Hey, all! I can't seem to find an answer to this anywhere.
If I'm editing in LRCCC, and send my photo to Ps to edit, like the images attached. External editors launched from Ps also don't work, such as Viveza or HDR Efex.
HOWEVER, if I start Photoshop using the normal shortcut (which has no extra launch parameters) manually, then send it to Ps from LRCCC, then it works just fine. Given that, I suspect it's an issue regarding how Lr launches Ps, but I've spent hours trying to figure out what's causing it.
Any ideas?
Thanks in advance!
known issue, work around is to launch PS before sending it an image from LR
Thanks! So, I assume a fix will come in a late update?
That seems like a safe assumption, but we cannot say which release will get the fix.
Members of this forum, like myself, are not Adobe employees, I have no idea if they will fix on next update, one would think they would. When will that be, nit a clue.
Alright! Thanks guys! I've modified my Lr shortcut to also launch Ps. Hopefully this makes it less glaring and less painful for now. Thank you!
