I'm using Lightroom classic CC version 8.0. And since the version before, upright transformation is f* up. It used to work fine. And for most it gets almost right. But when I try to do a vertical auto transform in a vertical photo it gets really weird results everytime. I don't know what's going on.
Hi kuantou,
Sorry that the upright transformation in Lightroom Classic CC 8.0 is not working as expected.
Could you please provide us a screenshot illustrating the issue?
Akash
sure, here are the original, the vertical and guided alignment.
Thanks for sharing the screenshots. Are you facing this issue with all the images or with any specific image format? Also, please try an reset Lightroom preferences back to defaults and check if that helps.
To know more about resetting Lightroom preferences, please refer the following link: https://helpx.adobe.com/lightroom/help/setting-preferences-lightroom.html
Let us know if that helps.
Mohit
Thanks. It seems resetting worked.
Great, thanks for the update.
Mohit
