[Moderator moved from Dreamweaver support forum to Premiere Pro CC.]
My device spec:
ram 8.0GB
intel(r) core(tm) i7-4800mq cpu @ 2.70ghz
system type : 64 byte
I could export some videos before but they were quite short
I imported video from .MOV and i used to edit PP normally
But when i exported my project, it said :
i tried to follow all the instructions on the web but none of them work . After turning off all the lumetri color in every videos, then it said :
I have tried to change the preference frome performance to Memory, renderer to Software Only, change some Format, even try Match sequence setting, export in C:/, split the sequence to small pieces but they didnt work . I had to restart my computer over 10 times because of lagging
sorry my English is bad but i need help a lot .
Error Compiling Movie... some past discussions and ideas
May be caused by . in name https://forums.adobe.com/thread/2166620
-1st, create a new project and import the project that has errors and see if that fixes the problem
-http://helpx.adobe.com/premiere-pro/kb/error-compiling-movie-rendering-or.html
-and a long discussion https://forums.adobe.com/thread/1240823
It caused by name . Thank you so much John T Smith . You just saved my life . Wish you have a good day !
Oh man, it has error again and cant export im gonna die.... . I will read your link . Hope it works
