I have uninstalled and reinstalled on root drive: I have uninstalled and reinstalled on secondary drive with more free space and the result is the same. Acrobat intermittently, but frequently, crashes when: 1) App window is expanded full screen (32" 3840 X 2160), 2) When creating a PDF portfolio, and, all of a sudden, opening PDFs from Bridge with a double-click rather than drag and drop or Shift + down arrow, either locks up Bridge or takes a long time to open.
I am not having problems with InDesign, Illustrator, or other CC apps.
I have exhausted the Forums re: resetting/adjusting preferences, etc. Could it be plugins?
Spent way too much time on this...HELP! thanks
Hi mlapolla,
As per the issue description mentioned above, Acrobat Pro DC is crashing on the machine, could you check if an update is available for Acrobat using check for updates option under Help menu, reboot the machine after installing update and try again. You may also download updates from here: Adobe software and product updates
Also, check if an update is available for the graphics card on the machine? You can check the same by going into the device manager or on the manufacturer's website.
If issue still persists, try the troubleshooting steps given in the following help document:
Resolve Acrobat DC intermittent crashes on Windows
Could you confirm dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Let us know if you need any help.
Shivam
Hi Shivam,
After doing all of this the problem persisted. Then I got smart; I updated the driver on my graphics card.
So far, only one crash which is likely related to overall system demands and not Acrobat.
Thank you.
Mark
Thank you for sharing your findings with us which will help other users facing a similar issue.
-Shivam
