Change style basedOn
Contributor ,
Nov 29, 2018 Nov 29, 2018
Hi experts,
How to change my paragraphs style basedOn?
my script as below, but not working
var doc = app.activeDocument;
var paraStyles = doc.allParagraphStyles;
var basicParagraphStyle1 = doc.paragraphStyles("01 Body");
var basicParagraphStyle2 = doc.paragraphStyles("06 Notes");
        for(var n=0; n<paraStyles.length; n++)
            if(paraStyles.name.match(/03|04|05|06|07|08|09|10|11|12|13|14|15|16/g)) {
                paraStyles.basedOnStyle == basicParagraphStyle1;
            else if(paraStyles.name.match(/17|18|19|20|21|22|23|24|25|26|27|28|29|30/g)) {
                paraStyles.basedOnStyle == basicParagraphStyle2;
Could someone please give me some opinions please.
Regard
John
Scripting
369
Community Expert , Nov 29, 2018 Nov 29, 2018
Hi John,
You need to look at the object model for the name of the properties you are trying to set. A good place to start exploring objects and their methods/properties is
https://www.indesignjs.de/extendscriptAPI/indesign-latest/#about.html
Other older version of the documentation can be found at in
Now with regards to you code in addition to the rectifications done by Sudha K in your code i have some more points to share, look at comments in the code below
Contributor ,
     Please use the below code.
var basicParagraphStyle1 = doc.paragraphStyles.item("01 Body");
var basicParagraphStyle2 = doc.paragraphStyles.item("06 Notes");
paraStyles.basedOn = basicParagraphStyle1;
paraStyles.basedOn = basicParagraphStyle2;
     When assigning value to the variable should not use "==".  "==" should be used in condition case only.
Hi John,
//You need to test if the pstyles you got above are valid or not, what if these styles did not exist in the document
if(!basicParagraphStyle1.isValid)
    alert("Style 01 Body does not exist in the document")
    exit()
if(!basicParagraphStyle2.isValid)
    alert("Style 06 Body does not exist in the document")
    exit()
var paraStyles = doc.allParagraphStyles;      //You don't need this line, this is done in line no 2, remove this
          paraStyles.basedOn = basicParagraphStyle1;    // Here you used == instead of =, in addition to the wrong property name
          paraStyles.basedOn = basicParagraphStyle2;  // Here you used == instead of =, in addition to the wrong property name
-Manan
Contributor ,
Nov 30, 2018 Nov 30, 2018
thanks so much Manan
John
