3 Replies Latest reply on Nov 30, 2018 12:19 AM by Johnwhite
    Change style basedOn
    Johnwhite Level 1
      Hi experts,
      How to change my paragraphs style basedOn?
      my script as below, but not working
      var doc = app.activeDocument;
      var paraStyles = doc.allParagraphStyles;
      var basicParagraphStyle1 = doc.paragraphStyles("01 Body");
      var basicParagraphStyle2 = doc.paragraphStyles("06 Notes");
              for(var n=0; n<paraStyles.length; n++)
                  if(paraStyles[n].name.match(/03|04|05|06|07|08|09|10|11|12|13|14|15|16/g)) {
                      paraStyles[n].basedOnStyle == basicParagraphStyle1;
                  else if(paraStyles[n].name.match(/17|18|19|20|21|22|23|24|25|26|27|28|29|30/g)) {
                      paraStyles[n].basedOnStyle == basicParagraphStyle2;
      Could someone please give me some opinions please.
      Regard
      John
        • 1. Re: Change style basedOn
          Sudha K Level 1
               Please use the below code.
          var basicParagraphStyle1 = doc.paragraphStyles.item("01 Body");
          var basicParagraphStyle2 = doc.paragraphStyles.item("06 Notes");
          paraStyles[n].basedOn = basicParagraphStyle1;
          paraStyles[n].basedOn = basicParagraphStyle2;
               When assigning value to the variable should not use "==".  "==" should be used in condition case only.
          • 2. Re: Change style basedOn
            Manan Joshi Adobe Community Professional
            Hi John,
            You need to look at the object model for the name of the properties you are trying to set. A good place to start exploring objects and their methods/properties is
            https://www.indesignjs.de/extendscriptAPI/indesign-latest/#about.html
            Other older version of the documentation can be found at in
            Now with regards to you code in addition to the rectifications done by Sudha K in your code i have some more points to share, look at comments in the code below
            //You need to test if the pstyles you got above are valid or not, what if these styles did not exist in the document
            if(!basicParagraphStyle1.isValid)
                alert("Style 01 Body does not exist in the document")
                exit()
            if(!basicParagraphStyle2.isValid)
                alert("Style 06 Body does not exist in the document")
                exit()
            var paraStyles = doc.allParagraphStyles;      //You don't need this line, this is done in line no 2, remove this
                      paraStyles[n].basedOn = basicParagraphStyle1;    // Here you used == instead of =, in addition to the wrong property name
                      paraStyles[n].basedOn = basicParagraphStyle2;  // Here you used == instead of =, in addition to the wrong property name
            -Manan
            • 3. Re: Change style basedOn
              Johnwhite Level 1
              thanks so much Manan
              John
