same issue going on, mix of win7 and win10
acrobat pro DC.
its been happening for the last 3 versions at least.
running a repair wont fix, needs to be a full remove and reinstall.
even then, at times it will disappear days later....
Hi RussR123,
As per the issue description mentioned above, PDF printer keeps disappearing, is that correct?
It could be because of a domain policy which is trying to delete the printer. Please refer to the following forum thread which discusses the similar issue:
Print to PDF keeps disappearing
You may also visit the following forum threads discussing the similar issue:
The PDF printer has disappeared
Adobe pdf converter keeps disappearing
Let us know if you need any help.
Shivam
Hi RussR123,
Shivam
