1
AME error code -1609629695
Nov 28, 2018 Nov 28, 2018
Hi, I'm using AME to render my video from After Effects.
I used to get the same error code for the renders (-1609629695) all the time, but all of sudden it was working fine for a few renders.
And now I'm getting the error again.
For different compositions, this has been occuring often, and I couldn't figure out what is causing this error or find any information about this online.
I'm using AME CC 2018 version 12.1 / After Effects CC 2018 version 15.1.0
Processor Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz, 2801 Mhz, 4 Core(s), 8 Logical Processor(s)
Windows Version 10.0.15063 Build 15063
Intel HD graphics P530
NVIDIA Quadro M1000M
and here's what I get about why my rendering is failing
- Encoding Time: 00:00:41
11/28/2018 04:00:20 PM : Encoding Failed
Export Error
Error compiling movie.
Render Error
Render returned error.
Writing with exporter: H.264
Writing to file: \\?\C:\Users\seungmi_lee\Documents\Personal Project\deliverable-test\asset\WIP\wip_AME\scene-07_1.mp4
Writing file type: H264
Around timecode: 00;00;08;18
Rendering at offset: 4.037 seconds
Component: H.264 of type Exporter
Selector: 9
Error code: -1609629695
Error or problem
39.6K
Adobe Employee ,
Hi there, Seungmeelee!
Here are some threads that have had similar issues. Please try these ideas while I look into this error for you!
Cant render anythhing with AME.
Error compiling movie. AME 2018
  • Make sure your NVIDIA GPU card has the latest drivers installed.  Check the NVIDIA site directly to see if there's a newer driver available for your model.
  • Try a different GPU setting in the Renderer menu at the bottom of the Queue panel.  If it's set to "CUDA", try "OpenCL" or "Metal" and re-import your sequence or source media.  If that doesn't help, try "Software Only" rendering to bypass the GPU.
  • If you have a Logitech webcam installed, remove it and uninstall any related drivers/software
  • If you're exporting to H.264 or HEVC, check if "Hardware Encoding" is enabled in export settings.
Let me know if any of these ideas work for you!
-Caroline
Hi Caroline,
Thanks for your comment, but I tried everything but none of them is working for me.
I'm curious if there's any way we can figure out what the error code means, cuz I'm getting that error code in every render failure.
Adobe Employee ,
Nov 29, 2018 Nov 29, 2018
I've done some more research and found other similar threads with a lot of different workarounds.
The common denominator seems to be an issue with the GPU that's doing the rendering.
Error compiling movie error code 1609629695
Repeated Render Errors - Code -1609629695
AME Error Code -1609629695
Encoder error -1609629695
I've also collected a YouTube tutorial that's worked for some users but not others.
Adobe Premiere Pro: How to Fix "Error Compiling Movie, GPU Render Error 1609629695" - YouTube
And a uservoice post!
The infamous GPU render Error -1609629695 – Adobe video & audio apps
^Caroline
Feb 16, 2019 Feb 16, 2019
i7-3770k / Asus Maximus V Formula / DDR3 Corsair 16gb / SSD Samsung 750 Evo 250Gb / EVGA 1080 Ti FTW3
Windows 10 x64 (1809) / Adobe Media Encoder CC 2019 (13.0.2)
I have the same problem. Disappears only if I increase the paging file to 50GB
Adobe Employee ,
Feb 18, 2019 Feb 18, 2019
Hi olegs,
Thanks for trying all the suggestion provided above. You've mentioned that the error disappears when you increase the paging file size to 50GB. I would recommend having a look at this article: How to fix issues that cause errors when rendering or exporting
Clearing up space in your hard drive is the first thing that Adobe suggests in case of export errors.
Is that the same step that you tried? Please go through it and check if there is anything else that can be done.
Best
Shivangi
Feb 20, 2019 Feb 20, 2019
I have 100GB free on my system hard drive. On the disk where I export video 500GB free.
Mar 07, 2019 Mar 07, 2019
Hi olegs,
i had the same Problem. i cleared mediacache of AE,PR and Mediaencoder, but ive got the same issue.  After reinstalling quicktime and restarting AE and mediaencoder it works.
Hope it workes for you too!
Cheers,
ben
May 14, 2019 May 14, 2019
Thank you! It works!
Jun 17, 2019 Jun 17, 2019
Hi!
What drivers are you using? when you said "restarting AE and AME" did you mean you unistall and install them again?
Hi Yerick10, with restarting AE and AEM I meant: closing aftereffects and mediaencoder and starting them again. I’m not sure which driver i had installed at that time. I think for the graphics card it was the default driver of NVIDIA.
Cheers
Ben
Sep 30, 2019 Sep 30, 2019
Same error here. Started when I switched to a new pc.
- Encoding Time: 00:00:19
09/30/2019 11:23:04 AM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\C:\video\lam-gods-master_2_3.mp4
Around timecode: 00:00:09:04 - 00:00:09:20
Rendering at offset: 9,133 seconds
Selector: 9
Oct 17, 2019 Oct 17, 2019
In my experience, this error often appear when one file of a sequence asset is corrupted.
for exemple if a jpeg file in sequence is corrupted, it will be fail when it will try to encode this frame.
good luck.
Nov 08, 2019 Nov 08, 2019
Reading some other forums I found that the combination of the Hue/Saturation effect and blur can effect the encoder with this error (or sometimes just Hue/Saturation on its own). By using the search feature in the layers panel - I click+drag turned off all of the Hue/Sat effects on my layers, let the preview refresh a frame, then turned them all back on again. For whatever reason - now exporting to encoder isn't crashing with this error.
Another thought for people who maybe stumble upon this, try turning your effect on your layers off (to test) and see if that does anything... then at least you have another troubleshooting idea
Nov 14, 2019 Nov 14, 2019
It happens with me if some layer is scaled up extremely big (like 1000%) or one of the files you are using in the project is insanely large (like 20000px or something).
Try to delete those and check if the render works then
Apr 14, 2020 Apr 14, 2020
This worked for me by deleting After Effect cahce.
I deleted all the cache files from temp folder
type %temp% in run of windows. Then delete all the files in temp folder .
Jun 04, 2020 Jun 04, 2020
I solved the problem converting the source files, the footage I used in the project (there where a bunch of mp4 files in 4K) with AnyVideo Converter a free converting utility to mp4 same resolution , but AME accepted this files after conversion
Jul 23, 2020 Jul 23, 2020
THE SAME ****IN ERROR ALL THE ****IN TIME!!! *** YOU ADOBE!
Sep 08, 2020 Sep 08, 2020
I had the same error, I solved it by changing the composition settings from HDTV 1080 25 to HDV 1080. It worked for me
Sep 20, 2020 Sep 20, 2020
SOLVED!!!!
Set your Media Export to Software, not Hardware GPU (within the Media Export dialogue)
You may or may choose 1 pass or 2 passes. I've only tested single pass.
And increase your Windows Paging file to at least 55GB -
Restart the machine
I was able to export an entire 6K 30 minute film.
And PROBLEMS ARE SOLVED.
May 16, 2022 May 16, 2022
How to increase window paging file??
Oct 24, 2021 Oct 24, 2021
حل هذه المشلة في انك تترك الجهاز يقوم بتصدير المقع من دون تشغيل اي برامج اخرى وان يظل برنامج ادوبي هو اعلى الواجهة
