Tried to combine 2 pdfs but it won't work.
Followed the tutorial.
Maybe one (a download) is protected by the author (BHP) and so combine is not permitted? If so, why does Acrobat not give me a message saying that this option is not available with this file?
This is the web page from which I created the first PDF: BHP | BHP approves South Flank project
You will see that it has a "link" symbol at the bottom - that is the pdf that I tried to combine with the first pdf that I created from the above BHP announcement.
I wasted so much time on this - and others around the world must run into the same problem.
Why don't we get a message saying that one of the files that you are trying to combine is locked or blocked in some way and so combine will not work?
Instead Acrobat DC allows me to go through all the steps - suggesting that all is OK, when it is not. If I had saved the combined file thinking that it had worked correctly I might have made a big mistake - eg lost data.
Surely this is something that Adobe should look into.
If you mean the Appendix then it's not secured and it should be possible to combine it with other (non-secured) files.
Are you trying to combine the file in Acrobat (if so, which version of it), or via the Create PDF online service?
What is the exact error message you're getting?
How did you create the other file you're using?
Thank you for your prompt response.
Using Acrobat DC V 2019.008.20081 I was trying to combine a genuine non-secured pdf file with a pdf that might have been created using 3rd party (CuteWriter) software (I can't recall - I used "print" from the web and I have two options for pdf). To be sure I have just now opened that questionable file in Acrobat DC and used "save as" to be sure it is now a genuine non-secured pdf file. I then tried "combine" again. This time it did not fully combine the files - but it did allow me to save the result as a "portfolio pdf". That is good enough for me. However, I was earlier under the impression that "combine" creates a normal pdf file - not a portfolio pdf - but that might just be my misunderstanding of how "combine" works.
I received no error message at any stage - which was my original complaint - if there is a problem (eg with the original file having been created by a 3rd party software) Adobe should be able to give me a warning. I have many hundreds of files created with CuteWriter and have always been worried that there could be some incompatibility with Adobe Acrobat's pdf format. About 10 years ago I received a large file from a major US company and Adobe Acrobat Reader said it was not a proper pdf file and it could not be opened. I have been worried about compatibility of pdf files ever since. Your question regarding what version I am using only exacerbates my original concern.
