Since the newest update I have had 2 major issues not previously seen.
1. Premier stops loading at importerquicktime.prm
It seems to not load after I close premier and start it back up.
I have to end process, restart the computer and then premier loads.
2. I use OBS studio to record skype conversations as 60fps mov files. Before the latest update, premier had no problem importing the videos so I could edit them. Now, premiere stalls when I import the screen capture videos (mov and mp4). ***Please not, I am not screen recording while in premiere, I am capturing skype and trying to import the videos into premier. Which worked fine before the latest update*** What gives?
TarynsaurusRox,
Can you find the file here? %APPDATA%\Adobe\Common\Essential Sound\SharedTags.json
 If so, please remove it and see if the situation returns to normal after restarting Premiere Pro.
Kevin
If you use the AVG antivirus, uninstall it, it is known to cause problems with the importerquicktime.prm.
Hi TarynsaurusRox,
Did you try what our experts suggested? Also, please try updating the application with today's update. Is your issue resolved now? Let us know.
Kevin
I recently updated with the newest update. i am still having problems with "Premier stops loading at importerquicktime.prm"
Importing OBS studio .mov files seems to be working ok now.
TarynsaurusRox,
Kevin
This worked for me. Finally a solution.
Thank you!
