Hello!
Since the latest update of Photoshop CC 2019 on my laptop i have a severe problem: when i work at in Lightroom on a picture an i want to open it in Photoshop ("ctrl E"), the picture opens there automaticly as i am used to, but i cannot edit anything, neither change something within the picture nore (which is important for me a s a press photographer) edit the metadata.
The only solution i have found by now is to open the picture in photoshop via photoshop itself (which takes much longer and does not allow me to keep recently changes from lightroom and leads me through camera raw first), then i can make all the changes i want to (which particularely is to import a special capture i get from a agency i work for, which is formatted in *.xmp). Afterwards i have to accept the changes in lightroom.
This is very bad for me because it takes much longer to do this then it did before...
I do not have the same problem on another laptop, where i have not updated photoshop for the very last verion...
Hoping to get help here...
Regards
Oliver
It's a known bug.
The way to get around it is to open Photoshop first, then Ctrl E in Lightroom.
P.S.: To proof if it is a problem with the newest update i (and i regret it now) updated my photoshop version on my desktop -> same problem there now: take a picture from lightroom -> ctrl E -> it is opening in photoshop, but i cannot edit anything there...
It's a known bug.
Thank you - this helps...
But i hope they will fix this bug as soon as possible anyway...
Adobe has acknowledged this bug: Photoshop 20.0.1: Most functions in Edit, Image, Layer, Select and Filter grayed out for image opene... Please visit that bug report and click Me Too and Follow in the upper-right corner. That will make it a little more likely Adobe will prioritize a fix, and you'll be notified when the bug's status changes.
