I create combined files for batches frequently. The latest files that I am combining are not working the same as all others.
I combine 3 files. When I go to File, I no longer see the option "Save As"
When I try to review the portfolio created, it does not display all of the files combined.
Have the seetings changed? Where can I view the settings?
Hi cherylk,
As per the issue description mentioned above, you are facing issue when trying to combine files in Acrobat DC, is that correct?
Could you confirm Acrobat's dot version and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
If you have created an action, you can check the settings for the action by clicking Tools > type action > manage actions >
Select the action > and click Edit.
Could you confirm if you are referring to the combine files options as seen in the screenshot below:
Have you tried clicking Tools > typing combine files to access the settings? Does that help?
Let us know if that is not the case.
Shivam
I discovered the settings were changed to create portfolios v. binders. My issue was resolved after I changed the settings.
Glad to hear you're back on track!
-Shivam
