Hello, hello,
I am learing Script UI and Scripting and I have a problem with palette in scripting Illustrator.
I want use palette to make window Script UI and use it to work with layers in illustrator but don't work.
I paste my code :
var windowString = 'palette\
{text: "My window",\
myEditText: EditText {characters: 20},\
myButton: Button {text: "Modify ?"}\
var myWindow = new Window(windowString);
function modify()
var myValue;
valeur = myWindow.myEditText.text;
myLayer.name = myValue
myWindow.myButton.addEventListener("click", modify);
var myDoc = app.activeDocument;
var myLayer = myDoc.activeLayer;
myWindow.show()
With type : palette, I can't work with Illustrator object (just app, for exemple app.beep() work) but no with document object or path item.
It's work with type : dialog (I can wotk with path item an othes Illustrator objects) )but I need use palette.
Can I get your help please ?
Sorry for my bad english, i can explain again if you want.
that's a know issue, to use a Palette window and interact with Illustrator you need to use BridgeTalk, here's a sample thread but you can search the forum, we have posted lots of samples about this topic
Is it possible to use AI "selection sets" in script and scriptUI?
Oooh thank you, I will see it
