_AcquireRIPImageData + 293 | |
9 com.apple.CoreGraphics | 0x00007fff4a62460c ripc_DrawImages + 4743 | |
10 com.apple.CoreGraphics | 0x00007fff4a6228ec CGContextDrawImages + 188 | |
11 com.apple.coreui | 0x00007fff5f18fd5f DrawNinePartImageWithOperation + 5502 | |
12 com.apple.coreui | 0x00007fff5f18e635 DrawNinePartElementFromRenditionWithOperation + 416 | |
13 com.apple.coreui | 0x00007fff5f16fa2e -[CUIThemeFacet _drawSpecificRenditionKey:rendition:inFrame:context:alpha:operation:isFocused:isFlipped:effects:] + 406 | |
14 com.apple.coreui | 0x00007fff5f16f889 -[CUIThemeFacet _drawSpecificRenditionKey:inFrame:context:isFocused:isFlipped:effects:] + 153 | |
15 com.apple.coreui | 0x00007fff5f16f7d0 -[CUIThemeFacet drawInFrame:isFocused:context:effects:] + 142 | |
16 com.apple.coreui | 0x00007fff5f187aee CUICoreThemeRenderer::DrawSimple(CUIRenditionKey*, CUIDescriptor const*, signed char) + 552 | |
17 com.apple.coreui | 0x00007fff5f16e661 CUIRenderer::Draw(CGRect, CGContext*, __CFDictionary const*, __CFDictionary const**) + 1719 | |
18 com.apple.coreui | 0x00007fff5f16df78 CUIDraw + 278 | |
19 com.apple.AppKit | 0x00007fff4780df96 __44-[NSAppearance _drawInRect:context:options:]_block_invoke + 47 | |
20 com.apple.AppKit | 0x00007fff476f8dee -[NSCompositeAppearance _callCoreUIWithBlock:options:] + 364 | |
21 com.apple.AppKit | 0x00007fff4780df61 -[NSAppearance _drawInRect:context:options:] + 105 | |
22 com.apple.AppKit | 0x00007fff47c889f5 __25-[NSWidgetView drawRect:]_block_invoke + 158 | |
23 com.apple.AppKit | 0x00007fff477eeed8 _withOverlaidDictionary + 135 | |
24 com.apple.AppKit | 0x00007fff47c8894a -[NSWidgetView drawRect:] + 114 | |
25 com.apple.AppKit | 0x00007fff47811755 _NSViewDrawRect + 66 | |
26 com.apple.AppKit | 0x00007fff477fc552 -[NSView _drawRect:clip:] + 1745 | |
27 com.apple.AppKit | 0x00007fff477fb3f3 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1400 | |
28 com.apple.AppKit | 0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622 | |
29 com.apple.AppKit | 0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622 | |
30 com.apple.AppKit | 0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622 | |
31 com.apple.AppKit | 0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622 | |
32 com.apple.AppKit | 0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622 | |
33 com.apple.AppKit | 0x00007fff477fb8b9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2622 | |
34 com.apple.AppKit | 0x00007fff477f94f8 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 938 | |
35 com.apple.AppKit | 0x00007fff477f9128 -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 65 | |
36 com.apple.AppKit | 0x00007fff477f6a5a -[NSView _oldDisplayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 1887 | |
37 com.apple.AppKit | 0x00007fff477f6099 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 253 | |
38 com.apple.AppKit | 0x00007fff477f2c86 -[NSView displayIfNeeded] + 1300 | |
39 com.adobe.Acrobat.framework | 0x00000001103f9e99 0x10fed9000 + 5377689 | |
40 com.adobe.Acrobat.framework | 0x00000001103d56f3 0x10fed9000 + 5228275 | |
41 com.adobe.Acrobat.framework | 0x00000001103629d2 0x10fed9000 + 4757970 | |
42 com.adobe.Acrobat.framework | 0x0000000110389133 0x10fed9000 + 4915507 | |
43 com.adobe.Acrobat.framework | 0x0000000110033473 0x10fed9000 + 1418355 | |
44 com.adobe.Acrobat.framework | 0x0000000110143bd9 0x10fed9000 + 2534361 | |
45 com.adobe.Acrobat.framework | 0x000000011014c5cc 0x10fed9000 + 2569676 | |
46 com.adobe.Acrobat.framework | 0x000000011014d8fc 0x10fed9000 + 2574588 | |
47 com.adobe.Acrobat.framework | 0x000000011014d840 0x10fed9000 + 2574400 | |
48 com.adobe.Acrobat.framework | 0x0000000110793aa9 0x10fed9000 + 9153193 | |
49 com.adobe.Acrobat.framework | 0x0000000110a65eec 0x10fed9000 + 12111596 | |
50 com.adobe.Acrobat.framework | 0x00000001107015be 0x10fed9000 + 8553918 | |
51 com.adobe.Acrobat.framework | 0x00000001107017ac 0x10fed9000 + 8554412 | |
52 com.adobe.Acrobat.framework | 0x0000000110d2fbad 0x10fed9000 + 15035309 | |
53 com.adobe.Acrobat.framework | 0x0000000110d2ccd4 0x10fed9000 + 15023316 | |
54 com.adobe.Acrobat.framework | 0x0000000110eafd2d 0x10fed9000 + 16608557 | |
55 com.adobe.Acrobat.framework | 0x0000000110d6c78e 0x10fed9000 + 15284110 | |
56 com.adobe.Acrobat.framework | 0x0000000110d6efcd 0x10fed9000 + 15294413 | |
57 com.adobe.Acrobat.framework | 0x000000011071e761 0x10fed9000 + 8673121 | |
58 com.adobe.Acrobat.framework | 0x000000011071e581 0x10fed9000 + 8672641 | |
59 com.adobe.Acrobat.framework | 0x00000001109406c9 0x10fed9000 + 10909385 | |
60 com.adobe.Acrobat.framework | 0x000000011093c990 0x10fed9000 + 10893712 | |
61 com.apple.AppKit | 0x00007fff47920d63 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5668 | |
62 com.apple.AppKit | 0x00007fff47854d8b -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2319 | |
63 com.apple.AppKit | 0x00007fff47854231 -[NSWindow(NSEventRouting) sendEvent:] + 481 | |
64 com.apple.AppKit | 0x00007fff476f14a8 -[NSApplication(NSEvent) sendEvent:] + 336 | |
65 com.apple.AppKit | 0x00007fff476decf1 -[NSApplication run] + 755 | |
66 com.adobe.Acrobat.framework | 0x000000010fee16a8 0x10fed9000 + 34472 | |
67 com.adobe.Acrobat.framework | 0x000000010fedffba RunAcrobat + 243 | |
68 com.adobe.Acrobat.Pro | 0x000000010dc59f3f main + 86 | |
69 libdyld.dylib | 0x00007fff7736e08d start + 1 |
Thread 1:: Dispatch queue: NSOperationQueue 0x600003b39aa0 (QOS: UNSPECIFIED)
0 libsystem_kernel.dylib | 0x00007fff774aa876 __semwait_signal + 10 | |
1 libsystem_c.dylib | 0x00007fff77435830 nanosleep + 199 | |
2 com.apple.Foundation | 0x00007fff4c5ac04b +[NSThread sleepForTimeInterval:] + 156 | |
3 com.adobe.Acrobat.framework | 0x0000000111074fb8 0x10fed9000 + 18464696 | |
4 com.apple.Foundation | 0x00007fff4c506d5a -[__NSOperationInternal _start:] + 686 | |
5 com.apple.Foundation | 0x00007fff4c53145f __NSOQSchedule_f + 227 | |
6 libdispatch.dylib | 0x00007fff7731ed53 _dispatch_call_block_and_release + 12 | |
7 libdispatch.dylib | 0x00007fff7731fdcf _dispatch_client_callout + 8 | |
8 libdispatch.dylib | 0x00007fff773225dc _dispatch_continuation_pop + 427 | |
9 libdispatch.dylib | 0x00007fff77321c7e _dispatch_async_redirect_invoke + 718 | |
10 libdispatch.dylib | 0x00007fff7732dd26 _dispatch_root_queue_drain + 325 | |
11 libdispatch.dylib | 0x00007fff7732e4bd _dispatch_worker_thread2 + 90 | |
12 libsystem_pthread.dylib | 0x00007fff7755f70e _pthread_wqthread + 619 | |
13 libsystem_pthread.dylib | 0x00007fff7755f435 start_wqthread + 13 |
Thread 2:
0 libsystem_kernel.dylib | 0x00007fff774aa1b2 __psynch_cvwait + 10 | |
1 libsystem_pthread.dylib | 0x00007fff775635cb _pthread_cond_wait + 724 | |
2 com.adobe.AGM | 0x000000010dddca5a 0x10ddcf000 + 55898 | |
3 com.adobe.AGM | 0x000000010dddc98d 0x10ddcf000 + 55693 | |
4 com.adobe.AGM | 0x000000010e12c98d 0x10ddcf000 + 3529101 | |
5 libsystem_pthread.dylib | 0x00007fff77560339 _pthread_body + 126 | |
6 libsystem_pthread.dylib | 0x00007fff775632a7 _pthread_start + 70 | |
7 libsystem_pthread.dylib | 0x00007fff7755f445 thread_start + 13 |
Thread 3:
Thread 4:
Thread 5:: com.apple.NSEventThread
0 libsystem_kernel.dylib | 0x00007fff774a6c2a mach_msg_trap + 10 | |
1 libsystem_kernel.dylib | 0x00007fff774a7174 mach_msg + 60 | |
2 com.apple.CoreFoundation | 0x00007fff4a191da2 __CFRunLoopServiceMachPort + 337 | |
3 com.apple.CoreFoundation | 0x00007fff4a1912f1 __CFRunLoopRun + 1654 | |
4 com.apple.CoreFoundation | 0x00007fff4a190a28 CFRunLoopRunSpecific + 463 | |
5 com.apple.AppKit | 0x00007fff476eeadd _NSEventThread + 160 | |
6 libsystem_pthread.dylib | 0x00007fff77560339 _pthread_body + 126 | |
7 libsystem_pthread.dylib | 0x00007fff775632a7 _pthread_start + 70 | |
8 libsystem_pthread.dylib | 0x00007fff7755f445 thread_start + 13 |
Thread 6:
2 com.adobe.Acrobat.framework | 0x000000011033c849 0x10fed9000 + 4601929 | |
3 com.adobe.Acrobat.framework | 0x000000011032d0b7 0x10fed9000 + 4538551 | |
4 com.adobe.Acrobat.framework | 0x000000011113f7ad 0x10fed9000 + 19294125 | |
5 com.adobe.Acrobat.framework | 0x0000000110327f10 0x10fed9000 + 4517648 | |
6 com.adobe.Acrobat.framework | 0x00000001103369b8 0x10fed9000 + 4577720 | |
7 libsystem_pthread.dylib | 0x00007fff77560339 _pthread_body + 126 | |
8 libsystem_pthread.dylib | 0x00007fff775632a7 _pthread_start + 70 | |
9 libsystem_pthread.dylib | 0x00007fff7755f445 thread_start + 13 |
Thread 7:
0 libsystem_kernel.dylib | 0x00007fff774a88a6 read + 10 | |
1 com.adobe.Acrobat.framework | 0x000000011032b421 0x10fed9000 + 4531233 | |
2 com.adobe.Acrobat.framework | 0x0000000110329359 0x10fed9000 + 4522841 | |
3 com.adobe.Acrobat.framework | 0x00000001103327cc 0x10fed9000 + 4560844 | |
4 com.adobe.Acrobat.framework | 0x0000000110327f10 0x10fed9000 + 4517648 | |
5 com.adobe.Acrobat.framework | 0x00000001103369b8 0x10fed9000 + 4577720 | |
Thread 8:
0 libsystem_kernel.dylib | 0x00007fff774ad052 kevent + 10 | |
1 com.adobe.Acrobat.framework | 0x0000000111ab502b 0x10fed9000 + 29212715 | |
2 com.adobe.Acrobat.framework | 0x00000001119d5dcc 0x10fed9000 + 28298700 | |
3 libsystem_pthread.dylib | 0x00007fff77560339 _pthread_body + 126 | |
4 libsystem_pthread.dylib | 0x00007fff775632a7 _pthread_start + 70 | |
5 libsystem_pthread.dylib | 0x00007fff7755f445 thread_start + 13 |
Thread 9:
5 com.adobe.AcrobatPlugin.EFS | 0x000000011b93f3a9 0x11b925000 + 107433 | |
6 com.apple.Foundation | 0x00007fff4c4ed014 __NSThread__start__ + 1218 | |
Thread 10:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork | 0x00007fff490934e5 -[__CoreSchedulingSetRunnable runForever] + 195 | |
Thread 11:
0 libsystem_kernel.dylib | 0x00007fff774ade82 __select + 10 |
1 com.adobe.AcrobatPlugin.Comments 0x000000011ade1ebb 0x11aa45000 + 3788475
2 com.adobe.AcrobatPlugin.Comments 0x000000011ade24c3 0x11aa45000 + 3790019
3 com.adobe.AcrobatPlugin.Comments 0x000000011ade28b3 0x11aa45000 + 3791027
4 com.adobe.AcrobatPlugin.Comments 0x000000011ad6ae45 0x11aa45000 + 3300933
5 com.adobe.AcrobatPlugin.Comments 0x000000011af8355b 0x11aa45000 + 5498203
Thread 12:
2 com.adobe.Acrobat.framework | 0x0000000111aa8604 0x10fed9000 + 29160964 | |
3 com.adobe.Acrobat.framework | 0x0000000111aa6191 0x10fed9000 + 29151633 | |
4 com.adobe.Acrobat.framework | 0x0000000111aa60e9 0x10fed9000 + 29151465 | |
Thread 13:
2 com.adobe.headlights.LogSessionFramework 0x0000000119d9459c boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x0000000119d92ebf boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x0000000119d2856a void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x0000000119d237b7 RealTimeProcessor::WorkerThread(int) + 3683
6 com.adobe.headlights.LogSessionFramework 0x0000000119d92239 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 14:: com.apple.CFSocket.private
0 libsystem_kernel.dylib | 0x00007fff774ade82 __select + 10 | |
1 com.apple.CoreFoundation | 0x00007fff4a1bf9d3 __CFSocketManager + 639 | |
2 libsystem_pthread.dylib | 0x00007fff77560339 _pthread_body + 126 | |
3 libsystem_pthread.dylib | 0x00007fff775632a7 _pthread_start + 70 | |
4 libsystem_pthread.dylib | 0x00007fff7755f445 thread_start + 13 |
Thread 15:
0 libsystem_kernel.dylib | 0x00007fff774a6c66 semaphore_wait_trap + 10 | |
1 com.adobe.AIDE | 0x000000010e77b972 CTThreading::OSSemaphore::Wait() + 16 | |
2 com.adobe.AIDE | 0x000000010e77aa1a CTThreading::ThreadSafeQueue::Dequeue() + 22 | |
3 com.adobe.AIDE | 0x000000010e77af64 CTThreading::WorkerThread::Start() + 38 | |
4 com.adobe.AIDE | 0x000000010e77a76a CTThreading::PthreadStart(void*) + 14 | |
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
0 libsystem_pthread.dylib | 0x00007fff7755f428 start_wqthread + 0 | |
1 ??? | 0x0000600000cbe940 0 + 105553129630016 |
Thread 25:
1 ??? | 0x0000000054485244 0 + 1414025796 |
Thread 26:
1 ??? | 0x0000000200000000 0 + 8589934592 |
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000010feae5c0 rcx: 0x00007ffee1f9fe88 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007ffee1f9fec0 rsp: 0x00007ffee1f9fe88
r8: 0x0000000000001701 r9: 0xcccccccccccccccd r10: 0x0000000000000000 r11: 0x0000000000000206
r12: 0x0000000000000307 r13: 0x000000010f2e4000 r14: 0x0000000000000006 r15: 0x000000000000002d
rip: 0x00007fff774acb86 rfl: 0x0000000000000206 cr2: 0x00007fffaa178188
Logical CPU: | 0 |
Error Code: | 0x02000148 |
Trap Number: | 133 |
Binary Images:
0x10dc59000 - | 0x10dc59fff +com.adobe.Acrobat.Pro (19.008.20080 - 19.008.20080) <B0E5A575-1F00-3838-8534-139840444702> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat | |
0x10dc5e000 - | 0x10ddb7fff +com.adobe.ACE (AdobeACE 2.20.02.41668 - 2.20.02.41668) <4F5F2FB8-6939-3F95-AB83-EE18E8DFE239> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE | |
0x10ddcf000 - | 0x10e2b6ff7 +com.adobe.AGM (AdobeAGM 4.30.80.1 - 4.30.81.1) <F546780C-B337-377C-8325-71175E386696> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM | |
0x10e371000 - | 0x10e38afff +com.adobe.BIB (AdobeBIB 1.2.03.41668 - 1.2.03.41668) <356C42CD-B75A-35EA-90B6-3EC75EA74A3A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB | |
0x10e393000 - | 0x10e66afff +com.adobe.CoolType (AdobeCoolType 5.14.05.41668 - 5.14.05.41668) <AD542820-E4F8-30BF-9C76-7CB11800A9BB> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType | |
0x10e6b7000 - | 0x10e7edfff +com.adobe.AIDE (1.5.0 - 1.5.0.34124) <CE69D37F-2D03-3B1D-8E63-C04CCC3FC37A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE | |
0x10e85d000 - | 0x10e863fff +com.adobe.AdobeCrashReporter (7.7 - 7.7.0) <FA36FB74-CC30-3BFC-BC2C-4025E64F8C6A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter | |
0x10f279000 - | 0x10f2a9fff +com.adobe.ARE (AdobeARE 1.5.02.41668 - 1.5.02.41668) <5603CC0B-15B4-3855-8BF6-6CC317CD471B> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE | |
0x10fdf8000 - | 0x10fe766a7 dyld (635.2) <1780094A-8FE2-3EAA-B4A3-C4CF14BC5196> /usr/lib/dyld | |
0x10fed9000 - | 0x112436fff +com.adobe.Acrobat.framework (19.008.20080 - 19.008.20080) <4081F060-407B-30DB-9CBB-0AC54A0519DE> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat | |
0x114a90000 - | 0x114a93047 libobjc-trampolines.dylib (750.1) <EAFE392F-7BD6-3988-9C6F-DFD359AE0AD3> /usr/lib/libobjc-trampolines.dylib | |
0x114b6d000 - | 0x114b71fff +AcrobatUpdateHelperLib.dylib (1) <3F981C5B-F26C-32CA-B4DA-B01D5884F76D> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib | |
0x114bf6000 - | 0x114c28ff7 +com.adobe.pip (7.4.1.11.44704) <E684FABD-A1CD-329F-80BE-AF6C2FEB415F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobePIP.framework/AdobePIP | |
0x114c5e000 - | 0x114c80ff7 +com.adobe.AcrobatPlugin.Updater (19.008.20071 - 19.008.20071) <F301A429-1043-3C3A-8241-5F23C69E9A99> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater | |
0x114c8a000 - | 0x114ca9fff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <0B2D4DF2-8040-3205-B7E4-220385090BB9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils | |
0x114cf3000 - | 0x114d81ff7 +com.adobe.AcrobatPlugin.PDDom (19.008.20071 - 19.008.20071) <3473DC10-EEF6-3AE0-BCB5-E37506397DDE> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/PDDom.acroplugin/Contents/MacOS/PDDom | |
0x115118000 - | 0x1152dbff7 +com.adobe.amtlib (10.0.0.274 - 10.0.0.274) <36A6E7C9-2F17-3B9B-87B4-893566003D72> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib | |
0x1155bd000 - | 0x115711fff +com.quite.plugin.QI+ 4 XB (4.0c - 4.0.2r1) <3FE6EBB7-681F-3EE4-BDE7-26589765724A> /Library/Application Support/Adobe/*/QI+ 4 XB | |
0x119752000 - | 0x119772ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.41773 - 3.9.0.41773) <290F26BE-690E-3264-850B-23A145F67798> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat | |
0x119797000 - | 0x1197d5ff7 +libcryptocme.dylib (0) <FBB5731B-265B-32EB-A2A2-78FD28833E45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libcryptocme.dylib | |
0x1197ed000 - | 0x11984bff7 +libccme_base.dylib (0) <59589393-1392-3DAA-8F3F-8840826C9420> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base.dylib | |
0x119876000 - | 0x1198acfff +libccme_asym.dylib (0) <F7C87F5D-DCB5-3C46-BDB6-5CD936125F18> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_asym.dylib | |
0x1198c7000 - | 0x11998aff7 +libccme_ecc_accel_fips.dylib (0) <ECA407E7-BD54-34A6-B85B-E99EEE6A9F45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc_accel_fips.dylib | |
0x119992000 - | 0x1199fbff7 +libccme_ecc.dylib (0) <DA65C6FE-D7F5-305E-BF42-CA3AD7B6C554> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc.dylib | |
0x119a32000 - | 0x119a8bff7 +libccme_base_non_fips.dylib (0) <FF0F0C06-3F5D-3BA4-9CFB-E90702E171F1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base_non_fips.dylib | |
0x119b2d000 - | 0x119b2fffb com.apple.textencoding.unicode (5.0 - 5.0) <8F8EAF7E-BE4A-363A-A855-B817C81CF951> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings | |
0x119c92000 - | 0x119dd0fff +com.adobe.headlights.LogSessionFramework (7.4.1.11.44704) <3FB068A4-9343-3185-870E-F922267BFA19> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/LogSession.framework/LogSession | |
0x11aa45000 - | 0x11b1e8ff7 +com.adobe.AcrobatPlugin.Comments (19.008.20080 - 19.008.20080) <BBE19F81-7C9B-3A0B-9CF4-82B7BE188A46> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments | |
0x11b3ee000 - | 0x11b53eff7 +IMSLib.dylib (10.0.0.35 - 10.0.0.35) <0F67F73D-2BD4-3432-AB6F-47C632068CBB> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib | |
0x11b607000 - | 0x11b692ff7 +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <71CC53CB-2483-3BEC-A044-04EF257425DB> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite | |
0x11b925000 - | 0x11b949ff7 +com.adobe.AcrobatPlugin.EFS (19.008.20071 - 19.008.20071) <185C5BB2-3CE9-3893-8958-69EA0475FD04> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS | |
0x11ba03000 - | 0x11ba5bff7 +com.adobe.AcrobatPlugin.Spelling (19.008.20071 - 19.008.20071) <48C860BB-E2F4-3F47-BC4A-74D7EADC86D7> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Spelling.acroplugin/Contents/MacOS/Spelling | |
0x11ba67000 - | 0x11bad3fff +com.adobe.linguistic.LinguisticManager (13.0.0 - 23526) <93A6AC53-0C96-31C5-9AFB-06087D7BAE0A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic | |
0x11cf50000 - | 0x11d081fff +com.adobe.ICUUnicode (58.2 - 3.61) <550AB59F-78EF-35F4-8F94-AD3EE47B603E> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUUnicode.framework/Versions/58.2/ICUUnicode | |
0x11d0f0000 - | 0x11d1ddff7 +com.lextek.onix (3.16.2.5 - 3.16.2.5) <96673EB4-7999-31D0-915B-628DB0757858> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Onix.framework/Onix | |
0x11d3a4000 - | 0x11d50bfff +com.adobe.AcrobatPlugin.DigSig (19.008.20071 - 19.008.20071) <B3FF4ED6-A280-3B63-A1A8-84F1EF3EB514> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/DigSig.acroplugin/Contents/MacOS/DigSig | |
0x11d527000 - | 0x11de65fff +com.adobe.AcrobatPlugin.PPKLite (19.008.20080 - 19.008.20080) <115B8015-53F5-3E26-A9E8-1262F44B8EF5> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/PPKLite.acroplugin/Contents/MacOS/PPKLite | |
0x11df0c000 - | 0x11df98fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 15 - 91.163280) <1F825AAD-53E1-3053-A4B1-E71E1F4DE216> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP | |
0x120262000 - | 0x121098fff +com.adobe.AcrobatPlugin.AcroForm (19.008.20071 - 19.008.20071) <4006C196-90AF-390B-83D3-489D38D55790> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/AcroForm.acroplugin/Contents/MacOS/AcroForm | |
0x121513000 - | 0x12184dff7 +com.adobe.AcrobatPlugin.EScript (19.008.20071 - 19.008.20071) <B724F036-A0BA-308E-862A-4480EE339D24> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EScript.acroplugin/Contents/MacOS/EScript | |
0x12c66c000 - | 0x12df6cfff +com.adobe.ICUData (58.2 - 3.61) <EA74F255-A2C8-3749-9DA5-071E6AED9FC2> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUData.framework/Versions/58.2/ICUData | |
0x130174000 - | 0x130236ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.41572) <89226A68-F0F9-3517-8DF5-24DB610A2C98> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K | |
0x7fff3ff3f000 - | 0x7fff3ff5aff7 libJapaneseConverter.dylib (73) <BFCBCBC5-3925-3A25-B13F-A8F3ECE5DE3A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib | |
0x7fff3ffc0000 - | 0x7fff40339fff com.apple.RawCamera.bundle (8.11.0 - 1031.1.3) <FE033C75-0F5C-3F38-8A11-36A32E9D3F47> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera | |
0x7fff4033c000 - | 0x7fff40487ff7 com.apple.AMDMTLBronzeDriver (2.2.8 - 2.0.2) <DEFFC096-0D52-3F03-A7B5-DE22B4810D75> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver | |
0x7fff460ba000 - | 0x7fff462a8fff com.apple.avfoundation (2.0 - 1542.10.104.1) <A3A0B581-CA6E-31E1-AE67-5DB8EABFEA04> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation | |
0x7fff462a9000 - | 0x7fff46378fff com.apple.audio.AVFAudio (1.0 - ???) <6FB8FD22-713D-347C-8278-9170077EE8AD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio | |
0x7fff46486000 - | 0x7fff46486fff com.apple.Accelerate (1.11 - Accelerate 1.11) <A09CB6D5-3F8A-3E05-B0EB-63878296A059> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate | |
0x7fff46487000 - | 0x7fff4649dfef libCGInterfaces.dylib (506.19.1) <8A894DB4-A48B-31A0-9316-DC41061D9549> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib | |
0x7fff4649e000 - | 0x7fff46b3efe3 com.apple.vImage (8.1 - ???) <DB23E2A0-EA06-3073-AA7E-2873556714A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage | |
0x7fff46b3f000 - | 0x7fff46db6fd7 libBLAS.dylib (1243.200.4) <76710990-AE2B-300E-88BB-797ABAD74956> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib | |
0x7fff46db7000 - | 0x7fff46e29fe7 libBNNS.dylib (38.200.5) <5F3A4021-8FF8-30E8-B84A-AA2BD70F4151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib | |
0x7fff46e2a000 - | 0x7fff471d0fff libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib | |
0x7fff471d1000 - | 0x7fff471e6ffb libLinearAlgebra.dylib (1243.200.4) <E923DA33-B142-3A73-A80A-642878D19099> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib | |
0x7fff471e7000 - | 0x7fff471ecff3 libQuadrature.dylib (3.200.2) <6FFAC142-415D-3AF0-BC09-336302F11934> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib | |
0x7fff471ed000 - | 0x7fff4726affb libSparse.dylib (79.200.5) <0D7E71A4-10D2-3979-B386-D2426ADAF6D7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib | |
0x7fff4726b000 - | 0x7fff4727effb libSparseBLAS.dylib (1243.200.4) <00D6FC17-B739-3259-90A4-92AC8BBE03D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib | |
0x7fff4727f000 - | 0x7fff47463ff3 libvDSP.dylib (671.220.1) <2F576522-08B1-3C65-8F00-3427E938ADDA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib | |
0x7fff47464000 - | 0x7fff47519ff3 libvMisc.dylib (671.220.1) <29F59097-A256-38E9-9D55-BF56E9139CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib | |
0x7fff4751a000 - | 0x7fff4751afff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <221E4FEF-0431-3316-8281-22B6F8315A09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib | |
0x7fff4751b000 - | 0x7fff4757effb com.apple.Accounts (113 - 113) <516F1A48-D158-3888-91AC-E1C7C3F9CCDD> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts | |
0x7fff47581000 - | 0x7fff476caffb com.apple.AddressBook.framework (11.0 - 1885) <0C7FCB1A-15C2-38E8-8085-D484650F5140> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook | |
0x7fff476cb000 - | 0x7fff484ebff3 com.apple.AppKit (6.9 - 1671.10.106) <179A5F4A-6467-31BD-93F2-CC27E046221E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit | |
0x7fff4853d000 - | 0x7fff4853dfff com.apple.ApplicationServices (50.1 - 50.1) <470C0943-30AD-3BA2-AFCE-EB7DD26E1709> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices | |
0x7fff4853e000 - | 0x7fff485a9ff7 com.apple.ApplicationServices.ATS (377 - 453.11) <7599E619-EE21-3EB7-875B-AE3B8D3E13BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS | |
0x7fff48642000 - | 0x7fff48761fff libFontParser.dylib (228.6) <E800074F-62CF-340A-A5A7-B8BE5B560045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib | |
0x7fff48762000 - | 0x7fff487adfff libFontRegistry.dylib (228.12) <480D472D-C8FB-321D-86EC-2EA6927A97AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib | |
0x7fff4880c000 - | 0x7fff4883fff7 libTrueTypeScaler.dylib (228.6) <D23BFDE4-8664-335A-B43B-A13A8EF29E40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib | |
0x7fff488a9000 - | 0x7fff488adff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <90641B6B-D07B-3577-B594-965825544B60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy | |
0x7fff4894a000 - | 0x7fff4899cff3 com.apple.HIServices (1.22 - 627.14.2) <01F309D6-32E7-3C4F-A38B-8206EE3076CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices | |
0x7fff4899d000 - | 0x7fff489abff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <67BC5855-B7A3-39E6-B5DD-52B287EB1532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis | |
0x7fff489ac000 - | 0x7fff489f8fff com.apple.print.framework.PrintCore (14.0 - 503.7) <C13BC56A-65F4-35B1-9E33-51FE6F3B06FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore | |
0x7fff489f9000 - | 0x7fff48a34ff7 com.apple.QD (3.12 - 407.2) <94A30038-C545-327A-B1C0-E19C79D62BAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD | |
0x7fff48a35000 - | 0x7fff48a41ff7 com.apple.speech.synthesis.framework (8.1.0 - 8.1.0) <823830AC-62A6-36CC-A659-6BC10F2AC6F5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis | |
0x7fff48a42000 - | 0x7fff48cdeff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <F56518BA-B21B-32D8-B077-40A989815F46> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox | |
0x7fff48ce0000 - | 0x7fff48ce0fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B0F229C4-E8AF-3EB3-8241-7576A115D69F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit | |
0x7fff49044000 - | 0x7fff49405ff7 com.apple.CFNetwork (975.0.3 - 975.0.3) <99BD4FA0-8BD3-35E5-8FB1-C757D439716C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork | |
0x7fff4941a000 - | 0x7fff4941afff com.apple.Carbon (158 - 158) <BF1EC28F-CBA8-3B2F-B9FA-E583BC2D6C1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon | |
0x7fff4941b000 - | 0x7fff4941effb com.apple.CommonPanels (1.2.6 - 98) <F1E1C47B-FD1A-30A4-B41B-87BD8B178B56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels | |
0x7fff4941f000 - | 0x7fff49726ff7 com.apple.HIToolbox (2.1.1 - 917.2) <0B91F11C-0895-3A7B-9A3B-2B6B1267EA1A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox | |
0x7fff49727000 - | 0x7fff4972affb com.apple.help (1.3.8 - 66) <4392A63F-9B58-3248-BF73-B46AD3744E6E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help | |
0x7fff4972b000 - | 0x7fff49730ff7 com.apple.ImageCapture (9.0 - 1530.1) <47915C3C-DED4-3E0C-9155-6B130FFF89BB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture | |
0x7fff49731000 - | 0x7fff497c5ff3 com.apple.ink.framework (10.9 - 225) <D6503F37-7EBC-32C1-95CC-A35EFC54E7ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink | |
0x7fff497c6000 - | 0x7fff497e0fff com.apple.openscripting (1.7 - 179) <BDE14D25-4D82-3EBC-8EF2-D1F6BC957B07> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting | |
0x7fff49801000 - | 0x7fff49802fff com.apple.print.framework.Print (14.0 - 267.3) <5CD250DF-98AD-30B8-A5D5-47634FF9E74D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print | |
0x7fff49803000 - | 0x7fff49805ff7 com.apple.securityhi (9.0 - 55006) <C5308CBC-6736-31A7-905B-C635C6D43FDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI | |
0x7fff49806000 - | 0x7fff4980cff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C38B9CB-DD45-3A7B-9D4C-631855A4EE32> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition | |
0x7fff4980d000 - | 0x7fff49932fff com.apple.cloudkit.CloudKit (736.130 - 736.130) <049A491D-025D-3DD6-8EC9-5BFD4B96A809> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit | |
0x7fff49933000 - | 0x7fff49933fff com.apple.Cocoa (6.11 - 23) <4D5D4968-E233-3598-B434-E1009D48A628> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa | |
0x7fff49941000 - | 0x7fff49a0dfff com.apple.ColorSync (4.13.0 - 3340) <0618DA46-5A5E-339D-BB2F-ED66A2BFCCF9> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync | |
0x7fff49a0e000 - | 0x7fff49b02ff3 com.apple.contacts (1.0 - 2900) <E5A10BFE-FAE6-3B2B-BC2F-44EB262EEA06> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts | |
0x7fff49ba8000 - | 0x7fff49c38fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A7F8E168-AB1D-36F4-9693-CFEF12BC197D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio | |
0x7fff49c9e000 - | 0x7fff49cc9ff7 com.apple.CoreBluetooth (1.0 - 1) <61235BEA-BF5F-31B2-B9C1-DE722E15840F> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth | |
0x7fff49cca000 - | 0x7fff4a06bfef com.apple.CoreData (120 - 866.1) <B74013FA-621B-30F9-8CFE-3290FF63C2B8> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData | |
0x7fff4a06c000 - | 0x7fff4a155ff7 com.apple.CoreDisplay (101.3 - 104.4) <52C96B6A-B119-3BE2-B47D-65F12E987609> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay | |
0x7fff4a156000 - | 0x7fff4a5a3fe7 com.apple.CoreFoundation (6.9 - 1560.12) <B5BDC307-6C89-3DE0-B4B9-4C2C650E4528> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation | |
0x7fff4a5a5000 - | 0x7fff4ac32ff7 com.apple.CoreGraphics (2.0 - 1247.4.1) <D2F1DD53-09BD-307B-8B80-46B259530ED8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics | |
0x7fff4ac34000 - | 0x7fff4af5dfff com.apple.CoreImage (14.1.0 - 710.2.240) <CAEE3AAA-0781-311A-B987-72C7332C1A3F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage | |
0x7fff4af5e000 - | 0x7fff4afdffff com.apple.corelocation (2245.8.12) <F5E2C817-2D01-3401-89F0-B024FE296FC6> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation | |
0x7fff4b03f000 - | 0x7fff4b2adff7 com.apple.CoreML (1.0 - 1) <A6C41E33-935A-3C1A-9FC3-0372E580A5D7> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML | |
0x7fff4b2ae000 - | 0x7fff4b3afff3 com.apple.CoreMedia (1.0 - 2282.19.104.4) <2FF4819F-0D06-38D5-9403-4DA3F6F37D76> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia | |
0x7fff4b3b0000 - | 0x7fff4b412fff com.apple.CoreMediaIO (900.0 - 5025) <A9CC940A-9E7C-35A4-A1E6-DADD66200378> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO | |
0x7fff4b413000 - | 0x7fff4b413fff com.apple.CoreServices (934 - 934) <EBA4A3BF-0B07-3E1B-9C14-8E6879453C6C> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices | |
0x7fff4b414000 - | 0x7fff4b492ffb com.apple.AE (771 - 771) <BBFEAB6C-B1F9-3D22-934E-8298155AC459> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE | |
0x7fff4b493000 - | 0x7fff4b76bff7 com.apple.CoreServices.CarbonCore (1178.11 - 1178.11) <9FBE7BFB-3A81-37AC-8E15-E6F7932BBDC0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore | |
0x7fff4b76c000 - | 0x7fff4b7b6ff7 com.apple.DictionaryServices (1.2 - 284.16.3) <D9388630-E7F2-321E-81FF-EBD5F3B47A52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices | |
0x7fff4b7b7000 - | 0x7fff4b7bfffb com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <E40A3C4A-79C7-37D8-999B-D1169A06870B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents | |
0x7fff4b7c0000 - | 0x7fff4b98bfff com.apple.LaunchServices (934 - 934) <FD3D313D-997B-388B-B208-29774CDDF897> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices | |
0x7fff4b98c000 - | 0x7fff4ba2efff com.apple.Metadata (10.7.0 - 1191.52) <5A758D93-4BBD-3C6D-861B-000536ED9B2D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata | |
0x7fff4ba2f000 - | 0x7fff4ba7aff7 com.apple.CoreServices.OSServices (934 - 934) <1D2AC09A-653F-3C2D-B5B9-F9ABA307E51C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices | |
0x7fff4ba7b000 - | 0x7fff4bae9ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <C6A34D09-9707-3F28-838F-63B59B8A12D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit | |
0x7fff4baea000 - | 0x7fff4bb0effb com.apple.coreservices.SharedFileList (71.27 - 71.27) <B46A15E0-4C10-3616-BE49-58E07EC463FE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList | |
0x7fff4be56000 - | 0x7fff4bfbbffb com.apple.CoreText (352.0 - 584.25) <AC3B4909-564A-3C26-B055-7687E5DE1697> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText | |
0x7fff4bfbc000 - | 0x7fff4bff9fff com.apple.CoreVideo (1.8 - 0.0) <C7BB7D0F-3AF2-3046-A387-A802BCA52A3A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo | |
0x7fff4bffa000 - | 0x7fff4c090ffb com.apple.framework.CoreWLAN (13.0 - 1370.8) <735EEBA3-C63B-38C8-A1A7-23B12C2E9550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN | |
0x7fff4c220000 - | 0x7fff4c22bffb com.apple.DirectoryService.Framework (10.14 - 207.200.4) <222097B7-D721-3F27-9798-ACC95E73F233> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService | |
0x7fff4c22c000 - | 0x7fff4c2e6ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <9F007E61-83AD-3DB5-B3D5-CB4F1EDF746A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording | |
0x7fff4c30d000 - | 0x7fff4c312fff com.apple.DiskArbitration (2.7 - 2.7) <C53C1905-9BCF-3AE8-8BB3-C8A2C7DB7D25> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration | |
0x7fff4c4db000 - | 0x7fff4c8a9fff com.apple.Foundation (6.9 - 1560.12) <B5DC275C-12C9-320A-A117-C8FE9034931A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation | |
0x7fff4c91a000 - | 0x7fff4c94aff3 com.apple.GSS (4.0 - 2.0) <721B6FEF-9E0E-311B-8CAF-93ADEE2AE548> /System/Library/Frameworks/GSS.framework/Versions/A/GSS | |
0x7fff4ca64000 - | 0x7fff4cb6eff3 com.apple.Bluetooth (6.0.9 - 6.0.9f2) <0EDECAF3-FF86-3F7D-B916-2D7E67FF67AE> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth | |
0x7fff4cbd0000 - | 0x7fff4cc62ff7 com.apple.framework.IOKit (2.0.2 - 1483.220.15) <B58031DE-A6B7-3685-840F-361670C06836> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit | |
0x7fff4cc64000 - | 0x7fff4cc6eff7 com.apple.IOSurface (255.1 - 255.1) <538F0257-A408-36AF-AB1E-1D7037D6359E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface | |
0x7fff4cc6f000 - | 0x7fff4ccc4ff3 com.apple.ImageCaptureCore (1.0 - 1530.1) <C053A62A-AA27-3E5F-97EE-8781E75028EB> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore | |
0x7fff4ccc5000 - | 0x7fff4ce63fff com.apple.ImageIO.framework (3.3.0 - 1821.6.4.1) <00BF9654-021D-33C7-B681-461F3EF357FD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO | |
0x7fff4ce64000 - | 0x7fff4ce68ffb libGIF.dylib (1821.6.4.1) <032CA0C2-8AAA-3D3F-8E61-25CE9267C2A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib | |
0x7fff4ce69000 - | 0x7fff4cf4efef libJP2.dylib (1821.6.4.1) <FED43EEB-2B6C-32FC-94A2-297DA8CE4D87> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib | |
0x7fff4cf4f000 - | 0x7fff4cf74ff7 libJPEG.dylib (1821.6.4.1) <DD334010-2B8D-3A5E-BC17-39A9D94AC92D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib | |
0x7fff4d247000 - | 0x7fff4d26dfe7 libPng.dylib (1821.6.4.1) <EBAAB8C0-33A7-3C13-B96C-8B6AB8287C7A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib | |
0x7fff4d26e000 - | 0x7fff4d270ff7 libRadiance.dylib (1821.6.4.1) <E9BCF8B3-DA07-3F80-B51F-5793BD38AE4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib | |
0x7fff4d271000 - | 0x7fff4d2bffff libTIFF.dylib (1821.6.4.1) <C432D21E-2DA5-3B69-BD04-BA7B6DBEAE2F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib | |
0x7fff4d5c1000 - | 0x7fff4e344fff com.apple.JavaScriptCore (14606 - 14606.2.104.1.1) <3313A815-BFC9-3DED-B778-FCE6F8367A7C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore | |
0x7fff4e35c000 - | 0x7fff4e375fff com.apple.Kerberos (3.0 - 1) <8BE3D524-257D-3663-A937-F1AC76BDF4D9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos | |
0x7fff4e376000 - | 0x7fff4e3abffb com.apple.LDAPFramework (2.4.28 - 194.5) <DC361FB9-4B59-311E-8CC5-07FF9A9C673F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP | |
0x7fff4e633000 - | 0x7fff4e63dfff com.apple.MediaAccessibility (1.0 - 114.4) <29D89F2B-6254-3D0D-BD0C-8472FCA373F4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility | |
0x7fff4e6f7000 - | 0x7fff4ed94fff com.apple.MediaToolbox (1.0 - 2282.19.104.4) <7603C180-8050-3355-A851-A67B6A4197AD> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox | |
0x7fff4ed96000 - | 0x7fff4ee29fff com.apple.Metal (157.60 - 157.60) <B38C577A-CD24-30AD-A396-219945949F39> /System/Library/Frameworks/Metal.framework/Versions/A/Metal | |
0x7fff4ee2b000 - | 0x7fff4ee45ff3 com.apple.MetalKit (1.0 - 113) <8949A0FA-337E-3C28-94D1-35853D69761B> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit | |
0x7fff4ee46000 - | 0x7fff4ee66ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <A9E87429-4788-3B2F-B970-4052F16C5961> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore | |
0x7fff4ee67000 - | 0x7fff4eee5ff7 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <80DE2FD1-85DB-3E98-98BD-F22A2600DD25> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage | |
0x7fff4eee6000 - | 0x7fff4ef0efff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <49039DEE-D0EC-33FF-BE10-997A520D2E38> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix | |
0x7fff4ef0f000 - | 0x7fff4f041ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <425D1FA4-17A3-3D00-8BE4-7A682FF279B5> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork | |
0x7fff4f042000 - | 0x7fff4f05dff7 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <BB1651A0-05CD-3F97-8355-39CD326C0AFD> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector | |
0x7fff4f05e000 - | 0x7fff4f05eff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <3910EC50-5B16-3695-B867-741E3B54FA8B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders | |
0x7fff5025d000 - | 0x7fff50269ffb com.apple.NetFS (6.0 - 4.0) <529E29A9-5E77-3A8C-A982-CF55F949FE5D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS | |
0x7fff5026a000 - | 0x7fff503a9ff7 com.apple.Network (1.0 - 1) <ADE86D62-7847-32D4-96E7-FD05CFC20B97> /System/Library/Frameworks/Network.framework/Versions/A/Network | |
0x7fff52d29000 - | 0x7fff52d81ff7 com.apple.opencl (2.12.7 - 2.12.7) <CCAC9774-C4BF-33C1-AC87-F2AEB972632F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL | |
0x7fff52d82000 - | 0x7fff52d9eff7 com.apple.CFOpenDirectory (10.14 - 207.200.4) <7E4EFF02-2596-31E6-88DE-29C89E2837E4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory | |
0x7fff52d9f000 - | 0x7fff52dabffb com.apple.OpenDirectory (10.14 - 207.200.4) <52A3918E-0F7A-33FD-87EE-21A37B37D13B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory | |
0x7fff5370e000 - | 0x7fff53710fff libCVMSPluginSupport.dylib (17.0.37) <E47B2819-913A-3588-A3F5-CE3EDA8551A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib | |
0x7fff53711000 - | 0x7fff53716ff3 libCoreFSCache.dylib (163.20) <BF8F04DD-C1A1-3D2A-BF3F-639FE907E28D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib | |
0x7fff53717000 - | 0x7fff5371bfff libCoreVMClient.dylib (163.20) <45A2C724-F3D1-316A-9A41-CAB8E2A390EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib | |
0x7fff5371c000 - | 0x7fff53724ffb libGFXShared.dylib (17.0.37) <C26CA5C7-8DFC-3BE9-9873-C7A51F139FB0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib | |
0x7fff53725000 - | 0x7fff53730fff libGL.dylib (17.0.37) <8DCB2714-ECB1-39EC-931D-C58D9E91B51C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib | |
0x7fff53731000 - | 0x7fff5376bfef libGLImage.dylib (17.0.37) <B64C775F-C64F-35D7-8179-1E4F20E76BA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib | |
0x7fff538df000 - | 0x7fff5391cfff libGLU.dylib (17.0.37) <B0D434EF-F5AC-3C0A-84DF-FFAFC57F3759> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib | |
0x7fff542cc000 - | 0x7fff542dbff3 com.apple.opengl (17.0.37 - 17.0.37) <6BCCA53E-5621-32ED-BA9A-38B1C2499ED5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL | |
0x7fff5465d000 - | 0x7fff547a7fff com.apple.QTKit (7.7.3 - 3034) <D612DC6C-0AA8-3D41-9E17-E8219984FC65> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit | |
0x7fff547a8000 - | 0x7fff54a03fff com.apple.imageKit (3.0 - 1067) <A43B90AB-8FCB-35BF-996A-CEB28B67EEB5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit | |
0x7fff54a04000 - | 0x7fff54af0fff com.apple.PDFKit (1.0 - 737.3) <F6981903-7259-3D89-B70E-855F970D84E7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit | |
0x7fff54af1000 - | 0x7fff55007ff7 com.apple.QuartzComposer (5.1 - 370) <AA2ED670-1970-3888-B7DB-D11192EBF6BB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer | |
0x7fff55008000 - | 0x7fff5502eff3 com.apple.quartzfilters (1.10.0 - 83) <06F25528-5474-39BF-BCD4-DD6B3203EA3C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters | |
0x7fff5502f000 - | 0x7fff55135ff7 com.apple.QuickLookUIFramework (5.0 - 775) <41F1FDD0-C99A-36D3-AC3A-A5E604D77F63> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI | |
0x7fff55136000 - | 0x7fff55136fff com.apple.quartzframework (1.5 - 23) <EB8812C6-F126-3262-9B6A-A7A440DFBF8A> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz | |
0x7fff55137000 - | 0x7fff5538ffff com.apple.QuartzCore (1.11 - 694.22.4.1) <1F5A49A9-370C-311B-B67C-DEA6DF6D2983> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore | |
0x7fff55390000 - | 0x7fff553e9ff7 com.apple.QuickLookFramework (5.0 - 775) <A4CA709A-2828-3F04-8786-7FAC8A95B98B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook | |
0x7fff555b0000 - | 0x7fff555c8ffb com.apple.SafariServices.framework (14606 - 14606.2.104.1.1) <189C4DE0-5B88-388F-9CD1-AC15C3936CC2> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices | |
0x7fff55bc4000 - | 0x7fff55bdcfff com.apple.ScriptingBridge (1.4 - 77) <3502C869-965C-3D65-AC25-D18636CBA127> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge | |
0x7fff55bdd000 - | 0x7fff55f03ff7 com.apple.security (7.0 - 58286.220.15) <6725D63D-378F-3751-8602-3122016E4AA4> /System/Library/Frameworks/Security.framework/Versions/A/Security | |
0x7fff55f04000 - | 0x7fff55f93fff com.apple.securityfoundation (6.0 - 55185.200.14) <236BACD7-163F-3F35-B710-2C62988AA251> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation | |
0x7fff55f94000 - | 0x7fff55fc4ffb com.apple.securityinterface (10.0 - 55109.200.8) <F2E44252-2A22-30FD-9706-E33EF75C3ED2> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface | |
0x7fff55fc5000 - | 0x7fff55fc9ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <C200EC23-CAFB-33E8-AF3D-5B36420A21B1> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement | |
0x7fff55fca000 - | 0x7fff56013ff3 com.apple.sociald.Social (???) <85FFE5E9-1201-359D-A9BC-20EC07B2F0B6> /System/Library/Frameworks/Social.framework/Versions/A/Social | |
0x7fff56386000 - | 0x7fff563f6ff3 com.apple.SystemConfiguration (1.17 - 1.17) <EED5BC9B-CE8D-343C-BCDC-04A79F704828> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration | |
0x7fff56657000 - | 0x7fff569b9ff7 com.apple.VideoToolbox (1.0 - 2282.19.104.4) <AA64D2D5-B992-301C-B39E-90852E2DFC95> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox | |
0x7fff56cc7000 - | 0x7fff57255fe7 libwebrtc.dylib (7606.2.104.1.1) <813EBF5C-B865-3A01-BF1F-8DB7A287FF35> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib | |
0x7fff57256000 - | 0x7fff58ad8ff3 com.apple.WebCore (14606 - 14606.2.104.1.1) <50CEEC5A-34FC-339A-A05F-257D9D0F4666> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore | |
0x7fff58ad9000 - | 0x7fff58cc8ffb com.apple.WebKitLegacy (14606 - 14606.2.104.1.1) <D42DC5C3-C35F-3990-A7CE-9871C4F4902C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy | |
0x7fff58cc9000 - | 0x7fff591c6ff7 com.apple.WebKit (14606 - 14606.2.104.1.1) <BFA28A42-A2DA-31A7-86F9-4838F5FEC3B1> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit | |
0x7fff5965d000 - | 0x7fff59702fe7 com.apple.APFS (1.0 - 1) <E00222C4-E8CF-302A-8AF3-E8BB9B1C3B0E> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS | |
0x7fff59c98000 - | 0x7fff59ca2fff com.apple.accessibility.AXCoreUtilities (1.0 - 1) <5C60531F-2E5F-3837-B1FC-2E933A774ED0> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities | |
0x7fff59e81000 - | 0x7fff59f24ffb com.apple.accounts.AccountsDaemon (113 - 113) <BA3596C5-E05F-3342-91F6-92D40E904756> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon | |
0x7fff59f25000 - | 0x7fff59f56ff7 com.apple.framework.accountsui (1.0 - 63.1.0.4) <F86129B4-A5C7-3B0E-A579-084A0FB0DBE2> /System/Library/PrivateFrameworks/AccountsUI.framework/Versions/A/AccountsUI | |
0x7fff59fd4000 - | 0x7fff5a130ffb com.apple.AddressBook.core (1.0 - 1) <55D01A2A-C878-3089-8615-F3510A5B1687> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore | |
0x7fff5a14c000 - | 0x7fff5a14dff3 com.apple.AggregateDictionary (1.0 - 1) <1DEBBE36-8945-3AD8-BD48-2850AD845711> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary | |
0x7fff5a4fa000 - | 0x7fff5a643ff3 com.apple.AnnotationKit (1.0 - 232.3.27) <6CDA223B-CBDF-3960-AC34-BAD648CB580B> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit | |
0x7fff5a749000 - | 0x7fff5a775ff7 com.apple.framework.Apple80211 (13.0 - 1376.2) <821DE2A3-1CAD-3A7D-A2DD-41EBA3A6FEF3> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 | |
0x7fff5aa51000 - | 0x7fff5aa60fcf com.apple.AppleFSCompression (96.200.3 - 1.0) <E093776E-C367-3CCF-BFD5-623476A89E9A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression | |
0x7fff5ab5e000 - | 0x7fff5ab69fff com.apple.AppleIDAuthSupport (1.0 - 1) <5362D9AD-A2AE-3436-97CE-C353124504E5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport | |
0x7fff5abaa000 - | 0x7fff5abf3ff3 com.apple.AppleJPEG (1.0 - 1) <9A690E6E-F987-3660-BED6-B1A4D1906B6C> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG | |
0x7fff5abf4000 - | 0x7fff5ac04ff3 com.apple.AppleLDAP (10.14 - 46.200.2) <1CA0C188-D060-3B80-84A1-6FA90812AF11> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP | |
0x7fff5ae1f000 - | 0x7fff5ae3fffb com.apple.aps.framework (4.0 - 4.0) <F737E01A-E9D1-3A9A-B54B-CA1B9750A08D> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService | |
0x7fff5ae40000 - | 0x7fff5ae44ff7 com.apple.AppleSRP (5.0 - 1) <B8E2BEC9-FAFB-3E26-BF26-E2E58C545006> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP | |
0x7fff5ae45000 - | 0x7fff5ae6dff7 com.apple.applesauce (1.0 - ???) <60BB16D6-DE7E-356A-B9DE-F73EE179934A> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce | |
0x7fff5af34000 - | 0x7fff5af37ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A2EE39BD-C721-33BD-8549-E087C04CF784> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo | |
0x7fff5af38000 - | 0x7fff5af88fff com.apple.AppleVAFramework (5.0.44 - 5.0.44) <A7D2AD26-D52A-39E0-8296-1ADDDB6B6CED> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA | |
0x7fff5afd3000 - | 0x7fff5afe9ffb com.apple.AssertionServices (1.0 - 1) <8FB0D908-6C46-3399-92D6-4E7D4B5F4F19> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices | |
0x7fff5b325000 - | 0x7fff5b5c8ffb com.apple.AuthKit (1.0 - 1) <8920796A-C818-3163-B6D0-FD05D1A6ADF5> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit | |
0x7fff5b799000 - | 0x7fff5b7a2ff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <972F41B3-7DF7-3BF1-ACCA-A093A4328ADF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement | |
0x7fff5b7a3000 - | 0x7fff5b845ff7 com.apple.backup.framework (1.10 - ???) <46534B04-DD0E-357B-9CB5-F88AAC6AF4ED> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup | |
0x7fff5b846000 - | 0x7fff5b8b7ffb com.apple.BaseBoard (360.24 - 360.24) <AC0E4924-994E-3B54-869C-C831B4DE0136> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard | |
0x7fff5b8c0000 - | 0x7fff5b8c6ff3 com.apple.BezelServicesFW (317 - 317) <44601C3E-4808-38A4-A554-71F36000B003> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices | |
0x7fff5b940000 - | 0x7fff5b97cffb com.apple.bom (14.0 - 197) <8BD14107-DB70-3800-9377-618CA230B40A> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom | |
0x7fff5c04a000 - | 0x7fff5c078fff com.apple.CalendarAgentLink (8.0 - 250) <3741CC99-814F-3E74-97A7-B658D8DB5C72> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink | |
0x7fff5c75b000 - | 0x7fff5c7a8fff com.apple.ChunkingLibrary (194 - 194) <13F1F769-E8E7-372A-8F0B-2BB4B7753248> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary | |
0x7fff5c850000 - | 0x7fff5c8dfffb com.apple.CloudDocs (1.0 - 575.120) <94232936-1B40-3EAF-B731-883A4872BCE4> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs | |
0x7fff5d468000 - | 0x7fff5d471fff com.apple.CommonAuth (4.0 - 2.0) <93CF1D80-A3A8-378B-9DF7-BF17A206C57D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth | |
0x7fff5d485000 - | 0x7fff5d49bffb com.apple.commonutilities (8.0 - 900) <BE71A0AD-7ED9-3B2A-BF7D-DA7841640FE0> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities | |
0x7fff5d74f000 - | 0x7fff5d7b9ff7 com.apple.AddressBook.ContactsFoundation (8.0 - ???) <2A910333-619F-3A27-B40E-0A4BF0F75AA8> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation | |
0x7fff5d7ba000 - | 0x7fff5d7deffb com.apple.contacts.ContactsPersistence (1.0 - ???) <6CE2F528-5CD6-35AE-B5BB-30070C5755B6> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence | |
0x7fff5d931000 - | 0x7fff5dd08fef com.apple.CoreAUC (273.0.0 - 273.0.0) <288EC7ED-A86A-30D0-ADE2-56C33CD93AA8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC | |
0x7fff5dd09000 - | 0x7fff5dd3afff com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <507AC58B-4527-353B-99CB-67FF183BD4D5> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD | |
0x7fff5dd58000 - | 0x7fff5dd7afff com.apple.CoreAnalytics.CoreAnalytics (1.0 - 1) <698E1B63-B193-3431-A1C7-9B8D2D62088C> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics | |
0x7fff5ddd2000 - | 0x7fff5de24ffb com.apple.corebrightness (1.0 - 1) <1AE1A7AE-506D-3A52-B710-9CFB16414EDC> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness | |
0x7fff5df68000 - | 0x7fff5df71fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8D971ACD-6A26-30A9-9C5B-BCBF60A661F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon | |
0x7fff5e183000 - | 0x7fff5e197fff com.apple.CoreEmoji (1.0 - 69.19.8) <E909BE8D-AE0C-327E-BE0A-D60B1F4012A4> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji | |
0x7fff5e35d000 - | 0x7fff5e451ff7 com.apple.CoreHandwriting (161 - 1.2) <0BD558D9-387B-34BA-8FAA-F1F75F1F9F01> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting | |
0x7fff5e614000 - | 0x7fff5e62affb com.apple.CoreMediaAuthoring (2.2 - 958) <FD761818-0B54-3DA6-B41C-20263BC2EDAE> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring | |
0x7fff5e76d000 - | 0x7fff5e7dfff7 com.apple.CoreNLP (1.0 - 130.15.22) <401F5284-A984-32A1-A547-CC8156381070> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP | |
0x7fff5e962000 - | 0x7fff5e966ff7 com.apple.CoreOptimization (1.0 - 1) <AEF88F43-C928-3DCB-95D6-C6706B565422> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization | |
0x7fff5e967000 - | 0x7fff5e9f4ff7 com.apple.CorePDF (4.0 - 414) <28DEBFFB-BABE-3493-8230-12CE3E5EC1E3> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF | |
0x7fff5ea9a000 - | 0x7fff5eaa2ffb com.apple.CorePhoneNumbers (1.0 - 1) <F47CA56F-6760-3282-BFD8-C8C8D2C33ECF> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers | |
0x7fff5eaa3000 - | 0x7fff5eafffff com.apple.CorePrediction (1.0 - 1) <BD34AB8C-8899-3BB1-95A2-0A2A1C901ADC> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction | |
0x7fff5ec31000 - | 0x7fff5ec62fff com.apple.CoreServicesInternal (357 - 357) <2D012EB3-83BF-3E51-A2BE-41AF26F2DDF0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal | |
0x7fff5f02c000 - | 0x7fff5f0baff7 com.apple.CoreSymbolication (10.1 - 64460.6) <F985088F-5323-3D84-80FE-3A3135C4A320> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication | |
0x7fff5f14a000 - | 0x7fff5f276fff com.apple.coreui (2.1 - 498.46) <7637C723-B16D-3001-B3AC-0612349D1CC5> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI | |
0x7fff5f277000 - | 0x7fff5f3fcfff com.apple.CoreUtils (5.7.4 - 574.17) <CA6C08FE-319A-30C6-9F07-68D12A9FA04E> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils | |
0x7fff5f453000 - | 0x7fff5f4b6ffb com.apple.framework.CoreWiFi (13.0 - 1370.8) <B44C1B90-3642-3108-96EC-5E3A8FA158E7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi | |
0x7fff5f4b7000 - | 0x7fff5f4c8ffb com.apple.CrashReporterSupport (10.13 - 938.23) <36754BB2-680F-36AE-A5DE-548B4F41F0AE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport | |
0x7fff5f54b000 - | 0x7fff5f55aff3 com.apple.framework.DFRFoundation (1.0 - 211) <B11AD3BE-42D3-3274-912E-153C015D72EE> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation | |
0x7fff5f55b000 - | 0x7fff5f55fff7 com.apple.DSExternalDisplay (3.1 - 380) <B6B26BB3-2DC9-34D0-817E-EB612432EC96> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay | |
0x7fff5f5a3000 - | 0x7fff5f5e1fff com.apple.datadetectors (5.0 - 390) <23B6955E-FFDD-36D3-B66C-C321D84CB1A3> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors | |
0x7fff5f5e2000 - | 0x7fff5f659ffb com.apple.datadetectorscore (7.0 - 590.24) <1C9AC888-8B75-3CF3-AD70-42D40C435E67> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore | |
0x7fff5f6a7000 - | 0x7fff5f6e8fff com.apple.DebugSymbols (185 - 185) <12419E0F-BC7A-3F3A-AA53-5F068DAED725> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols | |
0x7fff5f6e9000 - | 0x7fff5f842ff7 com.apple.desktopservices (1.13.1 - ???) <D63561E0-6153-33AD-9689-E0B9167D82C8> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv | |
0x7fff5f8dd000 - | 0x7fff5f8deff7 com.apple.diagnosticlogcollection (10.0 - 1000) <66A9915F-B247-38F7-A43D-0AB68CFAF6F3> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection | |
0x7fff5f974000 - | 0x7fff5fa46ff7 com.apple.DiskImagesFramework (480.220.2 - 480.220.2) <9921E083-1159-3671-92E5-868A88A11B1B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages | |
0x7fff5fa47000 - | 0x7fff5fb0bfff com.apple.DiskManagement (12.0 - 1530) <F844A618-613A-3609-9C31-621D92FB75DD> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement | |
0x7fff5fb0c000 - | 0x7fff5fb10ff7 com.apple.DisplayServicesFW (3.1 - 380) <511645F4-94EB-33A0-A076-66402F52581A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices | |
0x7fff5fbb4000 - | 0x7fff5fbb7fff com.apple.EFILogin (2.0 - 2) <8FCA68D2-CEA5-39F6-B222-AC31FCF79D1D> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin | |
0x7fff60384000 - | 0x7fff6039bff3 com.apple.Engram (1.0 - 1) <A7A2BA5D-34D9-30DB-BEC5-DCCBBC98BE60> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram | |
0x7fff6039c000 - | 0x7fff606cffff com.apple.vision.EspressoFramework (1.0 - 120) <7B2CB758-7FD9-3D6B-9BD4-AFD254008BEF> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso | |
0x7fff6088a000 - | 0x7fff60cb2fff com.apple.vision.FaceCore (3.3.4 - 3.3.4) <CCBC466A-1AD4-3B0B-80B2-D6CFCBB37FC0> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore | |
0x7fff60ce5000 - | 0x7fff60d71ff7 com.apple.FileProvider (125.129 - 125.129) <31642A56-F183-3DA3-8713-745358CAE55D> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider | |
0x7fff60d8a000 - | 0x7fff6120aff7 com.apple.FinderKit (1.7 - ???) <7D933EAA-7B52-327E-B77F-DF63A0C03481> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit | |
0x7fff645d4000 - | 0x7fff645d5fff libmetal_timestamp.dylib (902.1.60) <16F3973E-20CB-3FFA-9C8B-A2287AF03AA0> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib | |
0x7fff65c7a000 - | 0x7fff65c7fff7 com.apple.GPUWrangler (3.25.6 - 3.25.6) <F65BC9B4-77AB-3254-8432-9F7D3B0E169E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler | |
0x7fff6602f000 - | 0x7fff66054ff7 com.apple.GenerationalStorage (2.0 - 285.101) <089301DF-60C9-3BED-9357-2F91336C1579> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage | |
0x7fff6606d000 - | 0x7fff66aa2ff7 com.apple.GeoServices (1.0 - 1364.21.8.31.5) <8C22C9A9-B322-3CED-9714-9F3365845C4C> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices | |
0x7fff66ae5000 - | 0x7fff66af4fff com.apple.GraphVisualizer (1.0 - 5) <C7040CD7-6CAB-3878-B29E-21F1665341D0> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer | |
0x7fff66af5000 - | 0x7fff66b02fff com.apple.GraphicsServices (1.0 - 1.0) <F099E6ED-E08D-3F37-B381-0DF3109B27AA> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices | |
0x7fff66c45000 - | 0x7fff66cbafff com.apple.Heimdal (4.0 - 2.0) <D3A3285B-A45D-38A9-A4E9-D58D76674071> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal | |
0x7fff66cbb000 - | 0x7fff66ceafff com.apple.HelpData (2.3 - 184) <56A7277E-B1C3-3AD8-AF4B-8BAA41D6E640> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData | |
0x7fff67793000 - | 0x7fff678a2ff3 com.apple.ids (10.0 - 1000) <63A00A35-7F7B-34FF-B9B2-160CD6E4697E> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS | |
0x7fff678a3000 - | 0x7fff679aafff com.apple.idsfoundation (10.0 - 1000) <7E85F5A1-C419-3F47-9E6F-81EFE1D2EFB1> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation | |
0x7fff67f63000 - | 0x7fff67fc8ff3 com.apple.imfoundation (10.0 - 1000) <0B3040A6-7DD8-3C63-BECC-F0846DDC368C> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation | |
0x7fff6809c000 - | 0x7fff680a5fff com.apple.IOAccelMemoryInfo (1.0 - 1) <DCE6223D-D65D-39F2-90BC-34A1808EF6BD> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo | |
0x7fff680a6000 - | 0x7fff680adffb com.apple.IOAccelerator (400.27 - 400.27) <6FA8A133-57A7-3C35-BF94-8469B09885FB> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator | |
0x7fff680b1000 - | 0x7fff680cafff com.apple.IOPresentment (1.0 - 42.6) <C115E88F-5E16-3804-8ACD-29C0F8895EFA> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment | |
0x7fff684df000 - | 0x7fff6850eff7 com.apple.IconServices (379 - 379) <0A25D75C-35A7-3ED5-8900-EBC05522B5A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices | |
0x7fff68639000 - | 0x7fff6863dfff com.apple.InternationalSupport (1.0 - 10.15.6) <F0E300AD-1E67-3D57-B179-C2212F7CD00C> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport | |
0x7fff686aa000 - | 0x7fff686b7fff com.apple.IntlPreferences (2.0 - 227.15.8) <329CA6FA-7A55-35F2-AB6D-A6F0E65BA23F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences | |
0x7fff687ad000 - | 0x7fff687c0fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <1DB4E862-C010-38BA-B535-5DAD679FEADA> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle | |
0x7fff687db000 - | 0x7fff688d2fff com.apple.LanguageModeling (1.0 - 159.15.15) <E524CC46-42C7-3046-AD6C-5D5D768EA478> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling | |
0x7fff688d3000 - | 0x7fff68914ff7 com.apple.Lexicon-framework (1.0 - 33.15.10) <90C1CFE1-9935-3F4F-8A9B-1DD697F2FF3D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon | |
0x7fff6891b000 - | 0x7fff68921ff7 com.apple.LinguisticData (1.0 - 238.15.29) <A8DEE139-5D20-3BAC-AF5E-4E5E0C42C795> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData | |
0x7fff68a1a000 - | 0x7fff68a1fffb com.apple.LoginUICore (4.0 - 4.0) <2528E230-11E9-3436-ADCF-ED149F50A264> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore | |
0x7fff68a87000 - | 0x7fff68aa1fff com.apple.LookupFramework (1.2 - 251) <603045DC-6529-34F6-83B5-59065274AEC4> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup | |
0x7fff6917f000 - | 0x7fff69182fff com.apple.Mangrove (1.0 - 25) <8744DBF9-3375-392C-8EE6-24373E0D19E8> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove | |
0x7fff6920d000 - | 0x7fff6920fff3 com.apple.marco (10.0 - 1000) <994AADC2-F63E-3AA3-9059-15F2B45EA926> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco | |
0x7fff69210000 - | 0x7fff69237ffb com.apple.MarkupUI (1.0 - 232.3.27) <B78BC7CF-A267-3E53-A876-6F5C02BB2AB8> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI | |
0x7fff692a0000 - | 0x7fff692d3ff3 com.apple.MediaKit (16 - 906) <15D4EDA2-AAAC-3CF3-BB2B-3A92AECC932D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit | |
0x7fff6967d000 - | 0x7fff696a5ffb com.apple.spotlight.metadata.utilities (1.0 - 1191.52) <38A9B11A-9D5C-3CCA-A163-EC17242FDC68> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities | |
0x7fff696a6000 - | 0x7fff69738fff com.apple.gpusw.MetalTools (1.0 - 1) <5B86F005-D12D-3B0B-8906-808926D3DA12> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools | |
0x7fff6974d000 - | 0x7fff69766fff com.apple.MobileAssets (1.0 - 437.200.49) <0C9B7077-BFCF-3A2E-8F54-D7C2820893FD> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset | |
0x7fff698e2000 - | 0x7fff698fdff3 com.apple.MobileKeyBag (2.0 - 1.0) <6E36F030-D7E8-341D-A493-414F5E13B1E9> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag | |
0x7fff6990e000 - | 0x7fff6998aff7 com.apple.Montreal (1.0 - 42.15.8) <F7AAEEC2-B981-30C4-995F-4D98FB808984> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal | |
0x7fff6998b000 - | 0x7fff699b5ff7 com.apple.MultitouchSupport.framework (2410.5 - 2410.5) <8D87A3ED-4CBD-300F-92E3-B1B79D7E0BF3> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport | |
0x7fff69c28000 - | 0x7fff69c32fff com.apple.NetAuth (6.2 - 6.2) <55DC741A-A01A-380C-B2D3-244241DA1F2C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth | |
0x7fff6a3b7000 - | 0x7fff6a3b9fff com.apple.OAuth (25 - 25) <8938B438-399A-3B1A-99DF-956A5A5BF8FF> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth | |
0x7fff6a4fe000 - | 0x7fff6a554fff com.apple.OTSVG (1.0 - ???) <5F2E7A0E-384E-3545-A9D5-EC4406E92AF4> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG | |
0x7fff6b5b3000 - | 0x7fff6b6b9ff7 com.apple.PencilKit (1.0 - 1) <188DB13A-53B4-3F3C-8433-193AEAFDF17D> /System/Library/PrivateFrameworks/PencilKit.framework/Versions/A/PencilKit | |
0x7fff6b6ba000 - | 0x7fff6b6c9ff3 com.apple.PerformanceAnalysis (1.217 - 217) <8560F263-31F4-3CCA-84B1-30C296DC1A7D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis | |
0x7fff6b924000 - | 0x7fff6b924fff com.apple.PhoneNumbers (1.0 - 1) <739CE787-1F32-3EE3-90C7-4D0522A25092> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers | |
0x7fff6d1e1000 - | 0x7fff6d206ff7 com.apple.pluginkit.framework (1.0 - 1) <279FC41A-AEAA-3400-9AE7-1FC6E53BC549> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit | |
0x7fff6d231000 - | 0x7fff6d243ff3 com.apple.PowerLog (1.0 - 1) <F9F2A6D3-79EB-3DFE-9197-1EA780767CC5> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog | |
0x7fff6d631000 - | 0x7fff6d688ff7 com.apple.ProtectedCloudStorage (1.0 - 1) <C37D89CF-707A-3151-A37B-911AF6BF3B23> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage | |
0x7fff6d689000 - | 0x7fff6d6a7ff7 com.apple.ProtocolBuffer (1 - 263) <C5AC21FB-74AD-3FC2-B231-B1376751BBAE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer | |
0x7fff6d83b000 - | 0x7fff6d83eff3 com.apple.QuickLookNonBaseSystem (1.0 - 1) <ABB9436A-7E52-3232-ACE8-45083130C82A> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem | |
0x7fff6d83f000 - | 0x7fff6d855ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <AAF7A93C-5553-3476-B2F2-B8B1DA2BEF54> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing | |
0x7fff6d856000 - | 0x7fff6d8aef0f com.apple.ROCKit (24 - 24) <5437F6F7-453F-3D75-9E87-D2A090D82D25> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit | |
0x7fff6d9aa000 - | 0x7fff6d9b6ff3 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1336.220.5) <79F17D52-38B4-360E-88AC-CF1E3944CA7E> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery | |
0x7fff6d9c9000 - | 0x7fff6d9ecffb com.apple.RemoteViewServices (2.0 - 128) <68530B4D-B2C0-3271-941B-D9EA62095727> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices | |
0x7fff6d9ed000 - | 0x7fff6da01fff com.apple.xpc.RemoteXPC (1.0 - 1336.220.5) <D258016E-4FE2-3E99-9699-33D56BADD619> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC | |
0x7fff6e85a000 - | 0x7fff6e8a4ff7 com.apple.Safari.SafeBrowsing (14606 - 14606.2.104.1.1) <E7BC40BA-F760-3F28-9E07-7253A08B77D7> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing | |
0x7fff6f2d5000 - | 0x7fff6f34efff com.apple.ShareKit (577 - 577) <274D28E2-0DB2-3D22-9B3F-DC3D1A061700> /System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/ShareKit | |
0x7fff6f34f000 - | 0x7fff6f357ffb com.apple.coreservices.SharePointManager (1.0 - 57.1) <CC640F04-85B2-3617-B52F-1CE400549380> /System/Library/PrivateFrameworks/SharePointManagement.framework/Versions/A/SharePointManagement | |
0x7fff6f35c000 - | 0x7fff6f47afff com.apple.Sharing (1214.9 - 1214.9) <2A377CA5-C66F-3913-8401-951A3AE4D299> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing | |
0x7fff6f47b000 - | 0x7fff6f49aff3 com.apple.shortcut (2.16 - 101) <D724B49E-C972-31CC-B47C-8CB769A3E0B0> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut | |
0x7fff6f49b000 - | 0x7fff6f4adff7 com.apple.sidecar-core (1.0 - 38.1) <ED88E1A7-F24F-32A4-A0B7-933A01EF669B> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore | |
0x7fff6f4ae000 - | 0x7fff6f4beffb com.apple.sidecar-ui (1.0 - 38.1) <C4D00FAC-A43D-3B25-A684-FB8D74D46CBE> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI | |
0x7fff7022d000 - | 0x7fff704deff3 com.apple.SkyLight (1.600.0 - 336.81.5) <DE7FD278-A178-3A5B-8A26-7295340A54BE> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight | |
0x7fff70cae000 - | 0x7fff70cbbfff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <816EC315-3E76-37B7-A495-B4AE031DA439> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore | |
0x7fff70d77000 - | 0x7fff70fdfffb com.apple.spotlight.index (10.7.0 - 1191.52) <35500671-A576-3B70-B7B0-BA16E8AF31D6> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex | |
0x7fff7139f000 - | 0x7fff713deff3 com.apple.StreamingZip (1.0 - 1) <3F13DFEE-A6C9-3815-9120-B5CA6987662E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip | |
0x7fff713df000 - | 0x7fff71450ffb com.apple.Suggestions (6.0 - 226) <7B04BAF2-B734-3238-8F38-74629ADE6CF2> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions | |
0x7fff71b1b000 - | 0x7fff71ba8ff7 com.apple.Symbolication (10.1 - 64460.8) <1B488612-4C7F-3D9D-B6DC-64CF8D2CB3D6> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication | |
0x7fff71ba9000 - | 0x7fff71bb2ffb com.apple.SymptomDiagnosticReporter (1.0 - 820.227.2) <922102BF-0F85-3396-910B-B27255F15A4F> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter | |
0x7fff71e04000 - | 0x7fff71e30fff com.apple.framework.SystemAdministration (1.0 - 1.0) <E41D573A-C356-344E-9E67-809F30D9DEF4> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration | |
0x7fff720b1000 - | 0x7fff720beffb com.apple.TCC (1.0 - 1) <B84E7234-A993-328C-A054-EFEB0402C55C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC | |
0x7fff72330000 - | 0x7fff723f7ff7 com.apple.TextureIO (3.8.4 - 3.8.1) <F9D5F55D-9A33-326E-8B2F-B533CC91DD64> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO | |
0x7fff72455000 - | 0x7fff72470fff com.apple.ToneKit (1.0 - 1) <B353747A-3E09-3FA3-BDB2-598A891ACA8A> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit | |
0x7fff72471000 - | 0x7fff72499ffb com.apple.ToneLibrary (1.0 - 1) <3AEA8490-6454-3156-B11D-6B816EA2FE9A> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary | |
0x7fff724b1000 - | 0x7fff724b2fff com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <BD0BE410-E172-3585-82B2-869A1FE43092> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent | |
0x7fff724b8000 - | 0x7fff72672fff com.apple.UIFoundation (1.0 - 551) <7B73C4E0-256B-3C59-8E18-475A42BE0B12> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation | |
0x7fff726c1000 - | 0x7fff726c7fff com.apple.URLFormatting (59 - 59.34) <D104A904-5B18-368E-8290-35212094D9F5> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting | |
0x7fff73361000 - | 0x7fff7344aff7 com.apple.ViewBridge (401.1 - 401.1) <B93A89EB-4421-3FF1-AA28-EBC3AC5076FE> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge | |
0x7fff738cf000 - | 0x7fff73b3bffb libAWDSupportFramework.dylib (886) <F277AAEA-4ACE-3918-9651-8E4730AC4ACF> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib | |
0x7fff73b3c000 - | 0x7fff73b4dfff libprotobuf-lite.dylib (886) <04FE1231-9041-3C52-9C20-AA094C532C92> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib | |
0x7fff73b4e000 - | 0x7fff73bb0ff7 libprotobuf.dylib (886) <D5E8BAE2-D40B-3A29-9CB7-23242FCE14EA> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib | |
0x7fff73bb1000 - | 0x7fff73bf7fff com.apple.awd (1.0 - 930.11) <5CB90468-CD2B-3741-A950-0916E1C8CBBE> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics | |
0x7fff73c6a000 - | 0x7fff73c6dfff com.apple.dt.XCTTargetBootstrap (1.0 - 1) <697834E4-FEFD-305C-80EE-5052E61573FA> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap | |
0x7fff73c75000 - | 0x7fff73cd5ff7 com.apple.xquery (1.3.1 - 30) <DB666CD4-4C35-316A-8D7A-CF8CD6CEF36F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery | |
0x7fff7409e000 - | 0x7fff740a0ff3 com.apple.loginsupport (1.0 - 1) <5F1E000D-0674-3413-AB3E-83F7974666FB> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport | |
0x7fff740a1000 - | 0x7fff740b6fff com.apple.login (3.0 - 3.0) <474C5E41-1326-3E78-A154-218D618D6BD4> /System/Library/PrivateFrameworks/login.framework/Versions/A/login | |
0x7fff740ed000 - | 0x7fff7411fffb com.apple.contacts.vCard (1.0 - ???) <FE9F0A13-7FB7-334B-97C1-5730E388C84D> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard | |
0x7fff742c6000 - | 0x7fff742d9ffb libAccessibility.dylib (2402.39.1) <8DCEF4C2-7004-391B-B872-980AE10BB077> /usr/lib/libAccessibility.dylib | |
0x7fff7435a000 - | 0x7fff74392fff libCRFSuite.dylib (41.15.4) <62EDD39F-6D1B-334B-A9A2-5800714255BB> /usr/lib/libCRFSuite.dylib | |
0x7fff74395000 - | 0x7fff743a0ff7 libChineseTokenizer.dylib (28.15.3) <8CD1C213-7F62-3F02-BFB1-D0A5EFF92AB0> /usr/lib/libChineseTokenizer.dylib | |
0x7fff743a1000 - | 0x7fff7442dff7 libCoreStorage.dylib (546.50.1) <F56AD958-416C-38EA-9829-DEAAB1F0C155> /usr/lib/libCoreStorage.dylib | |
0x7fff74431000 - | 0x7fff74432ff7 libDiagnosticMessagesClient.dylib (107) <C542CB3C-AA44-3D7F-B88C-79CC31B481AB> /usr/lib/libDiagnosticMessagesClient.dylib | |
0x7fff74469000 - | 0x7fff7462cff7 libFosl_dynamic.dylib (18.3.2) <6EF1CB2A-2BDA-3458-B631-F794D72660FD> /usr/lib/libFosl_dynamic.dylib | |
0x7fff74682000 - | 0x7fff746a1fff libMobileGestalt.dylib (645.220.9) <F303B3D9-C6AD-30B9-9414-09DB34357E12> /usr/lib/libMobileGestalt.dylib | |
0x7fff746a2000 - | 0x7fff746a2fff libOpenScriptingUtil.dylib (179) <0664670D-C7E1-3D27-814B-B9C445AAF0DC> /usr/lib/libOpenScriptingUtil.dylib | |
0x7fff747e3000 - | 0x7fff747e4ffb libSystem.B.dylib (1252.200.5) <D5AFCC78-2AC2-37EB-B0EF-BB00FD38ED00> /usr/lib/libSystem.B.dylib | |
0x7fff747e5000 - | 0x7fff7486dff7 libTelephonyUtilDynamic.dylib (3609) <56815350-CAD8-33A0-B958-D7503B4DC519> /usr/lib/libTelephonyUtilDynamic.dylib | |
0x7fff7486e000 - | 0x7fff7486ffff libThaiTokenizer.dylib (2.15.1) <A8235B04-F541-3856-BE2E-B58EE0483AD9> /usr/lib/libThaiTokenizer.dylib | |
0x7fff74882000 - | 0x7fff74898ffb libapple_nghttp2.dylib (1.24.1) <B8D45114-3868-3154-BC35-22597E3E7D8A> /usr/lib/libapple_nghttp2.dylib | |
0x7fff74899000 - | 0x7fff748c2ffb libarchive.2.dylib (54.200.3) <B47C54A0-3A30-374A-BD99-2304B9B0EC82> /usr/lib/libarchive.2.dylib | |
0x7fff748c3000 - | 0x7fff74942fef libate.dylib (1.13.8) <C647A80F-6F80-3FDA-A9B4-92800999F963> /usr/lib/libate.dylib | |
0x7fff74946000 - | 0x7fff74946ff3 libauto.dylib (187) <01824E49-F2EF-3FC1-ABF3-782EFDF6CA17> /usr/lib/libauto.dylib | |
0x7fff74947000 - | 0x7fff74a1cff7 libboringssl.dylib (109.220.4) <40015722-01B3-3E55-84ED-07448ACDA101> /usr/lib/libboringssl.dylib | |
0x7fff74a1d000 - | 0x7fff74a2dff3 libbsm.0.dylib (39.200.18) <5E5098D0-F7B2-32A1-8038-E709F6718D4E> /usr/lib/libbsm.0.dylib | |
0x7fff74a2e000 - | 0x7fff74a3cfff libbz2.1.0.dylib (38.200.3) <4EE3C5E8-BEF3-3910-A231-B1AE2B437E01> /usr/lib/libbz2.1.0.dylib | |
0x7fff74a3d000 - | 0x7fff74a94ff7 libc++.1.dylib (400.9.4) <D4AB366F-48A9-3C7D-91BD-41198F69DD57> /usr/lib/libc++.1.dylib | |
0x7fff74a95000 - | 0x7fff74aaafff libc++abi.dylib (400.17) <BA948A32-9024-3E55-98D4-18E31F6AED25> /usr/lib/libc++abi.dylib | |
0x7fff74aab000 - | 0x7fff74aabff3 libcharset.1.dylib (51.200.6) <D998A58B-E4A8-3685-9A6A-43AFC28100EB> /usr/lib/libcharset.1.dylib | |
0x7fff74aac000 - | 0x7fff74abcffb libcmph.dylib (6.15.1) <5D776FF6-DF7F-3EDD-B920-C07ED76C672B> /usr/lib/libcmph.dylib | |
0x7fff74abd000 - | 0x7fff74ad5ffb libcompression.dylib (52.200.13) <EA767836-CBDC-318D-AC14-963C90D6CC67> /usr/lib/libcompression.dylib | |
0x7fff74d80000 - | 0x7fff74d96fff libcoretls.dylib (155.220.1) <3F98C144-397C-36A2-84F1-BB0D841D3D89> /usr/lib/libcoretls.dylib | |
0x7fff74d97000 - | 0x7fff74d98ff3 libcoretls_cfhelpers.dylib (155.220.1) <0C190169-8EB8-3BA2-89BB-60265BB502F9> /usr/lib/libcoretls_cfhelpers.dylib | |
0x7fff74e4e000 - | 0x7fff74f36ff7 libcrypto.0.9.8.dylib (76.200.2) <0B2819E5-A99F-3165-904D-3A659669D8C7> /usr/lib/libcrypto.0.9.8.dylib | |
0x7fff75262000 - | 0x7fff753faff7 libcrypto.42.dylib (22.200.4) <EFCEE49A-759B-3A9A-A164-ECD1A98D40F9> /usr/lib/libcrypto.42.dylib | |
0x7fff753fb000 - | 0x7fff75406ff7 libcsfde.dylib (546.50.1) <65E8F1F1-665A-381E-8932-D7CBA451991B> /usr/lib/libcsfde.dylib | |
0x7fff7540f000 - | 0x7fff75465ffb libcups.2.dylib (462.9) <51E06E95-891F-3B88-A8C3-35B514C57239> /usr/lib/libcups.2.dylib | |
0x7fff7548f000 - | 0x7fff754e3ff3 libcurl.4.dylib (105.200.2) <607613FE-3D84-3035-9C79-C6F72AF287D7> /usr/lib/libcurl.4.dylib | |
0x7fff7559d000 - | 0x7fff7559dfff libenergytrace.dylib (17.200.1) <D62ED169-B91C-3CCB-ADF5-E66AE4007B51> /usr/lib/libenergytrace.dylib | |
0x7fff755cf000 - | 0x7fff755d4ff7 libgermantok.dylib (17.15.2) <9CBF0658-E83B-32E6-B674-3EE72D22C041> /usr/lib/libgermantok.dylib | |
0x7fff755d5000 - | 0x7fff755daff7 libheimdal-asn1.dylib (520.220.2) <5302394C-ECF0-3C3B-BA67-4830EEF3CC40> /usr/lib/libheimdal-asn1.dylib | |
0x7fff75606000 - | 0x7fff756f7ff7 libiconv.2.dylib (51.200.6) <3240A278-F537-3EC8-BE0C-983797520A50> /usr/lib/libiconv.2.dylib | |
0x7fff756f8000 - | 0x7fff7595bffb libicucore.A.dylib (62108.0.1) <969815D4-A345-31BB-82B7-0C3B58CA7E90> /usr/lib/libicucore.A.dylib | |
0x7fff759a8000 - | 0x7fff759a9fff liblangid.dylib (128.15.1) <F79B6250-C0B1-3E8E-851F-6CA33B4311A3> /usr/lib/liblangid.dylib | |
0x7fff759aa000 - | 0x7fff759c2fff liblzma.5.dylib (10.200.3) <3ADDFA63-F37A-3C9C-91E4-58EE3113B9A1> /usr/lib/liblzma.5.dylib | |
0x7fff759da000 - | 0x7fff75a8afff libmecab.1.0.0.dylib (779.19.2) <314FE1B9-3B4E-3B89-A101-33CE7B78FCE6> /usr/lib/libmecab.1.0.0.dylib | |
0x7fff75a8b000 - | 0x7fff75cc8fff libmecabra.dylib (779.19.2) <0ECEC3FC-935D-3EA5-8B3D-5CBD4E80AB78> /usr/lib/libmecabra.dylib | |
0x7fff75ea0000 - | 0x7fff761f8fff libnetwork.dylib (1229.221.1) <CE7ACD18-109F-382E-963B-C68419E301A1> /usr/lib/libnetwork.dylib | |
0x7fff76289000 - | 0x7fff76a0ffe7 libobjc.A.dylib (750.1) <9CE27EC3-3A12-35D1-8F2F-3550B9668259> /usr/lib/libobjc.A.dylib | |
0x7fff76a10000 - | 0x7fff76a11fff libodfde.dylib (24.50.1) <B948D85A-165F-3E58-A8DD-24CF6454380A> /usr/lib/libodfde.dylib | |
0x7fff76a22000 - | 0x7fff76a26ffb libpam.2.dylib (22.200.1) <8C419238-675A-3C41-B8D4-95E391CA630F> /usr/lib/libpam.2.dylib | |
0x7fff76a29000 - | 0x7fff76a5fff7 libpcap.A.dylib (79.200.4) <5939AB23-B2A9-3C03-B6C1-4F0E5A21D9FC> /usr/lib/libpcap.A.dylib | |
0x7fff76a60000 - | 0x7fff76a9cff3 libpcre.0.dylib (9) <E756BD3C-C54E-3D7D-85C3-90195F4342B5> /usr/lib/libpcre.0.dylib | |
0x7fff76b79000 - | 0x7fff76b91ffb libresolv.9.dylib (65.200.2) <0FEAEB01-B926-37FA-AB47-99BAC481C10B> /usr/lib/libresolv.9.dylib | |
0x7fff76bd0000 - | 0x7fff76be2ff7 libsasl2.2.dylib (211) <205CC13E-4ED7-3CE9-987F-12B28C6115A7> /usr/lib/libsasl2.2.dylib | |
0x7fff76be3000 - | 0x7fff76be4ff7 libspindump.dylib (267.1) <528373EB-C7E9-3682-80CC-0EFCE0F3391D> /usr/lib/libspindump.dylib | |
0x7fff76be5000 - | 0x7fff76dbcfe7 libsqlite3.dylib (274.20) <4434B695-BC65-30D6-AFED-1B6488DB3D2E> /usr/lib/libsqlite3.dylib | |
0x7fff76ebf000 - | 0x7fff76f0cfff libssl.44.dylib (22.200.4) <CF4931A6-5928-3E2B-8E31-1854F36B0C19> /usr/lib/libssl.44.dylib | |
0x7fff76f0d000 - | 0x7fff76f5eff7 libstdc++.6.dylib (104.1) <0E48A478-4CFD-3111-8027-1047508A1D73> /usr/lib/libstdc++.6.dylib | |
0x7fff76f95000 - | 0x7fff76fc5fff libtidy.A.dylib (16.1) <435FB24F-0289-3330-B485-713909D6DA44> /usr/lib/libtidy.A.dylib | |
0x7fff76fe9000 - | 0x7fff77048ff3 libusrtcp.dylib (1229.221.1) <7AB42596-89F7-3026-8289-AB2682153A36> /usr/lib/libusrtcp.dylib | |
0x7fff77049000 - | 0x7fff7704cffb libutil.dylib (51.200.4) <91EE9BF4-FB06-3260-B502-7EFDAD5AF59B> /usr/lib/libutil.dylib | |
0x7fff7704d000 - | 0x7fff7705afff libxar.1.dylib (404) <4B4D0206-0B62-3E89-AD07-E7BB9E4DFA68> /usr/lib/libxar.1.dylib | |
0x7fff7705f000 - | 0x7fff77142fff libxml2.2.dylib (32.8) <1CE77741-2E67-34B6-BB9F-B8E043966FCE> /usr/lib/libxml2.2.dylib | |
0x7fff77143000 - | 0x7fff7716bff3 libxslt.1.dylib (16.1) <F191E8B9-7530-30CA-873B-2FA2BF2D6374> /usr/lib/libxslt.1.dylib | |
0x7fff7716c000 - | 0x7fff7717effb libz.1.dylib (70.200.4) <99A3D725-8388-38B4-B66C-5E9006E6F072> /usr/lib/libz.1.dylib | |
0x7fff771ac000 - | 0x7fff771adffb liblog_network.dylib (1229.221.1) <831417A5-7989-3BA5-B120-784B5EF83A54> /usr/lib/log/liblog_network.dylib | |
0x7fff771ef000 - | 0x7fff771f3ff3 libcache.dylib (81) <FE21A7E9-DBEB-33AC-836B-785AD036ACF4> /usr/lib/system/libcache.dylib | |
0x7fff771f4000 - | 0x7fff771feff3 libcommonCrypto.dylib (60118.220.1) <1099E427-6E81-3059-87AF-6F5FD81CA998> /usr/lib/system/libcommonCrypto.dylib | |
0x7fff771ff000 - | 0x7fff77206fff libcompiler_rt.dylib (63.4) <A4D9CF37-D076-3CE9-95F1-DA89DA1601B6> /usr/lib/system/libcompiler_rt.dylib | |
0x7fff77207000 - | 0x7fff77210ff3 libcopyfile.dylib (146.200.3) <4BCDADBF-79F5-3829-B47D-64DA0D44BCBF> /usr/lib/system/libcopyfile.dylib | |
0x7fff77211000 - | 0x7fff77295fdf libcorecrypto.dylib (602.220.6) <E1046E01-A2FD-35B4-B018-ACC372F3880E> /usr/lib/system/libcorecrypto.dylib | |
0x7fff7731c000 - | 0x7fff77356ff7 libdispatch.dylib (1008.220.2) <D8B56783-152A-34A8-94E9-8E6BAE049384> /usr/lib/system/libdispatch.dylib | |
0x7fff77357000 - | 0x7fff77386fff libdyld.dylib (635.2) <1B79A5CE-125F-301F-A441-C1869573AED0> /usr/lib/system/libdyld.dylib | |
0x7fff77387000 - | 0x7fff77387ffb libkeymgr.dylib (30) <A73AA788-C35C-3284-BFCA-95B1BBDF0CF3> /usr/lib/system/libkeymgr.dylib | |
0x7fff77388000 - | 0x7fff77394ff7 libkxld.dylib (4903.221.2) <16D75C5C-584A-3848-84C0-3BFB312AEB92> /usr/lib/system/libkxld.dylib | |
0x7fff77395000 - | 0x7fff77395ff7 liblaunch.dylib (1336.220.5) <95EB6EAF-2DC5-344F-BADB-CA4E35E4E503> /usr/lib/system/liblaunch.dylib | |
0x7fff77396000 - | 0x7fff7739bfff libmacho.dylib (921) <ECC4E97C-575E-3A08-8191-BF02D7D4E637> /usr/lib/system/libmacho.dylib | |
0x7fff7739c000 - | 0x7fff7739effb libquarantine.dylib (86.220.1) <6AE5AEEC-A9FD-3CF8-92DD-12B5AFBE12DE> /usr/lib/system/libquarantine.dylib | |
0x7fff7739f000 - | 0x7fff773a0ff3 libremovefile.dylib (45.200.2) <D74A307B-3DC7-3992-B16C-DACB8207BE13> /usr/lib/system/libremovefile.dylib | |
0x7fff773a1000 - | 0x7fff773b8ff3 libsystem_asl.dylib (356.200.4) <EC9D8AD4-E5CB-3765-804A-9E1E9DC045D2> /usr/lib/system/libsystem_asl.dylib | |
0x7fff773b9000 - | 0x7fff773b9fff libsystem_blocks.dylib (73) <26419398-C30C-30F1-B656-A92AFA9560F6> /usr/lib/system/libsystem_blocks.dylib | |
0x7fff773ba000 - | 0x7fff77442fff libsystem_c.dylib (1272.200.26) <3DEEE96E-6DF6-35AD-8654-D69AC26B907B> /usr/lib/system/libsystem_c.dylib | |
0x7fff77443000 - | 0x7fff77446ff7 libsystem_configuration.dylib (963.200.27) <02CC3996-B34E-333C-8806-AE2699D34424> /usr/lib/system/libsystem_configuration.dylib | |
0x7fff77447000 - | 0x7fff7744aff7 libsystem_coreservices.dylib (66) <254B6849-2C8F-302C-8616-B8324A11AB30> /usr/lib/system/libsystem_coreservices.dylib | |
0x7fff7744b000 - | 0x7fff77451ffb libsystem_darwin.dylib (1272.200.26) <974E9EF7-DE72-34B7-B056-0A81C10DF8EB> /usr/lib/system/libsystem_darwin.dylib | |
0x7fff77452000 - | 0x7fff77458ff7 libsystem_dnssd.dylib (878.200.35) <FFC665AA-B257-35AD-BD8B-32FD42C2EEC1> /usr/lib/system/libsystem_dnssd.dylib | |
0x7fff77459000 - | 0x7fff774a5ff3 libsystem_info.dylib (517.200.9) <0707C387-D7DE-372E-8FF1-3DE5C91932D6> /usr/lib/system/libsystem_info.dylib | |
0x7fff774a6000 - | 0x7fff774cdff7 libsystem_kernel.dylib (4903.221.2) <0E882078-7330-3B49-AA5D-3CDB5645A4E5> /usr/lib/system/libsystem_kernel.dylib | |
0x7fff774ce000 - | 0x7fff77519ff7 libsystem_m.dylib (3158.200.7) <43D1796B-954F-37D6-B1AC-9D80DF0655A2> /usr/lib/system/libsystem_m.dylib | |
0x7fff7751a000 - | 0x7fff7753eff7 libsystem_malloc.dylib (166.220.1) <3B196122-4E0D-3E3F-AA3E-5115B976DE26> /usr/lib/system/libsystem_malloc.dylib | |
0x7fff7753f000 - | 0x7fff7754aff3 libsystem_networkextension.dylib (767.220.1) <C54EB8F6-F305-3452-8DB1-F7DA6859AF8C> /usr/lib/system/libsystem_networkextension.dylib | |
0x7fff7754b000 - | 0x7fff77552fff libsystem_notify.dylib (172.200.21) <BCCB222F-DC64-3954-A836-DCCE6659CA5A> /usr/lib/system/libsystem_notify.dylib | |
0x7fff77553000 - | 0x7fff7755cfef libsystem_platform.dylib (177.200.16) <B75B04AD-69FE-3ADE-84D2-C17972FC8F49> /usr/lib/system/libsystem_platform.dylib | |
0x7fff7755d000 - | 0x7fff77567fff libsystem_pthread.dylib (330.220.2) <4958273C-4273-3501-8137-E44249E10D9C> /usr/lib/system/libsystem_pthread.dylib | |
0x7fff77568000 - | 0x7fff7756bff7 libsystem_sandbox.dylib (851.220.9) <4D6433A8-C703-3ED9-82EB-B9E481A0FD2F> /usr/lib/system/libsystem_sandbox.dylib | |
0x7fff7756c000 - | 0x7fff7756eff3 libsystem_secinit.dylib (30.220.1) <6C681113-8C48-3256-BEF6-0C3723DEB926> /usr/lib/system/libsystem_secinit.dylib | |
0x7fff7756f000 - | 0x7fff77576ff7 libsystem_symptoms.dylib (820.227.2) <3147D594-F41F-35FD-BF0B-6B8B66A407DE> /usr/lib/system/libsystem_symptoms.dylib | |
0x7fff77577000 - | 0x7fff7758cff7 libsystem_trace.dylib (906.220.1) <D5045DC5-A165-3238-A470-1796F12BF84F> /usr/lib/system/libsystem_trace.dylib | |
0x7fff7758e000 - | 0x7fff77593ffb libunwind.dylib (35.4) <41222EF6-2233-3CF4-947A-15D48CB8C030> /usr/lib/system/libunwind.dylib | |
0x7fff77594000 - | 0x7fff775c4fff libxpc.dylib (1336.220.5) <B2137772-E202-3656-A089-F6DD517007D5> /usr/lib/system/libxpc.dylib |
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 113 | |
thread_create: 0 | |
thread_set_state: 0 |
Calls made by this process:
task_for_pid: 0 | |
Calls made by all processes on this machine:
task_for_pid: 108756 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=639.5M resident=0K(0%) swapped_out_or_unallocated=639.5M(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
VIRTUAL REGION | |||
REGION TYPE | SIZE | COUNT (non-coalesced) | |
ATS (font support) | 32.3M | 8 | |
ATS (font support) (reserved) | 8K | 3 | reserved VM address space (unallocated) |
Accelerate framework | 1536K | 12 | |
Activity Tracing | 256K | 2 | |
CG backing stores | 64.6M | 10 | |
CG image | 1412K | 50 | |
CoreAnimation | 8832K | 40 | |
CoreGraphics | 8K | 2 | |
CoreImage | 232K | 32 | |
CoreUI image data | 5384K | 64 | |
CoreUI image file | 488K | 9 | |
Foundation | 28K | 3 | |
Image IO | 4908K | 3 | |
Kernel Alloc Once | 8K | 2 | |
MALLOC | 630.8M | 456 | |
MALLOC guard page | 48K | 12 | |
MALLOC_NANO (reserved) | 384.0M | 2 | reserved VM address space (unallocated) |
Memory Tag 242 | 12K | 2 | |
SQLite page cache | 64K | 2 | |
STACK GUARD | 56.1M | 28 | |
Stack | 22.2M | 32 | |
VM_ALLOCATE | 3976K | 70 | |
__DATA | 54.9M | 441 | |
__FONT_DATA | 4K | 2 | |
__LINKEDIT | 222.3M | 44 | |
__TEXT | 417.2M | 420 | |
__UNICODE | 564K | 2 | |
libnetwork | 640K | 8 | |
mapped file | 277.5M | 102 | |
shared memory | 14.8M | 32 | |
TOTAL | 2.2G | 1865 | |
TOTAL, minus reserved VM space | 1.8G | 1865 |
Hi I have the same problem, (Adobe Acrobat Pro crashing when trying to move a document from secondary monitor to main monitor) and found something that works on my combo. (IMAC 5K 27 inch late 2014 processor: 4GHz intel core I7 macOS MOJAVE 10.14.1)
In the preferences window choose 5th option from the top. "full screen'". You can change that . With me it was on "this monitor". I changed that option to "biggest monitor". I can now drag between my two screens without any problem. Hope it works for others....
Best, Marcel
The most recent update released Dec 11, 2018 may have solved the problem.
