As we are creating a Wizzard for document processing in Acrobat PRO DC, we found that the Single Fixes (like ‘Create content-item for Link Annotations) in the Preflight can not be chosen, only the ones under Profile. Is there a way to include a Single fix in a Wizzard?
Just create a custom profile that executes that single Fix-Up command...
On Fri, 30 Nov 2018 at 15:24, Frans van der Geest (ACP) <
Ah. Thanks, but a *bit* more guidance (or a link to an example) would be appreciated as I Googled already a lot on this but could not be steered in the right direction, hence asking here...
EDIT: Ah, found this:
Preflight profiles (Acrobat Pro)
Open the Preflight tool, click Options - Create New Preflight Profile...
Give you profile a meaningful name. Go to the Fixups section and add your fix up to the profile by selecting it on the right hand panel and click the left arrow button to move it to the list of select items.
Click Save and now go back to your Action and add to it a step that executes this Preflight Profile you just created.
Don't forget to add a Save step after that one, and you're done!
Still the same problem: the *Single Fixes* are not there:
The fix selected here, in Dutch, to Artefact items, can not be added to a (new) profile.
What are the options under the drop-down at the very top of the first screenshot (under the Preflight title)?
Ah!
Got it!
Thanks very much!
Graag gedaan! 🙂
