I have never had this issue before... However, since I have upgraded premiere pro cc every time I import multiple clips into a sequence they don't transfer over to the timeline in chronological order so it takes me a long time to shuffle the clips. This a time consuming process and feels sloppy to manually rearrange the clips.... Are there settings that can resolve this issue? Thank you
I'm sorry that you are experiencing this issue. I have currently tested this on three systems and it seems to be working correctly. I'm not sure what version you were originally on but the order of clips on your timeline is powered by the order you are selecting them in your Project Window. Here is a breakdown of things to test:
If these features seem broken, it could also be an install issue and you may want to reinstall Premiere. Hope this helps!
