My larger documents are consolidating fonts quite regularly, which consumes a great deal of time when I can't work on my document. How do I get the fonts to stay consolidated, so to speak.
OS X.14.1 Acrobat XI (11.0.23)
Hi Steve Gartside,
Have you tried the suggestions given in the threads mentioned above? Also, try saving the file using the Save As, and check if that helps.
Refer to the steps given in the following help document for the same:
Saving PDFs in Adobe Acrobat and Reader
Let us know if you need any help.
Shivam
Sorry, that's 'Consolidating Duplicate Fonts'.
Hi Steve,
As per the issue description mentioned above, you are receiving consolidating duplicate fonts' message in Acrobat, is that correct?
Could you confirm if you are trying to insert pdf pages to an existing pdf in Acrobat?
Or trying to combine multiple pdf files into a single pdf file in Acrobat?
Does this happen with a specific pdf file? Have you tried with another pdf file?
You may also try the suggestions given in the following forums thread discussing the similar issue:
Can I change option for Consolidating Duplicate Fonts?
"consolidating duplicate fonts" (Edit PDF)
https://acrobatusers.com/forum/general-acrobat-topics/consolidating-duplicate-fonts-0/
Shivam
Sorry for the delay, it's a busy time here at the moment.
Yes, this occurs when inserting pages into a document, however, I'm not convinced I'm seeing what I'd expect to see.
When I open the document and add a page it takes around 2 to 3 minutes to consolidate fonts, this then doesn't happen if I add a 2nd page or more fairly soon after adding the first, but after 10 to 15 minutes or more so it goes through the whole consolidation process again when I add a subsequent page.
It's kinda like the consolidation takes place in memory and is lost when the document is either closed or the memory is reclaimed for another task. I'd sort of expected it to consolidate fonts and remember what it had done so the next time it only needs to consolidate fonts on the new pages I'm adding.
When I look at properties > fonts, I was expecting to see one instance of each fonts, but there are hundreds if not thousands in the list and many appear to duplicate.
Hi Steve Gartside,
Shivam
Hi !
I also have the same problem, an incredible amount of duplicate and partial fonts in the same pdf file.
I've tried all the solutions above but none of them work.
Can you help me?
The pdf is 1400 pages long. Acrobat version: 19.21.20061.361316
I see there is no further response. I have a 3000 pg document that I was editing and saving in very short order. Saves were taking around 30 seconds. I then decided to try consolidatinng duplicates fonts (check-box in Save-As dialogue) to see how the resulting file would change.
After about a 10 minute save it dropped a couple MB in size, which would be great, but now it wants to consolidate fonts on every save, even though the document shows that all fonts are already embedded in subsets. This includes Save-As with checkbox for consolidating, unchecked.
Furthermore, Acrobat Pro DC now wants to consolidate all PDF files, regardless of how I save them. I cannot reverse whatever happened.
I'm having this same problem, and NOTHING works. It is utter BS for an app that is supposed to save time and that I'm paying for. How do you fix it from having literally thousands of "consolidated" fonts???
