Lr Classic CC not finding lens profile for supported lens
Oct 31, 2018 Oct 31, 2018
I'm using a lens that is on the list of officially supported lens profiles (a "Nikon AF-S DX NIKKOR 18-300mm f/3.5-6.3G ED VR" if that matters, see https://helpx.adobe.com/camera-raw/kb/supported-lenses.html). However, when I try to switch on the automatic profile corrections on a RAW file shot with that lens, Lightroom shows a message that it was unable to find a matching profile. As far as I can tell, the lens is reported correctly in the EXIF data. When I try to select the profile manually, the menu only displays a few (8) Nikon lenses, not nearly as many as should be supported. Is there anything I need to do to download additional supported lens profiles?
Running the current Lr Classic CC version 8.0, Camera Raw 11.0 on macOS 10.14.
Thanks.
778
Make sure you are working with a RAW file. From the text of your post is sounds like you are working with a JPG file. There aren't many lens profiles for JPG file because normally the camera includes the profile for JPGs.
Nov 01, 2018 Nov 01, 2018
Thank you. It was definitely a RAW file (Nikon .NEF). After several attempts I've now uninstalled and re-installed Lightroom and now the lens profiles work as expected. Don't know what happened here. All installations were done by the Adobe Creative Cloud tool.
Guest
Nov 15, 2018 Nov 15, 2018
I just noticed this issue today also and found a reply to a post back in 2016 regarding this.  It mentioned clearing the editing history.  Not sure how but after clearing the editing history on one photo I could see all the lens profiles again allowing me to apply to one and copy to the rest.  Hope it helps you also.
Check again, might be listed as
NIKON AF-S DX DX NIKOR 18-300mm f/5.6-6.3G ED VR
note  the double use of DX
